Does rotating weight really matter?
Quoted: 1763 Post(s)
Liked 1,293 Times
Likes For bruce19:
Weight matters no matter if it rotates or not. However the effect is greatly exaggerated on the forums and the reasons why is not generally understood by the forum "experts".
Sunshine
Quoted: 11027 Post(s)
Liked 7,574 Times
When starting from still, sure.
When trying to accelerate, sure.
When JRA, not really.
I dont need to watch a GCN 'experiment' though.
Likes For mstateglfr:
Liked 1,293 Times
Likes For noodle soup:
Is that the video where the conclusion was "no, unless you're accelerating"? Isn't climbing a whole series of micro accelerations, once it gets steep enough for inertia to be negligible for a given speed? Also, what about crit racers constantly accelerating out of corners? It seems to me even casual cyclists are accelerating quite a lot.
Likes For Doomrider74:
Quoted: 986 Post(s)
Liked 1,652 Times
Mass in motion and more than that, Harmonic Mass in motion. Not so much easily attainable but a little easier for bicycle riders. Looking at the technical aspects bicycle riders attempt this physically, mechanically, and metaphysically on a good ride...
Yes. Technically speaking, power variation across the pedal stroke creates speed oscillations in all riding, although this is much less pronounced in situations with more inertia.
The thing is, rotational inertia works in both directions. Heavy wheels won't accelerate as quickly at the peak of your power stroke on a climb, but they also won't decelerate as quickly when the power isn't flowing.
Likes For HTupolev:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I don't know much about racing, but I thought very small differences in acceleration can make or break a break away attempt. That video completely ignored that aspect of wheel weight.
Quoted: 1250 Post(s)
Liked 1,336 Times
People use the rotating mass argument as a justification tool when trying to explain why they are riding multiple thousand dollar wheel sets while they are 20 or 30 lbs overweight.
Likes For Atlas Shrugged:
Likes For rubiksoval:
Method to My Madness
Quoted: 2000 Post(s)
Liked 1,506 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
It may not manifest on the stopwatch, but it certainly affects handling feel. Bikes with lighter rims/tires feel much more fun and responsive to changes in orientation (less weight, lower angular momentum)
Likes For WhyFi:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
It matters for acceleration since you not only have to accelerate the wheel mass forward with the rest of the bicycle, but you also have to add rotational energy to the wheels. And the rotational (angular) energy grows with the square of the rotational speed (angular velocity). (For the technical people, there is an w^2 factor where w=omega.) Forward kinetic energy only grows linearly with speed.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
This isn't true at all. Kinetic energy for linear acceleration is quadratic with velocity.
https://en.wikipedia.org/wiki/Kineti...f_rigid_bodies
The inertia of mass at the tire requires double the kinetic energy to reach a certain forward velocity than mass at the frame.
Bikes: CO-OP ADV 3.1 aka Beeftank (stolen, RIP), State All-Road
Quoted: 96 Post(s)
Liked 144 Times
Disclaimer: All of the following may only have taken place in my head and is not based on anything scientific.
Purely anecdotal, but I didn’t like when I had lighter wheels, I’m not a heavy person so I definitely felt I had to work more to keep them going on flats, or on any road terrain in general. I felt like if I stopped pedaling the bike stopped. I did definitely notice they felt more touchy/responsive in a way that I actually didn’t like, which lines up with what whyfi said above. I understand I am the outlier here though lol. I feel more planted and comfortable with heavier wheels. I may just be crazy though. There’s also probably other variables I’m too dim to understand here. Long story short, I sold my lighter wheels.
All that said, the above qualities mean on a mtb lighter wheels make sense for me because I’m not rolling as much (inertia matters less) and I can appreciate the quickness and lighter feel more.
Quoted: 4843 Post(s)
Liked 3,969 Times
But, you are at your max. 2 feet means you are on that wheel, 5' means you aren't. You may not be able to close that extra 3 feet or it may take you minutes to do it. If you do make it, you may be cooked for the rest of the race. But getting that little extra jump to grab that wheel, that extra 0.07 seconds up the road? You're on! You're in the break. You may will be finishing 10 minutes ahead of that other you on heavier wheels who didn't quite make it.
In my hardest race ever, I was half way up the deciding hill 15 miles before the finish, in about 30th place with an unbroken line of rider in front of me. I was hurting bad. The race had been very fast and I'd been an instigator in an ill fated break. Looked over my shoulder to see how far I could fade back and still be with the leaders (being fully aware this might cause a field split that might never come together again). Next rider was 25 yards back. That's about 4 seconds at the speed we were going. I knew instantly the wheel I was on was going to beat that guy and everybody else back there by 10 minutes. I stayed on and was well rested and had waited in line, then got my drink at the water fountain before anybody else finished.
That was at steady speed and rims didn't matter. It was about holding a wheel at any cost. I paid a LOT to stay on that one. But at the top of the hil, I was there and the guy behind me wasn't. (I was on 270 gm average rims and 250 gm tubulars so they WERE very light and helped me to an unknown degree over the previous 3 hours.) Point being - the little things in races matter far more than any analysis of seconds gained or lost, etc. will ever tell you. If you are strong enough to simple clobber everyone with the raw power of your legs, those light rims might not matter. If you have to race with all your smarts and all your resources to be there at the end, rims can be make or break items.
Likes For 79pmooney:
Liked 1,506 Times
Yes, this is scientific; you were after the flywheel effect. Time trial bikes have solid rear wheels for that (and aerodynamic) reasons. This is not a phenomenon that is unique to cycling. Those who have installed aftermarket flywheels in manual transmission cars also go back and forth on this issue.
Likes For SoSmellyAir:
Quoted: 850 Post(s)
Liked 344 Times
I get confused when people say riding a fixie gives you a better pedal stroke LOL
Likes For smashndash:
Liked 1,293 Times
My take away thus far is that there has been a lot of money spent for not much gain. I am willing to be convinced otherwise but so far that's where I am.
Likes For bruce19:
Liked 3,969 Times
I will also say that this effect is much more apparent on fixed gear bikes. I started riding on a fixie with 3000+g 50mm deep alloy wheels. When I switched to a road bike, my legs would literally stop (not exaggerating) at the top of the pedal stroke because I was so used to the pedals carrying my feet through the deadzone.
Quoted: 8326 Post(s)
Liked 9,141 Times
Quoted: 850 Post(s)
Liked 344 Times
Ride with some slack in your chain and go down fast hills (keeping the top run of the chain tight). Also ride up seated as much as possible. And use some discipline. The vets in my club told me to ride fixed 45 years ago. I've never regretted it. When my pedal stroke needs work, I get back on it. (But I've never ridden heavy wheels outside of big tired gravel.)
Quoted: 7058 Post(s)
Liked 11,111 Times
FWIW it wasn't a GCN experiment. Some Formula 1 tech guy ran some tests with a computer program is what I took from it. Apparently he's the founder and CEO of this company: https://www.swissside.com/?locale=en
Sure, yeah, I trust him.
Likes For Koyote:
Quoted: 18883 Post(s)
Liked 10,646 Times
