self fusing silicone tape for finishing bar tape
Quoted: 1562 Post(s)
Liked 1,734 Times
I tried using plumbing silicone tape as finishing tape. It works well but it’s not really clear. It’s kind of milky looking:
I know they also sell bike specific silicone finishing tape that is more expensive. But is it really clear or is it still milky like this? I want clear tape.
Likes For icemilkcoffee:
Quoted: 431 Post(s)
Liked 460 Times
I use silicone tape but in black. It works well but since it's so stretchy, I found it impossible to get the edges to overlap neatly while pulling (hope that made sense).
Likes For tFUnK:
Quoted: 1109 Post(s)
Liked 1,200 Times
I like that. I'll have to get a roll and try it. You know, you don't have to overlap the finishing tape over the handlebar. You can wrap it so it just barely goes over the edge of the bar tape, or even just even with the edge, and holds just fine, and (IMHO of course) just looks tidier.
Liked 1,734 Times
Liked 2,979 Times
this is what I'd try if I wanted to have it 'clear"
https://www.3m.com/3M/en_US/p/d/b40066725/
-Oh Hey!
-Oh Hey!
Sunshine
Quoted: 10965 Post(s)
Liked 7,491 Times
Do 2 wraps with it pulled tight that are as wide as the tape is naturally wide. Then ease off the pressure and wrap half a turn with the tape lacking tension. The untensioned tape will be the same width and it will lay flat.
Likes For mstateglfr:
Liked 1,734 Times
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I have been using black silicone tape for years now and love it. It comes in other colors as well (red, white, yellow, blue). I make the overlap wide enough that the end fits over it all, and I cut it so it finishes on the bottom and out of view anyway.
It's like riding a bicycle
Likes For urbanknight:
Liked 2,979 Times
I'm not sure what you're referring to, but based on what I've used for automotive purposes, the aforementioned film is like a vinyl wrap.. that's a poor way of explaining it, but I didnt want to make it sound like it's a packing tape b/c it doesnt leave behind a glue when removed.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
If you want colourless then try shrink wrap.
Here's the one I used: https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
Ran a heat gun over it and it finished perfectly, still clear after 2 years.
Probably easier if you wrap top to bottom like I do,
but in theory you could put a bit of shrink wrap on the tubes before wrapping bottom to top.
Wrapping top to bottom it really holds the ends well and shrinks round the ends so the plug fits in evenly.
Likes For Aardwolf:
Liked 1,734 Times
Quoted: 332 Post(s)
Liked 742 Times
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I haven't found one that doesn't work. The plumbers repair tape at two different hardware stores, and 3 different brands from the rain forest. They all seem to work about the same with the thickness being the main difference, and that might be personal preference. Super thin is a little tricky to make sure it doesn't fold over on itself.
Likes For Aardwolf:
Bikes: a few that I can't recall
Quoted: 347 Post(s)
Liked 302 Times
Wheelman
Quoted: 298 Post(s)
Liked 676 Times
I got the 50mm - that's 50mm when flat, so 100mm circumference.
So that's 31.8mm diameter.
43mm => 86mm circumference => 27.4mm diameter
