Is this a real Mafac stiffening bridge, or a knock-off?
www.theheadbadge.com
Quoted: 2425 Post(s)
Liked 4,407 Times
Gotcha!
Humor aside, since not everyone has seen the ongoing discussion in the mafac stiffener thread about these, I thought I'd spin this off into a separate discussion.
Given the elusiveness of the Spence Wolf / Cupertino aftermarket Mafac bridges from BITD, I decided to try a test run of a modern interpretation / repop. These arrived in the mail yesterday, to the specs I came up with (with the assistance of bulgie, Charles Wahl and oneclick ):
Now, the company I used to make these isn't my first choice, so I'm on the fence. One bridge clearly has a few scratches on it, and - unlike my normal laser cutting service which will deburr things, these folks don't (thanks @bulgie for the tool recommendations).
I realize this is not really anything to complain about, but it's just one more repetitive, irritating thing I have to put on repeat for every one of these things after paying a fair amount to get them cut in the first place.
Still, this company will laser etch the stylized "M" and the other won't, and I feel this does make a big difference. The end result does a fantastic job of transforming an otherwise homely Mafac Racer:
Next step is to pull something from the fleet that I can fit these onto for testing. I don't have much here that's still centerpull; might have to make the '61 Paramount the testbed.
More to come.
-Kurt
More to come.
-Kurt
Likes For cudak888:
Quoted: 964 Post(s)
Liked 1,451 Times
The security torx screws assure that nobody will steal them!!
Seriously though they do look nice!
Likes For scarlson:
Likes For Mr. 66:
Disraeli Gears
Very nice! It's a shame that when such a useful device is installed, it obscures the original brake.
Is that 1/8" / 3 mm material?
Is the logo "laser etched" or "laser marked"? (which are different processes, according to a local outfit I've been considering using for some other work)
Likes For Charles Wahl:
Liked 4,407 Times
Plus point: The washers are captive to the screw. Can't lose them.
I could get very creative with the design - full drillium if I wanted - but I personally can't stand how rough the Racers, early Competitions, and Raids look. To me, it's a visual improvement, even fi it looks a bit more Modolo than Mafac.
The company I had these done with claims it's "area engraving," but it's clearly not really engraving at all. I'll ask them when I inquire about the scratched piece.
-Kurt
Likes For cudak888:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3906 Post(s)
Liked 6,517 Times
My question for the op: is this the real "is this a real Mafac stiffening bridge or a knockoff" thread or a knockoff?
Likes For SurferRosa:
Quoted: 4837 Post(s)
Liked 3,967 Times
Likes For 79pmooney:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 988 Post(s)
Liked 656 Times
Hmm, hide the OEM Mafac text on the caliper and add a Campagnolo logo to the accessory brace?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Liked 4,407 Times
-Kurt
Likes For cudak888:
Quoted: 2588 Post(s)
Liked 4,827 Times
Dayum, Kurt - those came out really nicely (doffs imaginary helmet... wait, I don't wear a helmet - make that cycling cap)!
Well done; I'm sure they'll do the job, too
DD
DD
Disraeli Gears
Sacré bleu! NE JAMAIS! or should it be NIEMALS! NIEMALS! NIEMALS!
Quoted: 3817 Post(s)
Liked 6,741 Times
I wonder if there’s some crude way to quantify the effect of this stiffener, compared to a MAFAC Racer without the stiffener. Maybe @gugie has some engimaneering know how to impart.
Likes For nlerner:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4690 Post(s)
Liked 5,837 Times
Likes For gugie:
Liked 4,407 Times
"Rough" is OK with me when it's "authentic" and "vintage".
That sounds to me like what the joint in my area calls "marking" as opposed to "engraving". I've never seen the former, and recognized it as such. My interest in knowing the difference is that I'm trying to make an amplifier control panel with one or the other.
It's dead flat, I'm pretty sure it's the laser marking you speak of - such as letters on an aluminum faceplate for an amplifier or lettering on aluminum-bodied lighting equipment. I wouldn't classify it as "engraved" at all by definition of what engraving actually is.
I'm pretty sure that was a Dia-Compe, so Japanese may be more appropriate. But the forum prevents me from having fun with kanji spit out of Google Translate.
If I told you, I'd get banned
-Kurt
Likes For cudak888:
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,299 Times
I haven't tried adding a front bridge to any Mafac caliper, but I have noticed that some combination of their good leverage (and an amount of flex coming from somewhere) combines to give the brake lever a long throw through its generous travel range. These Mafac brakes also manage to give good clearance at the pads for handling warped rims and wheel flex.
