For the love of English 3 speeds...
#1376
Quoted: 36 Post(s)
Liked 38 Times
Does anyone know if the numbers stamped on a dynohub are a year indication? I've got a Rudge with a 12 60 stamped on the front hub, 61 stamped on the rear sturmey hub, and b 60 stamped under the Brooks saddle. I can only imagine this means I have an early '60s Rudge?
Also do the serial numbers have any rhyme or reason?
#1377
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
#1378
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Right. In fact they can use quite a bit less and still make it a whole lot stronger. I've straightened bent hi-ten steel frames more than once, and it's pretty easy. I tried to straighten a bent 531 by the same method, and it just laughed at me.
#1380
Bikes: 1989 Dahon Stainless Classic III Folder - 1990 Dahon Mariner Classic III Folder - 2005 Dahon Jetstream P8 Full Suspension Folder
Here is a great notstalgic 1950s dutch video with ton of Dutch 3 speeds.
https://www.youtube.com/watch?v=1HgLqts3qJs&NR=1
#1381
Schwinnasaur
With strength steel you sacrifice ductility. Does any one know the yield of Hi-ten, Chromoly, and 531. Here is some stuff posted frome here https://www.bikeforums.net/showthread...eeds.../page56
Steel Alloys
Steel is a combination (an alloy) of iron and other elements designed to improve upon the material properties of pure iron. The alloying elements make up a small fraction of the material by weight (iron is 97% or more of most steel alloys) and don't significantly alter the density (weight) and stiffness of the material, but they can have a significant impact on the strength, weldablity, corrosion resistance and expense of the material.
While there are dozens of steel alloys, only a few are commonly used in bike construction and only two--high tensile and chromoly steel--are used in most mass produced bicycles today.
High-Tensile (Hi-Ten) Steel
High-tensile or carbon steel is a common and inexpensive alloy comprised of iron mixed with 0.2% to 2.0% carbon. (Of note, when iron is mixed with more than 2.1% carbon it is no longer "steel", it goes by the name "cast iron".)
High-tensile steel is an inexpensive but relatively weak alloy. Although it has essentially the same density as other steels, manufacturers working with hi-ten steel are forced to use thick walled tubes to ensure adequate strength, and rarely use butting. For this reason, high-tensile frames are much heavier than their chromoly counterparts.
Today, high-tensile steel frames are primarily used for children's bikes and are sometimes found on inexpensive adult bikes.
4130 ChroMoly (CRMO) Steel
ChroMoly is a steel alloy composed of iron combined with chromium (roughly 1% by weight), molybdenum (roughly 0.2%), carbon (roughly 0.3%), silicon (roughly 0.2%), manganese (roughly 0.04%) and sulphur (roughly 0.04%). 4130 is actually just one of a family of chromoly alloys, but it is the one used for bicycle frames. ChroMoly steel is also used in the construction of airplanes, and is sometimes known as "aircraft tubing".
Chromium is the component that makes stainless steel rust proof, but the chromium level of chromoly steel is not high enough to provide corrosion resistance. (Stainless steel is 10% to 11% chromium.)
Chromoly is frequently used to build mid-to-high-range steel framed bikes. A well made butted chromoly frame is typically only marginally heavier than an aluminum frame, and quite strong and durable.
Reynolds Steel
In 1953 the Reynolds Cycle Company began manufacturing a steel tube composed of proprietary manganese-molybdenum steel alloy they branded Reynolds 531. This alloy was strong and for its time, relatively light. It was once the preferred tubing for steel racing bikes (as well as British aircraft).
Over the years, Reynolds has introduced a number of branded steel tubes, the brand name indicating both the specific alloy and heat treatment but also the wall thickness and butting of the tubes. These include Reyolds 453 (a single-butted tube made of a manganese-titanium alloy), Reynolds 501, 520, 525 and 725 tubes (using 4130 chromoly steel), Reynolds 753 (high-end tubes made of a manganese-molybdenum alloy, essentially a better Reynolds 531), Reynolds 853 (4130 chromoly made stiffer by air hardening) and Reynolds 953 (a lightweight rust-proof maraging stainless steel introduced in 2006).
Reynolds steel is less common in bike frames today than it once was, but some of these alloys are still in use. The Reynolds 520 family is a well made class of 4130 chromoly tubes. You'll pay a bit more for the brand name, but you'll know you're getting a well manufactured tube. Reynolds 853 is a higher quality chromoly, made stiffer than usual by the way it is manufactured. Reynolds 953 is perhaps the best steel available for bikes today: Reynolds 953 frames are stronger than titanium, no heavier than high end aluminum and rust proof.
Steel Alloys
Reynolds Steel
#1382
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
This is getting a little off topic, but while most of the information in the excerpted post above is correct to my knowledge, there are some statements that are incorrect or misleading. I'm neither a metallurgical engineer nor a historian of Reynolds 531, so I hope that the better informed will chime in to confirm or refute my take on the following:
- (Of note, when iron is mixed with more than 2.1% carbon it is no longer "steel", it goes by the name "cast iron".)
