Matrix Clincher Rims - Bad Reputation?
I was just wondering. I keep finding negative comments about how terrible these rims are.
I have 2 pairs of these rims. One pair I rode (yes, past tense) quite a bit and never experienced a problem. I rode mostly on bike trails and smooth roads.
What were the problems with these rims? And why do they have such a bad reputation?
Thanks
Thanks
Butchya can't eat just 1
Not sure what version of the Matrix rims you are talking about, but I've got a newer set that I've got tons of training miles on and have no problems. I've even got several races on them. They've been fine and have only needed a little truing one time on one wheel.
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
I have matrix rims on my 85 Trek 670. They were the rims that
Trek used (house brand?), they are 20 years old, have thousands
of miles and no problems.
I think that Matrix were sourced from Araya
T-mar, otherguy?
marty
T-mar, otherguy?
marty
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
The ones that I have are the aero profile ones, charcoal dark grey in color. The name 'ISO' rings a bell but I am not sure.
Glad to hear that there are other people with positive experiences. Sheldon Brown does make a comment about how terrible they are.
Bikes: Puch Luzern, Puch Mistral SLE, Bianchi Pista, Motobecane Grand Touring, Austro-Daimler Ultima, Legnano, Raleigh MountainTour, Cannondale SM600
I have a pair of Matrix Titans that lasted 15+ years and many thousands of miles. Finally retired them when a couple of the spoke hole ferrules started to pull through. But I definitely got my money's worth out of them.
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
I have seen several die of just that curse - nipples pulling through the rim...but...these were all wheels that had lots and lots of hard miles on'em. I personally have never had a failure with one of these rims.
The point to observe here, I guess, is that rims are expendible, and do wear out, both from fatigue failure (like ferrule failure or rim joint failure) or from excessive braking surface wear. You have to inspect wheels carefully and regularly, because a catastrophic failure while riding is, well, catastrophic.
Quoted: 4722 Post(s)
Liked 3,039 Times
Originally Posted by lotek
....I think that Matrix were sourced from Araya
T-mar, otherguy?
marty
T-mar, otherguy?
marty
Personally, I have no extended experience riding Matrix rims, but I have not heard complaints from the many cyclists that do.
The only road rims that I have had a personal problem with are Campagnolo Omega, which I started riding in the early 1990s on my Marinoni and Gianella. The nipples would start pulling through after about 20,000 km. Wheel guru Jobst Brandt is convinced that hard oxidized rims, like the Omega, are more suspectible to failure. He argues that micro-cracks are created when the manufacturer punches the spoke holes into the brittle hard anodizing. The cyclic loading of the rim eventually causes these cracks to propogate into the underlying aluminum, which weakens the area around the hole and allows the nipple to pull through.
My personal experience supports Brandt's case, though I did not realize it until after I had read his argument. Apart from the abusive, heavy hit or crash induced failures, the vast majority of wheel rebuilds that I have performed are due to spoke pull through on hard anodized rims. This could also be due to the current prevalence of this finish, but I do not recall doing many rebuilds for this failure mode prior to the introduction of hard anodizing. For instance, my favourite vintage wheelset used a set of Fiamme yellow label rims and they had had about 150,000 km on them before I had failure between the double eyelets.
Quoted: 15 Post(s)
Liked 9 Times
you know I should have known that, I just ruined a "made in america" sticker
from my '85 wheelset (they don't hold up to finish line bike wash, or was it
degreaser?).
Knew I always liked the polished look better than anodized for a reason.
T-Mar are you aware of the same problem on Mavic Rims (i.e. SSCs)?
I've heard that Campy had problems back in the late 80's to mid 90's
but hadn't heard anything about other anodized rims.
marty
degreaser?).
marty
Liked 3,039 Times
marty
marty
Urban Cyclist
Bikes: Guerciotti SLX - 84', Tide-Ace 11sp carbon frame & misc. Shimano parts
Quoted: 8 Post(s)
Matrix Journey Clincher 700C 36h Rim
About 3 years ago paid $35 for a NOS Matrix Journey rim from a local bike shop. I laced with 2.0 mm spokes for a front wheel mounted on a vintage Guerciotti SLX 84' frame. I rode 4.5K on this rim without issues. After initial truing and tensioning did not have to make further adjustments. Average spoke tension I used on this rim is 107 KGF. I like to find manufacturer's spoke tension recommendation - maybe from Trek? Companies mentioned who may have manufactured this rim for Trek, AFAIK are no longer around.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The dubious reputation of Matrix some people have mentioned probably dates back to the original "Iso" (as in "isosceles," referring to the cross-section shape of the extrusion) tubular tire rims. There was a batch with poor anodizing (lots of pitting) that may have led to this assessment (I have a bunch of these reject rims I use to stretch new tubular tires). Or perhaps because the Iso rims didn't have eyelets, and builders were expected to use rim washers under the nipples, but didn't always do so, leading to cracking at the spoke holes. That said, I've never had a problem with the Matrix rims I've built into wheels. But then I use the rim washers on the Iso rims and the eyeleted rims never had a problem in my experience.
Likes For RoadieDropper:
No longer active
Quoted: 89 Post(s)
Liked 6 Times
23 years ago, my Trek 930 came stock with Matrix clinchers (26"/ 32h/ double-eyelets) and they've lasted just fine even to this day; so... I dunno. I've heard some talk over the years about the poor-quality anodizing, but I've never experienced a problem with it myself.
Quoted: 34 Post(s)
Liked 22 Times
I've got a set of Matrix ISO C-II wheels. I am not a fan. One is really lopsided and goes out of true often. Plus the sidewalls of the tire where they contact the rims gets worn away so that I am afraid of side wall failure. My Mavic CXP33 and Open Pro rims don't do this.
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Matrix rims have always been known for being extremely tough, as has been my own experiences.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
When I built up our tandem I got what was purported to be the rear wheel that was on it when it had been retired and disassembled. Original Atom hub but strung into a Matrix rim of unknown model. It wore a sticker from a bike shop on Martha's Vineyard. It had been strung incorrectly with the valve hole between converging rather than diverging spokes. Maybe that says something about the wheel's longevity, or I should say its shortivity. After maybe 1000 to 1500 miles it broke a spoke. I replaced but after another 500 or so it broke another. As I was examining it prior to fixin' I noticed the cracking. Longitudinal cranks between spoke holes. Of course we don't know what history it suffered before we got it. I do know its history after that - it got tossed immediately. I've never seen any other rim crack like that but what do I know?
Real cyclists use toe clips.
jimmuller
jimmuller
Quoted: 378 Post(s)
Liked 1,410 Times
The Titan is a good, solid wheel, with eyelets, in the same vein as Wolber's Super Champion Alpine, Araya's CTL-370 and Sun's M14-A.
I had an all-silver set once, 36-hole, appeared to be a box section and they were very strong. I don't remember the model name. The finish level was not great, but the rim was money in the bank for durability.
Old fart
Liked 3,401 Times
I have owned only one set of Matrix rims, Matrix Swamis, with an asymmetrical rear rim on my '98 7000ZX. I've had them since new and they've survived quite a bit of abuse over the years. I did have my doubts about the radially spoke'd front wheel, but that's been proven unfounded.
I've never seen any Matrix rims that weren't OEM spec'd by Trek...shame.
Brad
Brad
Working as a mechanic back then I saw some Matrix come in separated at the seam. Some were cracked out at the nipple opening, and quite a few had the dreaded "wavy" sidewalls. Mostly they came through in good shape after many miles. I think the biggest beef I heard from others was building them. It was harder than what came from Mavic, about the same as Araya. Tough to get round, and the wavy sidewalls made lateral true a guessing game. Personally, I liked them as they seemed to be tough rims. In particular the Titan and ISO C were durable.
Death fork? Naaaah!!
Bought a wheelset several years ago, Titan rims laces to 105 hubs.Been on three bikes, and currently on a Tempo.No problems at all.
Top
Top
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
I did have a problem with cracking on a couple spoke holes on a rear 6 spd Matrix "Titan S".
That said, it was OEM on a 1988 Trek 1000 and had at least 30K miles on it, with many of those urban commuting on our crappy northern potholed roads. It's currently still in use on my son's Schwinn Traveler. I told him keep an eye on it.
Liked 645 Times
