Better For Bike To Stay Cold? Or To Warm Up?
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
It is winter in Portland, so temps typically 30-40 F with occasional excursions to 20 F and 50 F, and usually raining or threatening to rain.
My commute bike lives in the unheated garage. At work, I can lock it in the parking garage by the attendants at basically ambient temp, or in the card-access bike room at about 60-65 F.
In theory, is it better for the bike to stay cold all the time, or to alternate between 60 F and 30 F? Or does it not make even a theoretical difference?
I was thinking about moisture in the frame, at the bearing seals, etc.
Quoted: 5930 Post(s)
Liked 2,820 Times
I don't think your temperature differences are enough to worry about either way, though if it's a choice between a warm low humidity place, and a cold damp garage the warm place is better. Often bikes kept damp full time rust faster, and the aluminum can darken or develop what look like white mildew (it's not) looking oxidation damage.
Bikes that face larger temp swings, especially if the warm place is more humid are prone to damage via water condensation inside the frame. This was and is a common problem for year round riders of high quality steel bikes, and why products like Frame Saver are sold.
If you have a garden shed, or a friend who has one, take a look at the metal tools stored there, and see how they're doing.
FB
Chain-L site
FB
Chain-L site
Bikes: Scattante R670
Quoted: 14 Post(s)
Liked 13 Times
Agree. My theory/experience is it's way better to let it warm up and dry off spending most of it's time in the less humid environment. I have a hose rigged up so if it's really salty and gritty from the winter roads I can quickly rinse it off with warm water before bringing it in even if it's below freezing.
Quoted: 2026 Post(s)
Liked 1,096 Times
I do the same with my "rain bike", a steel frame Surly Pacer. It spends it's off-time in a non-heated attached garage which does get cold but not really below freezing even in sub-zero outdoor temperatures which is why I'm such a fan of Frame Saver/ Amsoil HDMP.
Mad bike riding scientist
Quoted: 6269 Post(s)
Liked 4,297 Times
Granted my winters are drier than yours are but in 30+ years of commuting, I've never had a problem going from an unheated garage to a heated building at work to an unheated garage. All of my bikes now are aluminum or titanium so frame corrosion isn't a problem but even back when I was riding steel, I did the same thing without issue.
If you are getting moisture contamination in the bearings than your seals aren't sealing. Get better seals.
Stuart Black
Stuart Black
My thinking on this has been to leave the winter riders in my dry garage. In the northeast the air is generally pretty dry in the winter time. The air in the house is warmer and more humid. Anytime I bring some thing cold in from outside it sweats a little. For a daily winter rider, in and out of the house one or more times a day, I'd worry about moisture collecting in the tubing.
Liked 1,096 Times
That's correct only if you have a humidifier installed in your house. Unhumidified cold outside air has a much lower relative humidity when warmed up inside.
Liked 4,297 Times
Edit: D'oh! I can be such an idiot at times! That's also why bring the bike inside from the cold won't cause condensation in the frame unless inside is humidified. The humidity would go down when you move from cold to warm.
Stuart Black
Stuart Black
Liked 2,820 Times
While the relative humidity drops as the air in a closed chamber is warmed, the absolute humidity is constant. Water vapor doesn't magically disappear when you bring a bike indoors. By the same token relative humidity rises in the frame as the air is cooled, and it can cause condensation the same way it does in your windows.
So simple rule --- if your windows are foggy or frosted, expect condensation and possibly rust issues if you bring your bike from that room to the cold outdoors.
I don't remember ever seeing a condensation problem producing enough water to settle to the BB and damage the bearings, but internal rust in steel frames ridden in the cold is a common, well documented phenomenon.
Of course it isn't universal, and I wouldn't expect it in dry climates, no matter how cold it gets. But here in the northeast and in Europe, we get cold damp winters and frames rusting from the inside out isn't rare at all.
FB
Chain-L site
FB
Chain-L site
Liked 1,096 Times
Which, as I said above, is why I'm a big fan of Frame Saver or it's work-alike products. Between internal condensation and tramp water getting inside from road spray, rain, etc. I see no reason not to protect the internals of a steel frame.
I'd disagree. A house full of people breathing, taking showers, cooking, etc. I'd bet humidity inside is higher than out.
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
but when you bring the cold bike inside, it will condense the humidity of the warm inside air. If you don't believe it, keep your sunglasses on when you come in from a cold day.
Yeah, cuz the frame is cold. But there isn't a lotta air on the inside of the frame with moisture to condense, and as soon as the frame warms up, the water evaporates in the low relative humidity.
Liked 2,820 Times
Yes, when you bring it inside, you'll get condensation on the outside. But the outside is painted and designed to handle weather. Also as the frame comes up to ambient temperature.
Now, let's see what happens when you bring the frame back out. The humidity inside the frame will condense on the tubing as it drops below the dew point. That's the real problem since the inside isn't painted.
FB
Chain-L site
FB
Chain-L site
Bicycle Repair Man !!!
My winter bikes stay cold all winter unless I know they will be parked long enough to completely dry them out.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
My bikes stay in an unheated garage all winter unless I bring one into the basement to work on it. The air is bone dry outdoors all winter in MN and I have no worries about corrosion as long as the bikes are cleaned and lubed. BTW all of my bikes are steel.
Liked 1,096 Times
That same house has outside air being brought in and heated pretty continually. Unless you seal all the doors and windows, the humidity stays quite low.
Liked 2,820 Times
If you have fog or frost on the glass, the outdoor temp is below the dew point of your house, and you'll get condensation inside any closed vessel you bring outside. If there's no fog either the glass is well insulated, or the inside air is dry.
FB
Chain-L site
FB
Chain-L site
We live in a semi arid climate and even winters are drier than most despite the snow... corrosion is not much of any issue if you protect the exposed steel parts.
Quoted: 14 Post(s)
Liked 13 Times
Heck, when I lived in the high desert, I could leave stuff out year round. The paint would rot off from the UV but the underlying iron or steel wouldn't hardly rust. If you handled it, it would corrode in the pattern of your fingerprints. I worked in a manufacturing facility that in the summer was cooled by swamp coolers. The relative humidity of the air as measured at the output of the swamp cooler was 15%! In HI and the Northeast it was a different story entirely.
Liked 4,297 Times
The problem of condensation/rust isn't about when you wam a bicycle, it's what happens when you cool it.
There is a caveat, however. If you heat cold dry air without adding moisture, the air dries. Forced air furnaces really dry out the air in a house. Radiator and hot water systems don't because they don't heat the air in the same manner. But if you use a heater system with that blows heated air through your house, it will be much drier.
Frames rusting out is due to other issues that aren't related to the relative humidity of the air.
The lack of air circulation within the frame would also exacerbate any water infiltration issues. Once the water gets in the frame, it's going to stay there. In winter, the water probably has some salt from road maintenance. The salt water is going to sit there and do its damage without an opportunity for the water and/or water vapor to leave.
Stuart Black
Stuart Black
Quoted: 3352 Post(s)
Liked 1,056 Times
It is better to keep the bike cold. I have Stratus and and a trike. I store the bent in the basement over the winter, and keep the trike in the garage for the rare days that might be warm enough to ride in the rotten winter months. Even temps keeps moisture from forming and causing rust and corrosion.
Liked 2,820 Times
Do you not understand how dew, fog or rain happen? Relative humidity for any sample of air increases as the the temperature drops and and it's ability to carry the water vapor decreases, until the relative humidity reaches 100% and the excess water vapor precipitates.
FB
Chain-L site
FB
Chain-L site
