Domane SL 5 vs Cervélo Caledonia 105
Bikes: None at the moment
Quoted: 5 Post(s)
Hi all,
Not asking to help compare both bikes as I’ve had a chance to ride both in multiple sizes. I’m more asking advise on which I should purchase given a few variables.
Both are the same price up front, but there’s a few factors that concern me with both. The Cervélo concerns me because of it’s press fit BB and lack of dealers and or support. If I purchased a Cervélo it would be from a chain store called Erick’s Bike, Board and Ski.
The Trek I would be purchasing from an LBS. In the domane’s case I would need to replace the stock handlebar to a shorter reach and width, so that incurs a bit of added cost. Also, given I live in the Midwest I’m basically in Trek central so servicing it would never be an issue.
It’s quite the dilemma for sure, both are nice bikes for different reasons. The Cervélo has a snappy fun acceleration to it while still being comfortable, plus right of the box it would be set up and ready to go. The Trek Domane seems to be the ole reliable, it’s just I’d have to spend a bit more to make it work for me.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
Surprised a bit on your mention that the Trek would require a reduced reach handlebar. The Domane has probably one of the shortest frame reach ratios vs stack of the bikes out there. However, just looked at component list and see that the specced handlebars for any frame size above a 52cm has a 10cm reach (weird in this day and age where 8cm is fashionable).
Also, just a couple or so threads down from here, there's a Domane SL discussion -- seems that the stock bottom bracket ain't so great. Erik's is a good size chain, right? Good and bad -- if they have a good mech on staff, then no worries. I'd think a big chain has clout with the manufacturer if they go to bat for you on a warranty issue, while the Trek (owned?) store is also doing double-duty protecting Trek's interests? Maybe choose based on which color you like better?
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Hi all,
Did you look to see if there are any dealers within a reasonable dist?
Likes For phrantic09:
Quoted: 5 Post(s)
There’s a couple Cervélo dealers within an hour from me. One is an LBS that sells in Felt, Cannondale, and Cervélo bikes. The other is Erik’s Bike Board and Ski which sells all sorts of sporting goods.
Quoted: 5 Post(s)
The LBS carries Trek, but also felt and surly bikes. However, yesterday I phoned them to ask if I could trade in my Emonda ALR 5 and the woman on the phone said Trek didn’t want them to take in anymore trade ins. I was a bit off put by this as they were seemingly willing to let a potential buyer walk away. In the chain stores case I would order the bike online and I could either have it delivered to my door or have it shipped to store to pick up.
Quoted: 9653 Post(s)
Liked 6,365 Times
Trek company stores in our area take trades. You get blue book value if in good condition.
Quoted: 2333 Post(s)
Liked 2,097 Times
Bike service isn't like like taking a BMW to a Benz dealer. Any bike should should be able to adjust your gears or lube your chain.
Cervelo BB is not an issue.
Ole reliable sounds boring.
You did not say what size but the frames are pretty similar. The Trek has a shorter reach but generally Trek's have slacker seat tube angles and they should be pretty similar to the Cervelo. The Cervelo has more reach but less STA and less stack, so, it should feel slightly more sporty compared to the laid back ole reliable.
Greg would get the Cervelo
Likes For GhostRider62:
Quoted: 5 Post(s)
Liked 2,097 Times
For the Trek I would go for a 58cm and the Cervélo a 56cm. Both have relatively the same top tube effective length. The Cervélo is certainly more fun to ride, but I don’t know how it would feel after 50 plus miles. I’m someone who likes to go on long bike rides multiple times a week.
Quoted: 20810 Post(s)
Liked 9,456 Times
I owned a Domane SL5 - my R3, which has tighter tire clearance than the Caledonia, is a smidge less comfy than the Domane on 6+ hour rides, but still very comfy on 6+ hour rides. I'd go Cervelo all the way if the handling appeals to you.
Likes For WhyFi:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
The Domane has bigger tire clearance than the Caledonia. The Caledonia is more of a road bike that takes road+ tires, while the Domane is more of a full-on gravel bike. Which would you prefer? Both are good, but cross-shopping them is like comparing a 4Runner to an Accord.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
Quoted: 18883 Post(s)
Liked 10,646 Times
I've had a few Cervelos and never any BB issues.
