Cheap freewheel remover for fixes and bmx bikes?
Quoted: 401 Post(s)
So I'm adding a fixed wheel bike to my stable. As I understand it I'll need the equivalent of FR 6 to tighten and remove the fixed cog and free wheel.
Any suggestions where to buy a cheap one? FR 1.2 cost just 8 from Amazon but this equivalent product for fix is is 16+!
Bikes: 90's Bianchi Premio, Raleigh-framed fixed gear, Trek 3500, Centurion hybrid, Dunelt 3-spd, Trek 800
Quoted: 2167 Post(s)
www.sheldonbrown.com/fixed-conversion.html
Quoted: 401 Post(s)
I'm a little confused. Are you converting a freewheel hub to fixed gear? In that case you need the FR-1 or equivalent to remove the FW. Then, you will need a lock-ring tool to fasten the lock ring after you screw on the track cog. Incidentally, this type of conversion is subject to failure because reverse pedal pressure can unscrew the lock ring! Better to get a hub designed for FG. They have reverse threading for the lock ring.
I'm buying a new track bike. To tighten or replaced the cog won't I need this tool https://www.amazon.com/Park-Tool-Free...=fr-6+parktool
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Yes, a fix track hub with a reverse threaded lockring works better but a cog and lock ring on a freewheel hub works too. They aren't that prone to failure as long as you aren't doing skid stops all the time. But skid stops are a really dumb way of stopping a bike of any kind. They are showy but ineffective.
Stuart Black
Stuart Black
Liked 4,222 Times
Thanks @Habillis.
I'm buying a new track bike. To tighten or replaced the cog won't I need this tool Amazon.com : Park Tool FR-6 Freewheel Remover for BMX Bikes : Bike Hand Tools : Sports & Outdoors
Stuart Black
Stuart Black
You buy the freewheel remover to fit the freewheel you have. they are Not expensive, but not Free either.
you can remove the wheel and bring it to the bike shop and for a buck or so they can use theirs and take your freewheel off for you.
Fixie, Ie Track hubs, you have the LH thread lockring to remove [tool1]
Then you need a 2nd, different tool, a chain-whip to un screw the Cog from the Hub.
Quoted: 401 Post(s)
No. That tool is to remove a single speed freewheel. If you are using a single speed freewheel, your bike is a single speed, not a fixed gear. A fixed gear cog threads onto the hub and spins with the hub but you can't coast. Fixed gear cogs are removed with a chainwhip like this or chainwhip pliers like this
You guys are great!
Thanks @Habillis.
The chain whip feature is for installing or removing the cog. The end with the semicircle and the little prong is for installing / removing the lock ring.
Your link doesn't work. I think you are linking to this page but Brown also has a page titled "Fixed Gear on the Cheap" where he talks about doing exactly what Inpd wants to do.
Aha! You did the right thing. I went the same route after reading Sheldon Brown.
veloshef
Bicycle Mechanics
4
09-01-15 07:39 AM
drjaa
Singlespeed & Fixed Gear
9
10-02-14 08:00 AM
Honkylips
13
11-09-13 07:26 PM
