Easy workaround to keep chain on a single front ring?
I don't need more than one front chainring for my CX bike. Or, for my roadbike for that matter.
But if I try to just go minimalist up there -- and skip the front derailler -- once a ride I'll throw my chain.
The crazy thing is that I never notice the derailler making any "chain catching" sounds, like when it's saving a chain that would've otherwise fallen off.
And I can't find a pattern to the derailing.
So does it really have to happen? And do you really need some kind of guard to prevent it?
Let's see, singlespeeds don't have them.
And the front der only prevents derailing at the top. So something must be happening as a tight chain goes onto the ring after pulling past the top of the rear cog. But what? Is it a slight change in tension that allows slack which in time with some kind of sideways motion or bump throws the chain off?
I've tried one of those "shark tooth" things and I suppose that stops inboard derails. The chain would still sometimes fall off to the outside and cause bad trouble (like in a sprint).
Lately I just slapped a front der back on during summer use with a 53t front ring and racing rear cogset on a roadbike.
I'm now in CX season and I use the same bike for CX. So I now have a 40t ring up front and would like just to be shed of the excess front der. Maybe that shark-tooth would do the trick. Who knows, maybe small rings drop their chain some other way and might tend to more reliably keep a chain. I dunno. I guess I do hear about 'crossers using chainguards for single rings.
I just like to save all possible weight and would love to ditch that hunk o' metal there that's only keeping my chain on and doing nothing else.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Keeping the FD on makes the most sense. But if your chainring has shaped teeth for shifting speed then you may get some benefit from using a single-speed chainring with full size teeth.
Quoted: 550 Post(s)
Liked 325 Times
1. Don't have rings with truncated teeth in "downshift zones" which encourage derailment.
2. Have a straight chain line which wouldn't cause bad interactions.
1. Worn big ring. I fixed that problem with a new crankset.
2. Worn middle ring on a triple with the same chain-line as a single-ring crank. I replaced the ring.
Presumably the same thing could happen to the outside, and obviously a 3/32" single speed ring without down-shift zones would be a better solution for a one ring bike.
I've also gotten the upper and lower derailleur pivots dirty enough that it didn't follow the chain promptly. My problems stopped at chain slap although I suppose more could have happened.
No personal experience, but I would look into the single speed chainrings. I was looking at the SRAM X11 stuff and they had a pretty gnarly chainring tooth profile to keep the chain on that single front chainring in all gears.
Putting the derailer on would ruin the set-up IMO. You'll still have to trim it to keep it from rubbing, and once you are at that point you may as well put the other chainring back on and run a double.
Constant tinkerer
Yes, sadly, you need a real chain keeper to hold it on for cyclcross. Only for road biking can you maybe get away without one.
And it needs to be as close as possible to the chain (vertically.) Or else the chain can slip through.
You don't notice it because when it's (potentially) being thrown off you're going over a bumpy section and not looking at your chain...
Yes, it happens. You only need to ride without a chianguard to find that out.
Single speeds don't have them because they don't have rear derailers (which hold the chain sort-of on track using a spring.) With a single-speed there is nowhere for the chain to go. It CAN'T fall off.
You only need to prevent derailing at the top because when the chain derails from the bottom you just pedal a bit and it will be right back on. When it derails from the top you're screwed. I have a Paul chain keeper on my cross bike and my chain will sometimes derail from the bottom. No big deal. Just don't try pedaling backwards when that happens or you can have a serious jam, and ruin your chain keeper.
Experienced
Quoted: 16 Post(s)
You don't have to have a chain keeper OR a real single-ring if your chainline is perfect. I mean *perfect*. Line it up with a straightedge and use whatever spacers or respacing you have to do to get it within .1mm.
After that, get a dedicated single-ring on the front.
https://www.cyclocrossworld.com/thorn...hainring-guard
+ one of the several chain catchers to keep it from coming off to the inside..
that wrap around the seat tube and reach to the chain, ...
Im less weight conscious, Surly single speed rings in stainless are fine..
you might prefer Ergal alloys.
a set : https://www.cyclocrossworld.com/thorn...-chainring-kit
Liked 10 Times
Ben Berden's front ring set up. use the inner ring for the toothed gear and a blank ring like above for the outer and get the K edge keeper that has a "roof" on it so it won't bounce up
Magnets, how do they work
As an alternative to SRAM, check out Wolf Tooth Components. They have a decent new selection of rings that can be run 1x10 with no chain guide, and I've only heard very good things.
