No pee during long/century rides
I'm 49 years old, male and have been cycling most of my life. The past 3 years I've gotten into more performance oriented road cycling. By that I mean faster and longer rides. I've gone from 215lbs to 188 in the past 2 years. I ride 5 days a week; 33 miles on weekdays, 40 on Saturdays and 50+ on Sundays. I've done 5 centuries this year, including the mountainous 6 Gap ride in Georgia. I ride well and don't suffer. But my concern is, I never, ever have to pee during these rides. Even during the 6 Gap century over 6 mountains. I hydrate well before the rides, drink one bottle of electrolyte mix and one bottle of water between SAG stops or about every 25 miles when unsupported. Other people I ride with pee at almost every stop, but I never even feel the urge. Most of these rides are tempo rides around 20-22mph. I do know my body doesn't have to pee very often, but this seems extreme to me. I'll bring this up with my doctor on Friday when I have an appointment for a different reason. But I thought I'd throw it out here to see if this is highly unusual and if anyone else experiences this. My thinking is that my body either holds a lot more water than I think or it's always on the edge of dehydration and I'm barely keeping it there.
T Rob
T Rob
Liked 3,612 Times
I've read that the act of cycling inhibits the urge to pee.
Also, I think I recall reading that perspiring may affect the amount of fluid in our system which can put less strain on the urinary system.
Personally, I have hyperhidrosis, which means I'll be sweating most of my fluids out through my pores. On all-day rides, I do still pee though, not a lot but at least at every 25 miles. So, about 4 times over 8 hours, which is much much less than what I normally do, which seems like every freakin 15 minutes ...
just another gosling
Liked 2,005 Times
Can you weigh yourself before and immediately after? Bring a scale in the car? If you're losing more than 2%, that's bad. If you're heavier, fine. Personally, I try to drink enough so that I have to pee every 3 hours. Then I know I'm OK. If I don't, I assume I'm dehydrated and increase fluids until I pee. But every one's different. You seem to be fine with what you're doing or you'd notice that things are not OK. Another thing I look at is: do I have moisture on my forearms? If they're dry and hot, I need water. If they're moist, I'm fine. Maybe in really low humidity that sign wouldn't work but it does here.
Thanks for the input!
T Rob
Liked 2,005 Times
Be careful of your electrolytes, too. Heavy sweaters get into trouble with that more easily.
I make perfectly normal pee-stops when off-the-bike, yet - like yourself - do not have the urge while on the bike, even on long rides. My long-ish rides the past couple of years have ranged from between 43-75 miles, and I can recall having to relieve myself only once during a ride, primarily because I misjudged the start time and stood around drinking too much liquid before the ride.
If you do not find yourself feeling ill or cramping, I doubt that you are suffering near-dehydration. Your doctor - whom I hope knows a bit about the body's response to endurance exercise - should be able to put your concerns at ease.
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Liked 86 Times
I've actually been told that the more dehydrated you are, the more urge you have to pee. It may just be that your fellow cyclists don't drink enough water during their rides while you do.
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
Drink when you're thirsty. If you're not thirsty, don't drink. If that means you pee a lot or a little, so be it. Don't try to over-hydrate yourself. Yes, you'll make yourself pee, but you could very easily make yourself sick (many marathoners do this to themselves and some have died).
Coming up lighter post-ride is no big deal. You should make no effort to drink enough to replace all of your sweat on a 4-6 hour ride. If you're doing very long races (i.e. ultra's), then there is a certain percentage of weight loss that you should probably stay above (drinking to thirst will address this), but for a century it's really no big deal.
Gotta disagree with the "drink when you are thirsty" advice - I have frequently ridden past the point when I should have taken a drink, whether I was just too intent on riding performance, or stomach was a little resistant to having anything else put into it, I will at times have to remind myself to drink. I like the concept of pre-hydration.
Liked 2,005 Times
https://www.irunfar.com/2012/08/water...marathons.html
https://www.outsideonline.com/blog/ou...ce-sports.html
I know my body and thirst needs a little better than the folks who over-hydrate; I do not sit and guzzle all of the time while riding; on the other hand, I do not always wait until I feel thirsty to take a drink. In the middle of a humid Ozarks summer, it is just too dangerous to let yourself go too long without hydrating, and the reason I have to sometimes remind myself to drink is that - during a grueling ride in higher-humidity full-sunshine summer heat, the stomach is not always welcoming to anything you put into it.
The OP is concerned that he might not be hydrating enough because he does not feel the need to urinate, and I postulate that - as long as he is not ending his rides feeling ill, and since he is obviously hydrating during the ride - he most likely does not have to worry about dehydration. Any hint that I am encouraging over-hydration by suggesting pre-hydration during high-temperature cycling is a silly mis-reading of my original statement. It seems to me that- at least among cyclists with whom I am acquainted - over hydration is very rare, and is at the extreme opposite end of the worry spectrum.
kiltedcelt
15
06-20-11 11:53 AM
