Paul Chain Keeper or narrow/wide chainring? 1x11 setup
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Close to 1000 miles on my 1x11 setup with nary a problem. I had heard that rough terrain could cause a chain drop; however since most of my riding is on smooth roads I was not concerned. Well, last weekend at the end of a ride, my chain said adios to the ring and, what's more, wrapped itself around the crank in a way that I needed to break the chain to unravel. I carry a tool and extra pins so just a bit (actually a lot) of inconvenience, but I don't want it to happen again.
While shopping on line for a chain keeper, I found the one made by Paul Engineering - looks great and I was ready to order when I discovered references to narrow/wide chain rings, which I had not heard of. I've read other posts here that say mostly positive but some negative things about both products. The Paul Chain Keeper is expensive and not too pretty so if the N/W rings work as well as reported I'd rather go that way. OTOH, if the rings are just a gimmick and are only a marginal improvement, perhaps the Chain Keeper is the ticket.
Any real world observations would be great, especially from someone with actual experience with both?
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
My hybird is a 1x9 with a Race Face N/W ring and I haven't dropped any chains. If you are going off road more I might even consider both for extra security but on the road a good N/W chainring will work nicely. If you want to keep it MUSA Wolf Tooth Components makes an excellent one.
I will also say I have a All City Cross Wizard chainring guard on the bike but mostly to keep my pants and legs clean.
Got a proper chain length for a 1X? With a single speed chain ring or a NW one, you will not need a chain keeper. Got a clutch derailieur?
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I know you are just asking about those two things, but I will also add another suggestion: One cheap and (in my experience) highly effective solution has been to run a bash ring on the outside of the single ring, and an N-gear Jumpstop on the inside. I ran this on a 1x9 hardtail for years on legit, sometime very rough, singletrack and never dropped a chain. This was without a clutch style derailleur or N/W chainring.
This is of course assuming you can mount a bash ring. I don't know what your current crank/ring configuration is.
For cheap bash rings in every size imaginable (and made in the USA) check out BBG Bashguards. Most can be had for around $20 shipped.
Just Google Ngear Jumpstop to find it for sale.They generally run around $13.
Here is a pic of my Karate Monkey with that setup.
Non omnino gravis
I have belt, suspenders, and... another belt, I guess. Clutched derailleur, RaceFace narrow-wide, and a Paul chain keeper. Of the 3, only the chain keeper is superfluous-- it has carried over from my original 10-speed 1X conversion, with a std. chainring. But it is good lookin'. I've never seen a reason to take it off. Not hurting anything.
But I strongly recommend a narrow-wide. USA-made are good and cheap, RaceFace, Praxis, or SRAM are also excellent, just not as cheap.
On Holiday
Quoted: 394 Post(s)
Liked 14 Times
Thanks to all.
Clark W. Griswold
Liked 3,995 Times
Thanks. Been looking at the RaceFace and Wolf Tooth and I hear that Surly make a stainless steel one as well
Thanks. Pretty much decided to drop the Paul purchase and go narrow/wide. Since I had been wanting to get a larger chain ring anyway it makes more sense to divert money spent on the keeper to a N/W ring.
Thanks to all.
Thanks to all.
Bikes: A hauler, a commuter, and a steamroller.
Quoted: 15 Post(s)
I have two 1x bikes with NW rings, one with a clutch rear derailleur (the other with a stiff as hell spring), and both with no chain keeper. I have never dropped a chain with these on either bike.
Quoted: 15 Post(s)
Go with a NW chainring and a clutch rear. run that system and when you drop the chain more then once in a ride then replace the chainring.. Dropping off a NW usually indicates a badly worn ring .
JeffOYB
Bicycle Mechanics
22
10-17-13 09:53 PM
clearcastle04
Folding Bikes
37
11-27-10 12:28 PM
