Tubeless rim- clincher tire. Rim tape?
Bikes: A few BSO's.
Quoted: 164 Post(s)
Liked 55 Times
It would seem the obvious answer is no since the rim bed is closed and nothing to puncture the tube. I googled it and found a warning from Continental regarding heat build up from braking may cause the tube to fail. I am installing clinchers on a new Ultegra tubeless rim. I know it would make it more difficult to install the tire with rim tape. What is the consensus on this? Thanks.
Good luck trying to install a tire after adding rim tape. Those Shimano rims are very difficult without tape, the added thickness won't help.
masi61
General Cycling Discussion
7
10-18-21 05:00 PM
MPE
1
05-01-18 02:34 PM
