Keeping Varia TL515 Synced
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
I use a Varia 515 with a Karoo 2 and it’s been paired for over a year. It, light and radar, comes on when I start a ride on my K2 and off when I stop the ride. So, I bought one foer my wife to use with her Garmin 830 and it pairs ok and works for maybe three rides tops before I have to reset the unit and pair again. Like today, it’s been working fine for a few rides, blue standby light is on, she starts her Garmin and nothing. Meanwhile, mine has worked flawlessly with my brand X unit for over a year.
For the life of me, I have no idea why her 830 and her Varia don’t want to play well together. Anyone else had this problem and solved it?
Keep the chain tight!
Liked 2,981 Times
what i'd give a try is unpairing everything, then start fresh with a reset to the headunit, then pair the TL515, then pair everything else after that.
-Oh Hey!
-Oh Hey!
Super Modest
Liked 4,621 Times
That’s a thought. In fact, she probably has a sensor or two left from an old bike. I’ll give that a try.
Quoted: 680 Post(s)
Liked 949 Times
if she uses the Garmin without the radar thats what's happening. Garmin does not like lights t one not connected. I found you need to make sure it always has them on a regular basis. or go into settings and turn off the radar. plus make sure you power off the Garmin each tine and not just put it to sleep.
Super Modest
Liked 4,621 Times
I removed all of the sensors on my wife's 830 and dis-enabled the lights. You can't delete them, only disable them. I re-paired which was immediate. A quick test showed everything working great. Light and radar started when ride started and went off when ride recording stopped. We went to a local ride and the 830/radar combo worked fine.
I'll keep an eye on it but i think the unit was treating the light as a separate sensor. Now, the radar sensor shows including the light controls and there is no sensor for the light. I'm thinking 'success' at this point.
Quoted: 680 Post(s)
Liked 949 Times
Likes For fooferdoggie:
Super Modest
Liked 4,621 Times
It’s worked properly a couple rides in a row so I’m starting to get optimistic.
Likes For Trsnrtr:
