28 tire on a 23 aero rim?
I have 23mm wide aero wheels (Bontrager Aeolus Comp 5) that came from the factory with 25mm tires. If I put 28mm tubless on them will I negate the aero-ness of them?
Thanks for your thoughts!
Quoted: 878 Post(s)
Liked 726 Times
Depends on how close to the pointy-end you are speed-wise. You'll still get benefits from having deeper section rims, even if you were to use much wider knobby gravel tires. But if you need every marginal gain to win an ITT or town sign sprint, then sure, you'd possibly throw a few watts away at 40+ kph, since most road wheels are optimized for 25mm tires.
You might gain some back in decreased rolling resistance if you ride over less than perfect asphalt, so that's another trade-off to consider.
Likes For surak:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Don't overthink it.
Likes For cxwrench:
thanks for the thoughts! it was more of a theoretical question as I am slow AF and just wanted to make sure I didn't get laughed out of the coffee shop if I did it...
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
If not racing, who cares.
Depending on tire, overinflating even a matched tire can be 1 to 8 watts. Just the front wheel. Not including the rear.
I can imagine a 28 on a 23 costing at least 8.
Round to 10w and I figure that is likely 4 to 5% of the average BF member’s true hour ftp’s.
https://silca.cc/blogs/silca/part-5-...d-aerodynamics
Likes For burnthesheep:
should be more popular
My wheels are 27mm outer 19.5 inner and Trek delivers them with 25mm.
I threw away the Bontrager tyres and put 28mm GP5ks on to test, but they bulge out.
I put 25mm GP5ks on and they sit much happier now, with the rim marginally visible from the front profile.
I could not sense a comfort difference at 70-80PSI with tubes.
So I take the aero benefit and keep the 28 for the rear only.
Likes For yaw:
Quoted: 2333 Post(s)
Liked 2,097 Times
Totally depends on your speed. I unintentionally put a too wide GP5000 tire onto my narrow, aero front wheel. At 30-31 mph, it was cost me close to 15 watts measured. That is my TT speed (on a recumbent) At 20-24 mph, a 28 mm tire on a 23 mm rim might cost 2-4 watts as a guess, I have never measured it.
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
You would technically lose some aero, but the reduced RR of the 28mm tires may compensate. To be calculated!
Quoted: 6195 Post(s)
Liked 4,810 Times
dear god… there’s a sock height convention? *googles ‘correct bicycling sock height’*
someone should tell me how high to wear my socks or I’ll have to start a new thread!
it’s almost like if you’re out of a sport for 20 years things change when you’re away….
Quoted: 9653 Post(s)
Liked 6,365 Times
Sock height only matters if you shave your legs. And, neither matter if you wave.
Liked 2,974 Times
I'd say the slightly wider tire is going to net more advantages in the long run.
more likely to happen if your chain is not using that current month's egyptian wax.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Liked 6,365 Times
Probably the wrong socks.
Likes For Mojo31:
