SRM AXS app:Blocking gear combinations?
I've looked and looked, but cannot find any info on how to block certain gear combinations, like prohibiting a cross chaining shift to small front ring with smallest sprocket on the cassette. I know it is a thing but I don't see it explained anywhere I have looked.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
search : "SRAM FAQ" then email them your questions...... they're usually pretty good about answering such questions in a timely manner. be prepared to list Accurate Part Numbers and/or Groupset info.
Quoted: 1110 Post(s)
Liked 1,204 Times
I might be misunderstanding your question, but...
AXS doesn't have any settings that allow you to block any specific chain ring / sprocket combination.
However, it sounds like you're wanting to block the smallest sprocket / small chain ring combination. You don't have to "block" that combination, AXS doesn't allow it, period. That's the only combination that's blocked.
If you're on the small chain ring, the rear derailleur won't shift to the smallest sprocket in back. Just won't go there. You have to be on the big ring to go to the smallest sprocket.
If you're on the smallest sprocket in back and try to shift from the large chain ring to the small chain ring, the rear derailleur will automatically shift to the second smallest sprocket.
Does this answer your question? Sorry if I'm misunderstanding.
