Bates Racing
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
Bates Racing
I've got this Aussie bike with a bent fork. The fork is spaced too wide, and then if you bend it closed with the skewer, the wheel is off center.
Today I bought this green fork, the steerer is exactly the same length, same crown race dia, so easy swap over. The front end sits higher. Brake reach is quite a lot.
Can anyone ID the green fork? Seems pretty nice. The only marking on the steerer just says 58.
How will this ride? Is this a bad idea?
Likes For Soody:
Quoted: 1149 Post(s)
Liked 1,773 Times
I’m sure that it will work fine. It does change, slacken, your geometry some.
Your original fork is probably fine enough for realignment. Aside from putting a wheel on the original have you checked what is off?
Likes For Mr. 66:
Quoted: 275 Post(s)
Liked 417 Times
I did carefully bend the rear end with a bit of wood as the spacing there was 118mm and the dropouts weren't parallel. That seemed to work ok.
I'm not confident about bending the fork, but now that i have a replacement might as well make some alignment tools and give it a try.
like this guy:
Likes For Soody:
Likes For masispecial:
Quoted: 275 Post(s)
Liked 417 Times
