Advice on Garmin 520 - what do you like/dislike?
I can't believe I'm considering dropping 3-400 for a cycling computer. I've got a 30mi daily commute and have been using Strava on an iPhone - but lately I think I may be suffering from overtraining - I've never really had anyone teach me proper cycling technique or thought about varying my speed/cadence - I've never tried to formulate a training regimen.
I'd like to be able to bike my 30mi/4 days a week commute and still be able to do a ride on the weekend. Right now I can barely make it through the commute - I've never given thought to what my cadence is before ...
I'm wondering if a good cycling computer like the 520 with the speed and cadence sensor can help me better map out a good biking rhythm that will keep me healthier...
I don't think having a 520 with a speed and cadence sensor is going to solve your problem. Maybe a power meter, but that doubles or triples your budget and isn't a sure thing, just a much better bet. Outside of the extremes (like mashing up a steep hill for a long time), cadence isn't what fatigues cyclists.
The 520 will tell you how long to rest after each workout, but you're going to ignore it because you need your bike to commute.
You're probably better off buying sensors for your iPhone. There are some sensors that broadcast over Bluetooth and ANT+ which means they could also be used with a Garmin if you decide to get one down the line, but for your specific goal I don't think the $300 will help you. I'd also recommend a heart rate monitor, it won't be perfect but you can use it as a pacing tool.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Liked 122 Times
Not to talk you out of buying a Garmin, but for what you want to do, just keep what you have and get a Wahoo RFLKT, TICKR and Blue SC. All three combined will be cheaper than buying a Garmin bundle and will do what you need. There are several threads on this forum about the RFLKT and phones as a primary cycling computer that you may want to check out. You can set the RFLKT to display any data field you want to see on the primary screen and set other data fields on other pages. All three of these will connect to your iPhone via Bluetooth and give you the data you need. And since you aren't viewing your phone's screen to see your ride stats, you don't need to worry about your battery going dead on your rides. If you are unfamiliar with the Wahoo products, here's a link that will help you to make a decision on which way to go.
Edit: If at a later point you still decide to go with a Garmin, all you need to purchase is the computer because the TICKR and the Blue SC transmit Bluetooth and Ant+ simultaneously and will work with any of the Garmins.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
I have the Edge 520. I am having issues with it freezing during a ride. Today it happened after two rides where it worked the way it should. I think the problem is the Bluetooth connecting with my phone, a Nexus 6P. The next ride I am turning the Bluetooth off on the 520 to see if that fixes the problem. I have used the 500 and the 510 without any problems. The only feature on the 520 that convinced me to buy it was the Live Track but it doesn't work without the Bluetooth. I would suggest the 510. It has cadence with the sensor and costs less.
I just bought an Edge 520 and I love it. I'm a recreational cyclist riding between 150-250 miles per week. I love all the metrics this device gives you, surely more than I'll ever need. I'm a bit of a gadget nerd and I love all the bells and whistles this device provides. That being said, my previous bike computer is a Cateye cc-2000, solar powered cyclocomputer which I purchased in 1984, and it still works perfectly. It gave me all the data I needed, including cadence, speed, average speed, distance, etc.
While the Edge 520 is nice, it is also pricey, IMHO. You can get all the info you want in this cateye unit for $84 online. It gives you cadence, speed and everything else with the exception of heart rate. For that you'll need to buy a cateye heart rate strap separately.
https://www.amazon.com/Cateye-Strada-...s+with+cadence
The heart rate strap is about $50. Good luck and have fun. These bike computers, for me, are a great motivational tool. I think you'll really like the Edge 520, but the lower cost option will give you most of the data at a third of the cost.
Bikes: Specialized Crux Expert Evo, Felt DA, Surly Crosscheck, Divvy
One of the nice things that you may benefit from with the Garmin (many of the models) is the Cycling Dynamics that Garmin Connect provides. Although, the more useful ones do come from having a power meter.
However what you may want to do is to go get a book on cycling training. Any book by Joel Friel will be pretty good IMHO.
Jon
Jon
Cycling Dynamics are only available if you have Garmin Vector pedals.
Bikes: Trek FX 7.4 + Sirrus Expert Carbon X1
I got the 520 last week and use it. I love it and this is high as I will go.
Alot of features I will not use. I dont do laps. I am not going to use the map. My google map on phone is way better.
And to do the power stuff, you need Vector 2 and that thing costs $1k.
Non omnino gravis
I have absolutely zero complaints about my 520. Excellent battery life, flawless auto-uploads to Connect/Strava, never loses connection to any of my sensors. The BT connection cuts in and out on occasion, but I don't fault the 520 for that-- I fault BT, as it's a horrible stop-gap technology. Live Segments is great. It wasn't even one of my motivations when purchasing, but I find myself using it all the time.
The map screen is small, but it can be quite handy when the road that's supposed to be there isn't there anymore.
I have had my 520 for just over 2 months and I can say that it works flawlessly. I suspect that any problems with it will be the BT. I don't do smartphones at all, so the 520 is worth it for me. If I were dumping all the money that it costs for a smartphone, I would just go with the phone add-ons and forget the Garmin.
Bikes: Canyon Endurace
Liked 936 Times
I love my 520. I did have it "brick" on my once but there is info at the 520 forum on how to reset the unit. I also discovered a problem with it and notified Garmin and they fixed it with an update. It does more than I use and I like the ability to grow into it.
Did you notice the BT connection in and out by looking at the icon? Isnt it only used for text and get weather update and upload to the Garmin connect app? Its only used then.
When I ride my bike, I have two bicycle app on my phone running and I compare it to the 520. Just doing it for fun. There is wide numbers in some of the stats. I still believe in 520 as I have the cadence and speed sensor on it.
I like my 520 so far.
But, I dont have power meter, so anything to do with power metrics I cannot use.
I find no use for Lap. I dont go around riding a circular track.
The map are no use for a low resolution. I am thinking of deleting it to save space. I use Google map on the phone.
I am glad I didnt get the 820 as its the same thing, same screen size, but touch screen for $100 more?
Once you set your setting, you dont do anything else but run it.
Liked 2,207 Times
This is someone else comment below about the 820 ...
Got another 520... tried the 820 briefly. Couldn't stand the touch screen. It really is horrible. In some cases too sensitive, in other cases, very laggy (especially for scrolling). No thanks. And the display "seemed" fuzzier than the 520's. Extra layer for capacitive maybe??
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Liked 29 Times
I have the 500 and hate it. It came with my Giant TCR which I bought 2nd hand. The mapping is crap, as it does not show side roads/adjoining roads and all you have is a 'breadcrumb' single line. When you get to a bend/junction, I often take the wrong turn and have to backtrack.
If you take a wrong turn, you get the message 'off course', but it does not recalulate/redirect you like a car satnav. There are 2 small windows on the top which tell you how far the next junction is, but I cannot read the text as it's too small
I will most probably be buying the Garmin Edge 1000 very soon
Liked 2,207 Times
Sorry you hated the 500 but kind of useless to the OP, 'ya think ?
Unavilable due to riding
Bikes: Nishiki Olympic
Its is relevant.
Liked 2,207 Times
If dim had commented on how there is similarity between the units and what the 2 units had in common, that might have provided some usefulness to the OP. Simply stating then an entirely different unit is disliked, regardless of why, is really of no help.
The screen resolution on the 520 and 820 is bad/low that I think is only good for text and to have a map on there, I say use the phone when you got lost.
I read the original map is so bad that you want to use Open Cycle Map instead.