- In 1953 the Reynolds Cycle Company began manufacturing a steel tube composed of proprietary manganese-molybdenum steel alloy they branded Reynolds 531.
#1383
Bicycle Repair Man !!!
Wow... just realized that this thread got started on Feb 22 / 10 and don't think it has skipped a beat... much like those wonderful SA AW hubs we are all so fond of (among others).
For the number crunchers that is an average of 4 posts a day for more than a year running and I have to thank everyone for contributing so much love and checking in so often.
I was able to get out and enjoy a beautiful spring like ride last year but it is looking like we're going to be stuck in this deep freeze for at least a few more weeks... at least my winter bike is equipped with a 3 speed even though it isn't English and it has earned it's stripes this winter.
I did spend the last 6 weeks in Portland and got to enjoy another favourite 3 speed...
Likes For Sixty Fiver:
#1384
Bikes: 1971 Raleigh DL-1, 1979 Raleigh Cameo, 1980's Raleigh Rapide Mixte
First post on this thread, but I loved reading about all the different bikes here.
Anyway, here's a before and after photo of my '71 Raleigh Tourist. It was a fortuitous Craigslist find last year. The original owner was just a little bit too tall to comfortably ride the bike and this one happens to be a bit unforgiving with adjustments. I was happy to oblige and take it off her hands.
I have a couple of things left to do, namely adding the rear rack and a few other miscellaneous whatisits but it's mostly done. Having spent the better part of winter puttering around indoors, I'm dying for the temperatures to get above zero so I can get out and ride!
#1387
There's actually a gentleman in Virginia that makes custom racks specifically to suit the Raleigh roadster:
https://redbarnbike.blogspot.com
For a long time I considered purchasing a commercially available rack (or trying to retrofit an Electra Amsterdam rack) but, in the end, the prices end up about the same and, in my opinion, this one is much more beautiful.
#1391
Bikes: 2000 Litespeed Classic, 1984 Schwinn LeTour, 1998 Gary Fisher Marlin, 1969 Hercules, 1977 Sekai 5000 Superlite, 1993 Koga-Myata TerraLiner, 2013 Trek Farley.
Quoted: 7348 Post(s)
Liked 2,470 Times
Well done. What kind of front hub is that?
#1394
phony collective progress
Bikes: https://velospace.org/user/36663
It's the cheapie Novatech dynamo hub VO has on sale. Nothing hooked up to it yet. I still have to figure that stuff out.
#1395
Liked 2,470 Times
Well, I've been riding three speeds a bit lately, after a long time of not riding them. My main bikes are not in running order, so it was time to get at least something working. I was very pleased to acquire a Rudge last year but hadn't done anything with it. It's running great now except for the need for a pedal, which is on its way. It's lovely. I always wanted a Rudge even more than a Raleigh.
The Kool Stop brake pads don't fit on the left side of the front brake, because the caliper is so close to the fork blade. I'll have to get the short kind there. So I have three Kool Stops and one generic pad. The brakes work very well, at least in the dry.
And today I fixed my Raleigh Twenty so that I could take a bike on the train. I don't know which kind of headset it has. I know some (or all?) of them came with a plastic sleeve bearing, but this looks like it might be a traditional ball bearing. I stupidly left the bike outside all winter, and now it's worse than ever. The bike rides almost as if it has a flat front tire. I'll take a look and see. And the brakes suck, big time. I'll get some Kool Stop brake pads and see if they help.
I rode to the train station, carried the bike on the train, and rode in Manhattan. As you can imagine, riding in Manhattan is grueling and very dog-eat-dog. It's a bit harrowing with a sluggish bike, a stiff headset, and gawdawful brakes. But I survived. It was fun anyway.
#1396
Schwinnasaur
On my R20 I had to go a front V-brake to get good stopping ability. Even with Kool Stops the original brakes are just too long. I also went to AL rims and Schwalbe Marathon tires. The original rims were pitted and the tires were shot.
If I were to going to replace the tires again I would not go with the Marathons.
#1397
Quoted: 70 Post(s)
Liked 15 Times
Aaron
#1398
Liked 2,470 Times
How did you put a v-brake on?
#1399
There are a few ways to do this... you can change the fork to one that has the right bosses or modify the existing fork by adding them.
My P20 got cantis to allow for fender clearance and compatibility with road levers... an upgrade like his might run you $80.00 to have the bosses added front and rear.
Built this up for a friend... used linear pull levers to handle the v brake up front and added a drop bolt for the rear caliper although we will probably add some new bosses in the rear for another v brake.
The stopping power is awe inspiring and the suspension fork really makes bad roads a non issue... and it is still an English three speed (with a lot of mods).
#1400
Will any of you have a spare Raleigh crank 46t in clean working condition? I need it to complete my Superbe restore project.
That's the type of crankset I am looking for, 46t.