Likes For Seattle Forrest:
Quoted: 10237 Post(s)
Liked 5,184 Times
My C2 always made a popping sound on low rpm high torque situations. BB went kaput at 5000 miles, which is pretty good. Threw a new BB on there and it makes the same popping noise. That’s all I can contribute to this thread.
Dont get me started on Brake Rub.
Liked 5,184 Times
Oh, My madone has the T47 bottom bracket which I think is the same as the domane you are looking at. That went kaput at 3,000 miles.
I guess I do have more to add to this thread.
Liked 2,973 Times
if customer service is a factor, then Trek is not your brand.
I didn't put CS at the top of my list when I was looking for a dropbar CF bicycle. Ended up with the Domane. No regerts.
-Oh Hey!
-Oh Hey!
Liked 5,184 Times
Liked 6,365 Times
Customer service at the two Trek stores I use has been outstanding.
Several times stuff has been fixed/adjusted while I wait. I’ve never had to leave the bike. The charges for service have been anywhere from $0.00 to $25.00. That’s out of warranty.
Likes For Mojo31:
Liked 5,184 Times
same here. BB was replaced for free.
Liked 2,973 Times
The lbs CS is fine, but Trek beyond that could do better.
-Oh Hey!
-Oh Hey!
If you like riding the Cervelo buy it! It’s a great bike. As others have said ongoing repairs can be any bike shop. If you have a warranty issue you’ll need to work through the dealer, but it’s really Cervelo you’ll be working with.
Here’s an interesting interview with someone from Cervelo about the Caledonia.
For instance, most endurance bike raise the front which impacts handling instead they lowered the bottom bracket (since you don’t need to pedal through corners if you aren’t racing) increasing the stack while maintaining the handling. The domane is also a great bike, but you should buy the one that puts the biggest smile on your face.
Likes For ratell:
Quoted: 1109 Post(s)
Liked 1,200 Times
I don't know why service would be an issue except for warranty. The components aren't specific (in general) to any brand. Any good shop can take care of your bike.
I'd by the Cervelo if I liked it. If it didn't, I'd look at every other brand that is within reasonable distance, or online. I'll admit a bias against Trek. I just enjoy having stuff of equal or better quality and value that isn't the same as everyone else, so Cervelo would probably be an example of that as long as it suited me.
RE: press fit BB's We have two press fit BBs in the family - both PF30. I've never heard nor seen any problems with the original PF bearings. However, just for something to do a couple of winters ago, and thinking it was about time to replace them, I replaced the older bike's with a "screw together" PF 30 bottom bracket from Praxis. Liking that design when I built up a new PF30 BB bike last spring, I used a Wheels Mfg. version of the same sort of thing. They're similar but slightly different in application. But, if you're at all concerned with the press fit bottom bracket (unlikely as problems are), it's easily resolved with a thread together.
OP is making Erik's bike shop sound like it's a big box Dick's Sporting Goods or similar. It isn't, it's a bike shop with small stores, albeit a small midwest chain. If Erik's now sells Cervelo (didn't last I checked, but it's been a while), then it shouldn't be an issue getting it serviced there...or anywhere else. FWIW I take both of my bikes (one Colnago, one Specialized) to Grand Performance in St. Paul. The former was bought there, the latter was bought at Erik's and is not sold by Grand. Nothing against Erik's, I just prefer Grand for service work.
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I bought a Caledonia ten months ago and really like it. It's possible that if I'd bought a Domane I'd like it just as much, but the Caledonia appealed to me more than competing bikes. I've had no BB issues, and with regard to longer rides have completed one Century on it with no issues. Two good bikes, so get the one that speaks to you. I heard the Caledonia calling my name, and it's been good so far.
Liked 10,646 Times
I have a Cervelo C3 which is very similar but older. It's a very fun bike to ride. I love the handling. It accelerates well. I can take it on dirt roads in the mountains around here and ride it pretty fast in good conditions.
