Sweaty Bag strap question
Ok, I am a total noob to commuting. One issue I have is that the shoulder strap for my Timbuk2 bag is soaked through with sweat by the time I get there. Even the strap pad. Does any one have any ideas to remedy this. A pannier isn't really an option because this is my only bike and is used for much more than commuting. (i'm not showing up to the trails with a rack )
Anyway, this has to be a problem that other commuters have encountered so I thought I'd ask.
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Really only two ways to avoid a sweat soaked strap- 1) don't use it in excessive heat or 2) don't use it all. You can choose to live with it or reconsider your cargo management solution. You don't need a rack and pannier(s) to get load off of your back- Carradice comes to mind.
Community guidelines
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Quoted: 7 Post(s)
Liked 8 Times
Pletscher makes a quick release rack that can be removed in a few seconds. good for commuting and then quick remove for the trail rides on the weekends and evenings.
https://www.youtube.com/watch?v=KXdzrd6Ct1U
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
^^That looks interesting, but since the vid was taken at Interbike in '08, why hasn't that rack gotten more buzz here?
Bikes: Raleigh Glacier MTB/Commuter. Cannondale CAAD5, Windsor Timeline fixed gear
A rack is (normally) held on by 4 bolts...I can remove/install my rack about as quick as you can check the air pressure in your tires. I say go for the rack, and spend the 2 minutes removing it before you hit the trail.
I just ditched a backpack in favor of a rack and detachable trunk bag for my 29er. I'll never go back. I would rather spend five minutes, if I took my time, pulling off the rack than deal with a sweaty backpack every day. I wouldn't think twice about using the bag on a trail with extra water/food/tools in there.
Quoted: 52 Post(s)
Liked 17 Times
I believe timbuktu bags are washable. The main strap wasn't removable on my bag but maybe yours is and you wouldn't have to wash the whole thing. The pad could certainly be washed on its own.
It's really no different than helmet straps or pads. In fact it's a good idea to at least rinse out the pads now and then or you may find the salt from your sweat draining into your eyes during the next downpour.
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
I also have a multi-use bike, and have a "road" setup with rack (fenders if necessary) and 50mm slicks, then I throw the 2.4 ardents on for trail duty. The rack is 4 hex bolts - literally a minute or two to install/remove. If your bike has the requisite mounting eyelets, it is easy as pie. If not, a seatpost/quick release rack might be an option.
incazzare.
I use a Carradice saddlebag.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Lots of seat post beam racks from many brands, out there ..
look in shops, test fit them,
some have quicker-release mounts ,
but bolts are not locking things on, either..
