Bianchi Impulso first ride, rear Veloce derailleur really messed up!
DAMMIT!
First ride today after assembling my new Bianchi Impulso with a Campagnolo Veloce groupset..amazing.
LOVE THE BIKE, but only managed 20 minutes before the dropout mounting for the rear derailleur snapped off on a very slow incline where I shifted all the way up on the biggest cog on the rear, BANG! and the whole rear derailleur followed the cog up clockwise before stopping at 12 o'clock, twisting a couple of chain rings, chipping the paint on the chainstay and damaging a spoke.
As this is out of the box I'm trying to get it on warranty, but am worrying about the Veloce now. Should I upgrade the rear mech to a Centaur which seems to be the most expensive 10speed from Campy ?
Am I expected to do a full gear adjustment when assembling the bike, i.e. is it my fault ?? Surely not.
I am no expert but if you assembled the bike it should be your problem to adjust derrailleur's. Doubt you will get warranty but consider yourself lucky you did not get hurt.
Quoted: 1186 Post(s)
Liked 289 Times
In case your bike didn't include instructions, here is the relevant section from Campy:
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
The derailleur was just doing what it was told.
If you hit a baseball through a window, do you blame the ball ?
https://www.parktool.com/blog/repair-...nts-derailleur
Looks like you just need a new hanger & derailleur. Possibly a chain if there are bent links.
There is nothing wrong with veloce. 100% the fault of the mechanic.
i would also recommend mounting your bottle cages to the frame and not the seatpost. Those styles of bottle holders don't have a great reputation for security. I would only use one when you run out of proper mounts.
Yes. Yes Since you say you assembled it. If it came assembled from a bike shop, then they would be at fault.
Park Tool Co. » ParkTool Blog » Rear Derailler Adjustments (derailleur)
okei.
Well... it is the first bike I got from a bike shop - not physically collected at the shop.
Out of the box everything was assembled except for seat/seatpost, front wheel and bar tape.
SO.. Not being too naive, I thought that as everything on the rear of the bike was already assembled, that I could at least do a couple of test rides before maybe doing some fine tuning, not that the rear derailleur was so badly factory-setup it would self destruct ;-). Everything was working as it should except for some minor clicky-slightly off perfect sounds on the extremes of front / rear chain angle.
I was plainly naive.?
And as for the seat cage; I use a fairly small bottle and prefer the look/distance. Obviously the carbon cage was extremely important weight-wise...
Super Moderator
Liked 927 Times
okei.
Out of the box everything was assembled except for seat/seatpost, front wheel and bar tape.SO.. Not being too naive, I thought that as everything on the rear of the bike was already assembled, that I could at least do a couple of test rides before maybe doing some fine tuning, not that the rear derailleur was so badly factory-setup it would self destruct ;-). Everything was working as it should except for some minor clicky-slightly off perfect sounds on the extremes of front / rear chain angle.
Even if it was perfect when they shipped it, it could have got banged up a bit in transit. Now you know to check first, ride second.
Quoted: 86 Post(s)
i've always maintained that a smart guy that has made a few embarrassing, dangerous, egregious and most of all costly errors stands the best chance of really reaching their potential. if so, this may be this best the thing that could have happened! too bad no sympathy here, i guess.
OTOH, if one WANTS sympathy, understanding and compassion, and who doesn't? get a lawyer, that's what they are, in part, paid for. to spin born, they are! *Yoda*
i have had cause in the past to retain legal council once and before i went in to see them, i felt pretty bad, and down on myself for what i had thought i had done. after the meeting, i came out convinced i was an innocent dupe and everybody and their brother were at fault but me. spinners i tell you, spinners extraordinaire.
Texas Tornado
Bikes: '14 Specialized Roubaix SL 4 Full Ultegra 6800
1) I call the "plastic thing" a "dork disk".
2) I'm no expert bike mech but how the hell did you do this? I'm thinking you didn't tighten the skewer and when it went to wobbling it dominoed.
Liked 289 Times
No, it's simply the limit screw on the rear derailleur isn't adjusted properly. There is a very fine line between the correct adjustment and letting the rear derailleur touch (or in this case jam) the rear wheel spokes. Mines rubbing at the moment so I just don't shift into the biggest cog, and if I do I'm just very careful.
Super Moderator
Liked 927 Times
Derailleur into spokes. Improper low limit screw adjustment.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Since you will need to order a derailleur and hanger, may as well get a chain. Your chain has experienced some unusual stress, no way to know if it's damaged.
Quoted: 686 Post(s)
Liked 5 Times
For what its worth, the rear derailleur could have been fine when the bike was shipped, but could have also been bumped during shipping, or even pulling it out of the box.
Be happy you had the dork disk on and you weren't going so fast that the derailleur swung around and nailed the seat stay, cracking it in half. Been there, done that.
On the upside, learning the hardway means you never make the same mistake again.
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
Either the chain was/is too short, the derailleur hanger was/is bent, or the derailleur was/is improperly adjusted.
In the future, have a professional mechanic assemble your bikes, or at least have one inspect your work. Your bike is broken because you made a mistake or 2 in assembly.
Liked 289 Times
In that case it's a little different. If the shop put the bike together they should have adjusted the derailleur properly. I would expect the shop to take care of you. This is likely the reason on-line bike sales have never taken off.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Guess you learned the hard way, you never ride a bike straight out of the box. First to the stand. Best way to adjust the rear derailleur inboard and outboard stops and indexing initially is with no chain. So take the chain off. A lot of Bianchi bikes with Campy come with KMC chain and Missing link. Pinch the link remove the chain and set the rear derailleur. Also don't forget the rack screw that adjusts cage height for best chain wrap and clearance to the big cogs. Truth is the front derailleur always takes more attention for flawless shifting. Also just changing the way the wheel axle sits in the rear dropout affects shifting.
As mentioned...we all learn by our mistakes. Yes some are more costly than others. But it is the guy that is willing to make the mistakes that becomes most proficient. Btw, Veloce derailleurs are fine and very little difference with Centaur derailleurs FWIW.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,016 Times
I did something similar once. The cause was the rear derailleur touching the spokes.
Liked 3,016 Times
You are right. Consider my hairs split. The derailleur was not properly adjusted. But just to elaborate, the adjustments seemed OK when shifting up and down on the repair stand. But riding at the bottom of a roller, downshifting quickly from a small cog to the largest (and in fact, overshooting the intended gear by not counting clicks on the brifter), the derailleur moved too far.
