Do all BSA 68 bottom brackets have the same thread length?
Hello
I would like to replace my BBR60 24mm Ultegra bottom bracket (BSA 68) with a Rotor 30mm BSA 68mm so that I can install Rotor InPower cranks.
From the online shop I have the visual impression that the BSA thread on the Rotor BB is slightly longer than on the BBR60. Are all BSA threads the same depth/length or could it be that the Rotor BB would not fit?
I haven‘t visually checked how long the thread in my frame is…
Thanks!
Dominic
Thanks!
Dominic
Quoted: 499 Post(s)
Liked 434 Times
If the thread isn't wide enough you can probably have it tapped some more. I've never seen any mention of how wide the thread should be, never even thought about it, I've tapped and fitted quite a few bottom brackets.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I don't know of a standard for depth of threading in the shell. If your frame is an older steel one, it may not be threaded as deeply as a newer frame. The reason is that the steel cups of old-school bottom brackets didn't need to engage very many threads in the shell to get a good purchase. I've noticed that newer cartridge bottom brackets with aluminum cups sometimes have more threads, I think to spread out the load on the softer material.
If your Rotor BB cups can't thread all the way into the frame, the right thing to do is to have the bottom bracket shell tapped deeper. Alternately, I have ground off some of the leading threads on modern BB cups so they can thread all the way in.
Quoted: 4408 Post(s)
Liked 1,562 Times
It shouldn't be an issue.
Quoted: 5788 Post(s)
Liked 2,580 Times
Thread length isn't the issue because there's thread relief beyond the thread.
Since weight is always a consideration, BB aren't made with the same wall thickness all the way across. Obviously the outer half inch or so on each side has an ID based on the thread, but the middle can and does have a larger ID, typically larger than the thread OD.
Quoted: 714 Post(s)
Liked 800 Times
I'll second what FB said. I build bicycle frames and every bottom bracket I have used has a relief in the center of the bottom bracket that would allow you to thread something in past the end of the threaded portion.
Quoted: 499 Post(s)
Liked 434 Times
You don't need much thread to hold a monobloc BB in place, which is why they can be made of plastic, or just fixed with a couple of lock rings and no thread at all engaging with the BB shell.
Liked 1,562 Times
I disagree. A CCB BB axle exerts significant axial stress on the cups, trying to push them out, while a cassette BB exerts mostly radial forces on the shell.
We can all pedal our pet engineering theories until the cows come home, but the answer to the OPs question is "It doesn't matter." Anything else is just really bad advice.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
In any case, if you encounter a shell that will not allow your cup or cartridge to fully seat, you can use bottom bracket taps to extend the threads.
N.B. I think the "unknown" shell above is probably Henry James, and does not have the relieved section.
Likes For JohnDThompson:
Quoted: 499 Post(s)
Liked 434 Times
I wasn't replying to the OP nor offering advice (that was in my earlier post in this thread).
Quoted: 581 Post(s)
Liked 921 Times
I have had older frames where the threads were too short to accommodate the cups on a Shimano cartridge bottom bracket. I used a dremel to grind away the protruding ends of the shoddily mitered tubes that protruded into the BB shell, then had a shop run the taps through to extend the threads a bit. For most modern-ish frames I doubt the protruding tube ends will be an issue, but the taps will likely be the correct solution.
Likes For ClydeClydeson:
Old fart
Liked 3,400 Times
Quoted: 581 Post(s)
Liked 921 Times
JohnDThompson Both I think
Old fart
Liked 3,400 Times
I believe I've also seen threadless BBs offered by a third manufacturer within the past few months (Olympia? Olympic?), but I can't say with certainty whether they're still available today.
Old fart
Liked 3,400 Times
FWIW: Velo-Orange no longer offers a threadless cartridge bottom bracket on their website. However, YST and Sunlight still offer them.
I knew about the Mavic threadless; not sure I'd run across references to the Edco version. Any idea if either of those are still made? I ask because I occasionally search for threadless BBs (personal interest, and in case of for possible future need). I don't remember seeing the Mavic version come up except as either used or vintage NOS. Would be nice to have other higher-quality options if needed.
Old fart
Liked 3,400 Times
The Edco used eccentric cups to lock the cartridge in place.
Appreciate the info. Thanks.
