2*11/2*11 MTB converted to dropbars
Quoted: 142 Post(s)
Liked 34 Times
I got a bargain TREK 6500, 2007 MTB converted to 1*10 drop bars. I like it, it's more fun to ride than I've expected.
Unfortunately it's current 38t front - 32t rear ratio is not good for the hills in my area, so thinking about converting it to 2*10 or 11. Yes l, I am aware of the 1*11-50t options, but I'd like to explore the 2x with something like 38/24t on the front.
So, what are my options for the dropbar shifters that can work with top pull front 2x10 or 2x11 derailleur? Is this possible?
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Di2, or microshift bar ends (they have both road and mtn versions).
Likes For Polaris OBark:
Quoted: 142 Post(s)
Liked 34 Times
I think I figured it out. Two main issues of the road components on mtb are the smaller chainline and bottom pull FDs that in my top pull frame. So this is my plan:
- Clamp on to braze on adapter
- 4mm spacer for the braze on part (to increase the chainline)
- Problem Solvers Cross Clamp & Pulley to change from top pull to bottom pull
- Road FD, braze on
Quoted: 142 Post(s)
Liked 34 Times
I think I have an idea, see my previous post.
Quoted: 4209 Post(s)
Liked 3,875 Times
Are you saying you will shim out the braze on ft der adaptor? With an eccentric shim? Not common but I have one from JTek https://www.jtekengineering.com/wp-co...18/02/6448.jpg. Never used it but a cool item. Andy
AndrewRStewart
AndrewRStewart
Quoted: 1944 Post(s)
Liked 2,164 Times
Food for thought…
Shimano changed the road FD cable pull for 2x setups. I believe it will work with a mtb FD. There was a Salsa Fargo model, a couple years back, that was running a factory setup of Tiagra 4700 shifters to a Deore FD.
Tiagra 4700 is on 10 speed, but I would think it holds true for 105 and Ultegra 11 speed left shifters.
John
John
Likes For 70sSanO:
Quoted: 142 Post(s)
Liked 34 Times
I was thinking about these two:
Liked 3,875 Times
The shims linked to are not for moving the ft der in or out WRT chainline. The move the der forward or change it's angle, relative to the seat tube. Stii cool options for when these changes are wanted. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 142 Post(s)
Liked 34 Times
Oh,, you are right, of course. The 3mm spacer moves the FD forward, not away from the chainline. Any other options for using a road FD with MTB chainlines?
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
When I converted Trek 6500zx I used a Schlumpf drive from Haberstock Mobility.
20201024_120748 by Richard Mozzarella, on Flickr
Efneo is a bit cheaper. By "a bit," I mean: "a lot." But the Efneo is cable shifted & used Shimano mountain pull. So you still would need a mountain pull drop bar shifter. So your cost savings doesn't really get you anywhere.
If I were to do it again, I'd stick with Gevenalle shifters, conventional gears & just accept that the front will be friction with any drop bar conversion.
My most recent bike is a Ritchey Ascent. It is billed as a mountain bike. I used a 1x11 Gevenalle shifters, a Paul Components 31.8 adaptor, a SRAM X9 triple shifter to shift a Sturmey Archer CS-RK3 , (You would need the non-disc brake version.) The cables running on top of the top tube like they are on your Trek 6500zx would make cable routing a breeze.
Ritchey Ascent Breakaway by Richard Mozzarella, on Flickr
Likes For base2:
Quoted: 142 Post(s)
Liked 34 Times
Looks cool. Will take time to digest all the info about the Schlump and Erfneo.
What is that grey thing with a hoze attached to the frame of your Trek?
Quoted: 142 Post(s)
Liked 34 Times
Shiftmate 7 mixes Shimano & Campagnolo triple road shifters with mountain bike front derailleurs
Liked 3,875 Times
I am potato.
Liked 1,629 Times
Car dependency is a tax.
Likes For base2:
Quoted: 142 Post(s)
Liked 34 Times
Liked 3,875 Times
The only model listed on their site is for 28.6 frame post: https://www.jtekengineering.com/?SingleProduct=33. Will it work on 34.9 frame or is there another model?
I got this shim years ago for our tandem to try to improve very small front shifting points. Never got around to installing it and we don't ride the tandem much any ways. Andy
AndrewRStewart
AndrewRStewart
