Video for setting up a new cassette?
I finished my first century ride last weekend and am now trying to set up my first indoor trainer and transitioning to riding indoor for the first time. Any good resources on how to get the cassette up and running on my trainer? Brand new to trainers and trying to figure out how to set the whole thing up. Thanks.
More info needed. If the trainer doesn't require your bike's rear wheel, then it's relatively new and should have online instructions available.
Sorry. Should have given more details.
It's a refurbished Wahoo Kickr Core from Wahoo.
I did buy a separate cassette from Wahoo.
I'm not sure I got all of the paperwork with the refurbished model, so I'm going off of what I got. I understand there is something to line up when getting the cassette installed.
Does it matter how many gears are on my bike normally vs how many are on the new cassette? I think the new cassette might have more.
(Figuring how to get my bike taken apart enough will be the next step. )
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Quoted: 1819 Post(s)
Liked 1,696 Times
All you have to do is remove the rear wheel in order to install the bike on the trainer.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Rtfm.
Quoted: 4414 Post(s)
Liked 4,867 Times
1. It does very much matter how many gears are on your bike vs the new cassette. They have to match or your rear mech won't shift properly.
2. Also if the new cassette has different max and min sized gears you might have to adjust both your chain length and rear mech adjustment to clear the cassette. At worst case if your new cassette has a much larger gear your rear mech might not have enough capacity to clear it at all.
So at this point you need to take a look at the cassette on your bike and see how it matches the new one you bought. If the new one has a different number of gears then you need to swap it for a cassette identical to the one on your bike. That's your easiest option here.
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Likes For shelbyfv:
