How big tire for Specialized Sequoia?
Dirt Bomb
Quoted: 5471 Post(s)
Liked 288 Times
Looks like about 1/4" clearance on both sides. It has a 25 tire on it. Think I can go with a 35?
I mostly ride it on pavement but would like to take it on the Katy Trail. The Katy is flat with crushed gravel.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
What year is that frame? Because it is definitely not the more recent disc brake equipped Seqouia (MYs 17-19).
Hard to tell by the eyeball, perhaps someone who has the same bike can offer up their exerience. What I do know is that you can get by just fine on the Katy trail with 32s. I used to ride my Diverge Mk1 with 30/32 slicks (Tubeless, Specialized Roubaix Pro) on that trail when I was working in STL. I think I've ridden about 100mi total of it.
Dirt Bomb
Liked 288 Times
It's pre-'12. Just wondering if anyone knew what size tires it could take. I'll measure as best I can and go from there.
I don't do a lot of road biking. Figure if I set it up for the Katy I'll get more use out of it. It's my least-used bike. I can ride to the Katy from my house.
Sunshine
Quoted: 10965 Post(s)
Liked 7,491 Times
What is happening with that black cable housing thats twist tied in the pic?
High Plains Luddite
^ Wild guess: bike computer cable?
Mystery #2: the black zip tie that appears above the pedal on the drive side.
Quoted: 532 Post(s)
Liked 621 Times
As I said, though, the parts of the Katy trail I've ridden were easily ridden on a 32mm tire, with a slick tread. Which I suspect, if it fits, will be the max tire you could fit in that bike. In the "Before Gravelbikes" time, even a bike like yours often had limited clearance, because back then it was typically only MTBs running big volume.
Randomhead
Liked 3,699 Times
I rode 30mm tires for a year on rough gravel and it worked okay-ish if you ignore all the flats. It would have worked great on crushed gravel.
Quoted: 83 Post(s)
Liked 64 Times
Rode the Katy in 2019, still officially closed after major floods. Some sections were still sandy but 32 Paselas were no problem. Clearance beats width when it's muddy.
Dirt Bomb
Liked 288 Times
Funny how stuff like that shows up on a picture.
Like I said, this is my least used bike. I'll spruce it up a bit. Where I live the shoulders have glass and the rest is gravel, so I usually ride my Rockhopper or my hybrid with Schwalbe Marathons.
Quoted: 1461 Post(s)
Liked 1,486 Times
Hard to tell what you can fit in there, but I have ridden crushed gravel/limestone trails for years on 28mm tires and it's fine.
I'd prefer to be on 32mm+, but that statement also applies to paved roads.
Dirt Bomb
Liked 288 Times
Did some more measuring and the total width clearance is 38mm. Going to try some 32's and hope they work. Seems 35's would be pushing it.
Dirt Bomb
Liked 288 Times
I ended up putting some Michelin Protek Cross 32's on the Sequoia and they just barely fit. In fact, the little nubs rubbed on the front fork for the first ride or so until they got knocked off. But I'm totally happy with the ride. So far they've worked good on bumpy sidewalks and patches of gravel - some of it pretty loose. This was my least used bike but now it will get more use. It should be pretty fast on the Katy Trail.
Likes For sknhgy:
