Technically not a Mechanics Question : WD-40 stain on the floor
Bikes: 1994 Cadex CFR3, 2006 Scott CR1 SL, Rossin aero, Bertrand GB 2000, Spec Allez Pro
Quoted: 134 Post(s)
Liked 68 Times
Was stupid. Degreased my shifters without protecting the ground. Now I have a big stain on the blocks of my driveway. Hot water and dish soap won't do it. What's the next radical step to take?
Sr Member on Sr bikes
Radical?
Looks like you're going to have to WD-40 the whole driveway.
Seriously...pressure sprayer???
Dan
Dan
Really Old Senior Member
Hot water & laundry soap.
Make a near paste & let soak for 15-20 minutes.
Scrub brush.
Scrub brush.
Likes For Bill Kapaun:
Quoted: 6221 Post(s)
Liked 4,829 Times
Don't look at it. Seriously, does anyone ever go to someones house and compare their driveway with another?
It'll probably disappear in time. Probably just about when another stain makes it's mark.
Likes For Iride01:
Quoted: 134 Post(s)
Liked 68 Times
I totally would but it's actually a shared driveway, quite well maintained behind our block, in an historical sector, etc. Can't not see it
Liked 4,829 Times
Well be careful if you to use a pressure washer. Too much pressure too close to the brick or concrete will blast away the finer material that was encouraged by brick makers or cement finishers to come to the top. After I did that to one of the sidewalks leading up to a house I used to have, then I had even more head aches with maintaining the appearance of it. Might be why I just don't care anymore about such.
However a slurry of powdered laundry detergent as someone else mentioned along with just time will let the stuff in WD40 disappear. It was clean WD40? Or was there chain gunk mixed in?
Likes For jonny7:
Junior Samples
What are the blocks made out of?
It's going to sound stupid, but I have a driveway made of pavers that are somewhat variegated in color. I got a few oil drops on them and simply sprayed lighter fluid on the drops and set them afire. The burning fuel pulled the oil out fo the pavers. The pavers were a bit discolored but it blended pretty well with the variegation and eventually went away.
Later on, in a fit of accelerated stupidity, I changed the oil in my motorcycle and took it for a test ride without replacing the oil filler cap. Coming back into the drive, a much greater bit of oil was dribbled onto the pavers. The fire trick didn't work as well, but to Iride01 's point, it faded with time and is now indiscernible.
Quoted: 303 Post(s)
Liked 136 Times
If the already suggested are inadequate, TSP soak and heavy mechanical brushing would be the next step. TSP is a bit
harder to find these days but is a superb degreaser. Since TSP is pretty alkaline (a bit of understatement) dishwashing gloves and eye protection
are advised. It is also a very strong plant fertilizer (ie algal blooms in waterways) hence its relative rarity but should be in big box stores.
https://www.dandochem.us/product_html...hate_(tsp).pdf
Disregard the last paragraph about "exercise performance enhancement" as that applies to milligram level amounts in expensive supplements.
Quoted: 134 Post(s)
Liked 68 Times
I will try Dawn+Brush for starters but I have my doubts, since dish soap barely changed anything. TSP is up next.
Here's the stain, forever immortalized.
Liked 4,829 Times
A month of sun and occasional rain, it'll be gone.
Or have an expert, skilled in putting in pavers remove them and either turn them over if possible or swap them out with leftovers that usually can be found elsewhere in the yard. Or perhaps move them to an obscure corner and swap with the pavers there.
It's not something you want to do yourself unless you do this every day at your job. It'll never match for a first time DIY'r.
Likes For Iride01:
Quoted: 1037 Post(s)
Liked 1,298 Times
I have used laundry detergent to get oil off a driveway, powdered works a little better than liquid, but either works fairly well. That being said, WD-40 will go away fairly quickly on its own. I use it on my reel type lawn mower each time I finish cutting the grass, and always get it on the driveway. In a few days it is gone. Mt drive is blacktop though, old so it is no longer black and you can definitely see the WD-40 stain. Why is probably showing more on your drive, is the dirty grease that came off your components.
Try a laundry detergent before Dawn, it will work much better in my experience. I even keep a box of laundry detergent in the garage for just such an occasion.
Quoted: 283 Post(s)
Liked 262 Times
Nice driveway. Dawn + water + bristle brush. Scrub a bit, cover with 1 inch cat litter. Forget about it for a few days. For that nice drive, maybe try flour vs cat litter. You may need to repeat treatment.
Likes For grizzly59:
SE Wis
Quoted: 2750 Post(s)
Liked 3,406 Times
Quoted: 1062 Post(s)
Liked 665 Times
Flip the blocks upside down. Or, trade them with blocks from a region that's not in plain view.
Also, nice job laying them. Did you do it yourself? I didn't have the courage for anything but plain rectangular bricks.
Quoted: 1309 Post(s)
Liked 1,913 Times
I spilled used mower oil last week on my concrete driveway. Treated it with Simple Green and left it on for the rain to wash off. spots gone a week later. HTH, MH
Likes For jonny7:
It's worth a cheap shot... I've had really good luck with plain club soda on all kinds of stains on floors, carpets and fabrics. Let it soak an hour and wipe it up.
Quoted: 941 Post(s)
Liked 319 Times
Not sure how it would work on blocks, but I've done a number on our garage floor a few times with used motorcycle oil drippings. Black and ugly stains! Picked up some oil absorbent granules. Poured some paint thinner on the area, poured the granules over it, brushed it a bit with an old broom and swept it all up. Worked well. Might take a second round of a bad stain.
Isn't duct tape the opposite of WD-40? That should work...
Otherwise I'm probably in the simple green camp.
Paint thinner/mineral spirits may be able to dilute it and allow it to be brought up or spread out and they would dry in a little while, but I'm not certain how wise it would be to just pour that stuff on the ground.
Otherwise, as it gets warmer if there wasn't too much gunk in it, it should dry on its own. WD-40 is reasonably lightweight and doesnt stick around all that well, unlike other oils.
Quoted: 303 Post(s)
Liked 136 Times
Looked at the Zep stuff, it would work but is possibly an order of magnitude more hazardous than TSP, as it is sodium hydroxide
which for practical purposes is the ultimate alkali. It works just as well on skin as it does on grease dissolving both readily.
Quoted: 1572 Post(s)
Liked 643 Times
1. Wait for a calm day with no rain anticipated. Spray the stain with some kind of commercial degreaser product. Cover the spot with kitty litter. Walk away.
2. The next morning sweep up the kitty litter and the oil spot will come with it.