I did find it necessary to explore improving the flex resistance of the Weinmann front caliper that I used for MTB racing, due in part to my use of slippery-when-wet MA40 rims with still-intact anodizing.
I first made the front bridge, only tall enough to clear the biggest (45mm) tire I would use. It made the brake feel a lot less less squishy at the lever, good for keeping the lever from bottoming on the grip.
I then noticed how much that the long-reaching arms and pads rotated as they got pushed forward by the rim, the long Matthauser pads threatening to have their top-front corner cut into the tire, and much of the rear of the pad moving past the other edge of the brake track toward the hub.
So I added tethers to transmit the braking force directly to the fork instead of cantilevered off of the flimsy, nylon-bushed pivots.
The latter modification surprised me, it firstly reduced friction at the pivots quite noticeably, but also kept the long pads better aligned with the rim for added firmness at the lever.
The tethers also angled slightly inward toward the rear, so effected some self-energizing effect as well.
There are examples of both modifications on bikes from earlier in the last century, and we also saw brake boosters as they became called become somewhat of a fad back in the 90's on mountain bikes.
Crafting a booster/stiffener plate for a particular bike is a fun exercise in practical design, more fun when you add some precise drillium to top it off.
On one of my efforts (on the front of a hybrid), I used a ready-made booster having big hoops for eccentric bolt-center adjusters. But it was so much taller than necessary, being made for 26" tires. So I hacked off the loops and notched the ends of the horseshoe to position it against the cantilever pivot bolts with thick sandwiching washers holding it in place.
Then I made one from scratch for the rear, adding drillium. The braking really is so much better, front and rear, especially since the pads no longer go through such a range of toe-in change due to flexing pivots.
My first-ever brake booster was the strip of bracket cut off of a water bottle cage, modified a bit for use on a 1978 U09 having Weinmann centerpulls.
It (the bracket) sure was ugly! That bike has been sold and thankfully no pictorial evidence of that booster remains.
Liked 4,407 Times
I'm curious how the bridge helped reduce the sponginess; might I ask what's the OD on the spacers you used to push the bridge further forward? I'm wondering if the bushing and the bridge helped to apply more pressure around the nylon bushings, taking some of the bendiness out of it. I wonder if the bushing/washer alone spreading the force might do the same thing, minus the bridge. Just spitballing ideas here.
I think it can't be overstated that you're running that on a Pedersen replica, by the way. That just makes it cool. It's even cooler that you're using it on one of them.
Those tethers - in principle - remind me of the L-shaped brackets fitted to some bikes (usually cheap ones, but I've seen them factory with John Bulls on secondary-brand Raleighs) to grab the stays/fork blades to stiffen the caliper. Always thought of it as a kludge; by the 1960's we knew how to build a half-decent brake that didn't necessarily need these.
Mind, the tethers look absolutely perfect on the Pederson though. Adds an air of the past to it.
-Kurt
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1243 Post(s)
Liked 3,598 Times
Liked 4,407 Times
Likes For cudak888:
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
Kurt you're doing some very nice work ! A pic of the original which were also laser cut, and then drilled.
There was some spalling from the cut and that was removed with conventional methods :-)
I like these and they do make a difference in brake "feel". to round out the package, I'd suggest a new stainless center bolt and brass bushings, both available from Rene Herse Cycles.
very cool !
/markp
very cool !
/markp
Likes For mpetry912:
Likes For Piff:
Liked 4,407 Times
I'm sticking with Mafac right now. All I have to do to get these ready to sell is deburr the reverse side. I'd be out of the notion if I had to start sourcing additional hardware; this stuff is expensive enough as is.
-Kurt
Likes For cudak888:
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
My rear raid got to where it won't hardly squeal at all, I kind of miss it. Also these things stop better than any brake I ever used.
Likes For 52telecaster:
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
You do know what MAFAC stands for right?
Mon Accoutrements Fait un Atroce Cacophone
(translated - my accessories make a terrible sound)
Kurt - let the end user do the deburring ! Good for you for getting these made
/markp
/markp
Liked 4,407 Times
Now that I've made these bridges, I think I can hack the look of a Racer now too
At least, I hope Google Translate got that right.
I'm not sure how many people would consider these if they had to deburr them on their own, really. I just wish I had one of these:
-Kurt
