Give Me The Skinny..................on
Give me the Skinny on Chamois Cream.
Without getting into Too graphic detail, where do you all spread this stuff?
I`m not asking which is the best cream, just where do you all apply it?
The jars are So Small, I`m just thinking if you spread it Everywhere, you`d run out in a week?
I ride two bikes.
A classic Schwinn Passage road/touring bike, and a Trek Verve III.
On my Trek , I`m fine.
On my Schwinn Passage (1985) everything is rubbing and on fire!
I ride two bikes.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
It goes in the Chamois Coffee, right?
Likes For livedarklions:
Quoted: 6196 Post(s)
Liked 4,810 Times
I don't use it. Never needed it.
If you wear cotton underwear under your bibs or shorts while you ride, you will need a lot of it. Also seems to help if you keep hair down there short and groomed! <grin>
FYI, on the cheap Chicago Schwinn's I had from the 70's all the way up to and including the Varsity, their saddles were crap. Don't know if your Passage is one of those, but that saddle in the pic sure gives me some painful memories.
Quoted: 3952 Post(s)
Liked 7,299 Times
Likes For tomato coupe:
Quoted: 338 Post(s)
Liked 408 Times
I sometimes use it, especially before triathlon (because of salt and everything) or the running bit (again, salt) or if I didn't do a long ride in a while, am going on one, and feel like I could use it just in case. You just use a bit - a dip - and rub a thin layer where the saddle and your bum touches. Don't slather it all around.
If one bike I'm fine and the other is a torture device, probably different saddles?
Likes For Branko D:
Quoted: 6972 Post(s)
Liked 10,968 Times
Likes For Koyote:
Quoted: 14 Post(s)
Liked 37 Times
Well, if you don't ride with shorts with Chamois, why would you want to use Chamois cream? I stopped using it with modern day shorts and see no need to. However, if I did use it I'd probably apply just like I did with Chamois shorts.
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
Is it really too difficult to do a quick Google search?
how to apply chamois cream shorts
Likes For KJ43:
Chamois Cream
I use chamois cream with modern shorts. I apply to my skin areas that are friction points, and to the liner itself
although they are synthetic these days. I haven’t tried riding without the cream, so maybe I am just wasting my money. I ride 100-150 miles per week in summer, most rides <50 miles. A large tube (8oz?) lasts me about a month in summer, maybe 20 rides? I’d buy a tube or jar and try it out. Some creams come in 2oz packets so maybe buy a sample to try out. Bill
Likes For BillRS22:
Bikes: Cannondale Topstone, Trek Dual Sport, State Bicycle Klunker
Quoted: 87 Post(s)
Liked 132 Times
Likes For Bogey Speedwell:
Liked 7,299 Times
Likes For Pratt:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I like Body Glide's Bike Glide and I just apply it to my genital area. I do suffer from chafing so it does help out and the stick based nature means your hands stay clean.
Likes For veganbikes:
Quoted: 128 Post(s)
Liked 98 Times
Clark W. Griswold
Liked 3,994 Times
Proper shorts or bibs are meant to be worn sans undies those would be your undies but if you are riding just in cotton you will have issues. Cotton holds on to moisture so it is poor for a next to skin layer just about always but especially in high output activities and also quite bad in cold weather. ExOfficio Give N Go undies are the best I have worn and generally what I am commuting in these days for long rides I still wear bib shorts but for short commutes the ExOs are excellent. Moisture wicking is always the key. The longer that moisture stays next to your skin the more likely you will get a rash
Likes For bikehoco:
Quoted: 1591 Post(s)
Liked 1,020 Times
That's the best way. If you don't already have a place in mind where you need it, you may not need it. It reduces chafing in the crotch area but if you aren't having any discomfort you don't need it. If you are, put it on the around the area that gets sore.
Quoted: 1279 Post(s)
Liked 1,393 Times
for a ride over 40 miles i put a relatively small amount on the place where the top of the inside thigh meets the part which isn't the leg, on each side. that's the only place i've ever had a little irritation, probably from the edge of saddles which aren't quite exactly the right shape. i do not apply it to my butt or anywhere "else."
Likes For mschwett:
Tragically Ignorant
Liked 9,098 Times
Next up: where do you apply underarm deodorant?
Tragically Ignorant
Liked 9,098 Times
Quoted: 242 Post(s)
Liked 454 Times
I prefer Noxema...as Chris Horner says, it feels tingly.
I apply it where my inner thighs meet the torso.
Generally you apply it to the chamois itself along the edges where the chamois joins the shorts at the sides. It's to prevent chafing.
If you prefer not to wear cycling shorts then you are on your own to find a method that works.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I use Chamois Butt'r. It comes in a large tube that lasts quite a while. You can apply it to your skin or to the chamois itself. I limit the distribution to the areas where chaffing might be an issue:
Likes For Rolla:
