Sun Rim M13II
Sun Rim M13II
I have a rear Sun Rim M13II that I bought new in 2005. It's difficult to remember exactly, but I am quite sure its mileage is less than 4k miles. It has a popped spoke. My question is- should I have the spoke replaced on an eighteen year old wheel or should I just buy a new Sun wheel?
Quoted: 5788 Post(s)
Liked 2,580 Times
Depends on a bunch of details.
Are you doing the work?
If paying, how much, vs. how much for a new wheel?
Is the rim OK, ie. little brake crack wear, no stress cracks at spoke holes, no dents, etc?
Comparable quality replacement wheel?
As a rule, I generally replace spokes, and think replacement after the third, or when the interval between spoke breaks becomes too short.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 966 Post(s)
Liked 1,629 Times
Sounds like one of mine! I was really satisfied with my Sun Rim machine built wheel set. I don't remember if it was a Wheel Master or a ChiCom/Ebay purchase. After 8 years slowly spokes on the rear wheel were popping off at the neck. On close examination I found the spokes to be of a diameter closer to 15ga rather then the 14ga I expected. After popping four spokes I decided to just replace all the spokes with 14ga Sapim spokes. It was easy. It has been well worth saving the Sun Rims for sure...
Best supplier I have used recently: https://www.bikehubstore.com/category-s/300.htm
Likes For zandoval:
Liked 2,580 Times
No, I wouldn't be doing the work myself. The price for a new Wheel Master Sun Rim M13ii is $82. The old (2005) Sun Rim M13ii appears to be okay in terms of cracks/dents. My reasoning for buying a new one was just not to have to worry about some other problem developing with the old wheel.
In any case it's a question of how much peace of mind is worth, so start by getting a quote for the repair.
I suspect that you'll be deciding whether it's worth a $50-60 difference, which IMO is too much. But it's not my bike.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Really Old Senior Member
I'd order 3 spokes of the correct length of the side that broke.
297mm for DS 298mm for NDS.
IF you use all 3, then consider a new wheel or buy the remaining spokes and swap one at a time.
Run spokes up to the 1st thread of a new nipple and then take the wheel to the shop for the final tensioning/truing if you aren't comfortable.
Use new nipples. It makes life considerably easier.
I used 14/15 DB on the DS rear and 15/16 DB on the rest. They do fit a bit sloppy in the 2.6mm holes, but I've used them over 10 years.
Likes For Bill Kapaun:
Quoted: 506 Post(s)
Liked 639 Times
Quoted: 4206 Post(s)
Liked 3,870 Times
Where I work that spoke replacement would cost just under $40. About half of the complete replacement wheel. So for those added $42 above a repair one gets unworn bearings, all fresh spokes and often better spoke tension consistency. But if one did replace the complete wheel the old wheel can become the back up wheel and/or the one that you learn how to do this stuff on your own. The value of that education is, IMO, worth far more than the mere $42.
But before deciding I would want to check out the bearing condition. If the cones were pitted I would side on the replacement wheel choice. If this hub is a freehub design then those bearings should also be part of the consideration. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2338 Post(s)
Liked 2,822 Times
Liked 2,822 Times
I have built enough wheels, and have seen spoke length vary between different hubs
Little Beaver out Big Chief
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
a new replacement rim, unlaced, runs 40 to 70 bucks on Ebay... Black rims are about $10 cheaper than Alu finishes.
spokes are under $2 each.
the spoke length change from a low flange hub to a high flange hub is about 1mm.
spokes are sold, pre-cut, in TWO millimeter increments.
how far is it to your nearest spoke cutting equipped shop?
i'll assume that a drive side spoke popped.
you'll need a cassette removal socket to access the broken spoke hole.. $15.
get a couple spokes of each length Bill listed...
Or let a shop deal with it .They can quickly determine the condition of your rim...
your choices.
your choices.
I don't know what hub OP has as all that has been specified was the rim, so I couldn't guess on the difference between your hub and OP's if i had the hub info I would use one of the calculators to get spoke info
His hub would have to deviate considerably from the norm for the lengths I quoted to NOT WORK well.
