1961-62 Allegro Special Pista
Bikes: Lugged Steel Single Speed Beater
Quoted: 59 Post(s)
Liked 215 Times
So the other day, randomly scrolling through the local Buy/Sell app, I stumbled upon this beautiful bike. The components we’re unrecognizable from the pictures, I just noticed it was a lugged track frame & knew I had to have it knowing how uncommon they are. It was a pleasant surprise to arrive and see all the components up close!
Anyway, being the oldest bike I’ve ever had (older than my parents!) and unfamiliar with Allegro, I did extensive research. I’ve read every Allegro thread on this forum! Fortunately, I love to read/research as much as building and riding bikes so it worked out.
The owner told me a wonderful story about his father riding this bike at the Velodrome here in SoCal in the late 60’s-70’s and the Kemps.
Apparently at some point in the 80’s the bike was attached to an indoor trainer and then sat in the garage for 30+ years until I showed up to buy it with the trainer still attached.
According to the Allegro database, the serial number on the seat tube puts it’s manufacture date somewhere between 1961-1962.
It also appears to be completely original, all components except for the missing front wheel.
The plan is lots of cleaning & polishing, and get her back as close as possible to her former glory.
I have a pair of clean period-correct high flange Campy Record track wheels I’m picking up locally this week.Reynolds 531
BB grease-port on shell
Original Hand-painted pin-striping
Downtube Lettering is painted not decals
-Campagnolo fork dropouts
-Campagnolo frame dropouts
-Campagnolo Record seat post
-Campagnolo Pista 165mm crank (151 bcd)
-Campagnolo crank bolts/dust caps
-Campagnolo 46T Chainring
-Campagnolo Chainring bolts
-Campagnolo Record Pedals
-Campagnolo 16T Track Cog
-Campagnolo Axle Nuts
-Campagnolo BB assembly
-Campagnolo Headset
-Cinelli or 3T Stem (?)
-Titan (?) handlebars
-Bar Tape(?)
-Bar Ends(?)
-Brampton France track chain
-Christophe Toe Clips
-Alfredo Binda Leather Toe Straps
-Brooks Professional saddle
-Campagnolo Headset
-Bar Tape(?)
-Bar Ends(?)
Likes For Yune_Garage:
Quoted: 5892 Post(s)
Liked 3,479 Times
That bike is beautiful and that is a heck of a score. The saddle is cracked and likely gone so you may need a replacement. Your plans sound good. I'd use the lightest possible cleaning agents for the paint.
Now that you have one bike older than your parents, what is your plans for a second C&V bike?
Likes For RustyJames:
Quoted: 823 Post(s)
Liked 1,396 Times
Added to the Allegro database!
Truly STUNNING example! Bocama 14 type II lugs, too! This may be the single best preserved Allegro I can recall seeing from this era! This is a truly lovely machine, and quite a score! Thank you for sharing it with us!
Are there any date codes on the rear hub locknuts?
Likes For rustystrings61:
small ring
Quoted: 439 Post(s)
Liked 935 Times
I agree with rustystrings, such wonderful condition. Polar opposite of mine.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Quoted: 3827 Post(s)
Liked 3,377 Times
Likes For juvela:
Quoted: 59 Post(s)
Liked 215 Times
I have an early 80’s Centurion (older than me) that I’ve stripped down completely that will be getting work done. Nothing fancy but I always liked the two-tone Centurions so it should be fun. 👍🏼
Quoted: 59 Post(s)
Liked 215 Times
I haven’t had the chance. I did read all your Allegro comments in previous threads. Learned a bunch! I’ll take a look when I get home this afternoon and report back.
Quoted: 59 Post(s)
Liked 215 Times
I’m still trying to identify the stem and bars.
it looked identical to a Cinelli of that era however it’s missing the stamping and instead has a ‘Made In Italy’ decal. I’ve managed to loosen the stem, so it can be moved around but it won’t pull out from the head tube so I can see if there is any designation markings or dates.
Im guessing it’s not a quill type and its the expanding type (forget the proper name).
Side note: All the bearings, rear hub, BB, and headset were super smooth. Even the Campy pedals spun smoothly and the grease was still redish and tacky.
Quoted: 59 Post(s)
Liked 215 Times
The Pista cranks are minty considering they're 55+ years old. It’s amazing really.
Unfortunately, there’s a fine scratch over the Campy logo on the drive-side arm and there are areas where the leather toe straps buffed and polished the crank arms to a mirror finish Im guessing from use, but no deep scoring or nicks anywhere.
Even the chainring teeth!
They’re mint, with no wear or chain indentation.
Quoted: 59 Post(s)
Liked 215 Times
The new WRX is very nice! Im still getting used to the fender arches (Has a more Rally look) but I almost got one back when I was deciding to get an Abarth or not. 👍🏼
Bikes: Bakers dozen is the limit!
Quoted: 89 Post(s)
Liked 449 Times
Likes For unworthy1:
Liked 3,377 Times
as you are sure to have learned from your reading the frame's lug pattern is BOCAMA 14/II
the bottom bracket shell is Georg Fischer
possible this latter may exhibit a "GF" marking on the underside or a "+GF+" marking
the crown may be a Fischer model was well, do not recognise it
if it is it may be marked on the underside
the cycle's spokes are by Wippermann of Germany -
might be interesting to check to see if the manufacturer fitted the machine with a Wippermann drive chain as well
the inner faces of the rear hub's axle nuts will give a date confirming marking -
beautiful job you are doing there with a beautiful machine!
Quoted: 59 Post(s)
Liked 215 Times
I noticed the chain it had on it was stamped ‘Brampton France’
A little stiff but not in bad shape considering the age!
I’ll definitely take a look at the axle cones for dates as well.
Btw the BB shell does have some markings but I’m unable to identify it due to wear but I’ll snap a picture to be sure.