Quoted: 714 Post(s)
Liked 800 Times
These are designed specifically for that purpose. They work better with a clutch type rear derailleur, but they work well without them. https://www.wolftoothcycling.com/
Constant tinkerer
But you're right, no chain keeper is needed on a single-speed/fixed gear. If it is, something is wrong.
Liked 5 Times
We need to sticky one of these threads. Every week, it seems, someone comes up with the bright idea of "simplifying" their geared ride by making it a 1x__, and then everyone shows them the doo-dads that are shaped like FDs and the bashrings that are like toothless chainrings, and the deeper-toothed rampless/pinless rings that help too, and then the OP says "really? wow. gosh. I didn't realize that i'd have to spend extra money and buy extra parts in order to 'simplify'." In the end, the only parts you're eliminated are the left shifter and its cable-- and about half of your gear range.
Yeah, well, that doesn't seem so simple now, does it?
Maybe it's just me and my inability to think abstractly or tolerate goofy half-measures, but it seems to me that one oughta decide: am I a derailers person, or a SS person? (If you truly can't decide, consider becoming an IGH person...) I love SS, I love it to death, but I have some geared bikes, too. And once you've delved into that whole mess, you might as well get derailers on both ends of the drivetrain.
-rob
PS-it's the rear that musses everything up, anyway, with the goofy 7/8/9/10/11/infinity arms race and the difficulties in cross-compatibility. The front has been pretty much double or triple for ages now, with a few 4-ring oddballs popping up from time to time....
-rob
Constant tinkerer
Quoted: 19 Post(s)
Liked 7 Times
I used to ride a 1x5 system, that was how the bike came. The chainring teeth were unramped and there was no keeper or guard.
I think modern chains may have more lateral movement than chains of old, has anyone tested for this?
1x8 or 1x9 systems can provide enough gear range for rolling terrain without steep hills. The chainset is much lighter and cleaner with fewer dirt traps. There is nothing wrong with the concept as long as you can get it to work reliable with modern components.
Fit unramped rings, a chainkeeper device or some plastic chainring guards.
Quoted: 1529 Post(s)
Liked 718 Times
If you want to be really minimalist about it, I'd try this experiment:
No wait, if it turns out this is enough to prevent the chain being thrown (probably in conjunction with a SS ring), then you can disassemble the RD's pivots and drill new holes for the springs, to set a higher chain tension. Harder than usual to reassemble.
BB derailer pulleys, as always, are a good idea too (plastic not ally).
Quoted: 1572 Post(s)
Liked 643 Times
Hmmm. My son just built himself a 1X10 hard tail mountain bike. He split a tire on a night ride last night so you know he's really mountain biking it. I wonder how he keeps his chain on the front ring. I'll let you know when he answers me back.
There's his answer: He uses an MRP chain keeper.
Liked 5 Times
1x5 or 6 is more reliable b/c chainline doesn't vary so widely. You're more likely to drop the chain at the upper- or lower-extremes of a 8, 9, or 10speed cassette.
There's no doubt in my mind that a 1x__ will provide enough range. The thing is, many ppl question the need for a double crank and a front derailer, b/c they feel they don't need the extra range. I feel like they need those items to keep their chain on the rings; the added range is just the icing on the cake.
If you like "clean lines" and "simplicity", get a SS or a FG. IGHs are nice, too. If you like derailers, I see no reason to forgego the front one, as you'll need to clutter and ballast the bike with other crap to keep the chain on anyway.
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
One: Align your front chainring with the center of the cassette.
Two: Trim your chain to the minimal amount that will work.
Three: Check your RD's chain tension get it as high as you can without a friction issue.
Four: You'll probably need a chain guide of some sort anyhow, good luck.
A 1x front is a great thing, but once you go past 7 speed it's very likely to have too much of an angle to travel on the outer low/high gears and will probably still pop off unless you have a guide/guard of sort.
carbon fiber chain guards are out there.. FSA for one https://www.bikeman.com/CR4021.html
Less bashable than what logjumping MTB's use .. .
the one in the 9th post, has most of the aluminum cut away.. so weighs less than the chainring it replaces..
save weight get 12oz beers instead, of 16s.. ?
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
Save more weight and get cans instead of bottles?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
It helps to keep pedalling over bumps -- the chain is slack when you're coasting over bumps, and that's when it can get dislodged.
Quoted: 7349 Post(s)
Liked 2,474 Times
I'm with surreal. 1-x-something seems like it's more trouble than it's worth.
Hoopdriver
General Cycling Discussion
8
05-01-18 03:37 AM
4rchtime
Singlespeed & Fixed Gear
27
12-16-10 09:46 AM
