Riding the nice bike during the winter time
Hi All
I sold my alloy road bike this year to upgrade to a carbon fiber road bike with SRAM axs. Everything on the internet says like salt will immediately corrode and destroy my new bike, but it’s my only bike and I’d like to keep riding it through the winter when it relatively dry out. tThere will likely be a lot of salt on the roads too. Would my bike and drivetrain be ok if I put clip on fenders and washed the bike down after each ride? Anyone else ride your nice bike during the winter?
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I do. But, there are only a couple weeks a year with appreciable road salt where I live so it is not that hard to keep it clean. If I was in Minnesota I would have a special winter bike. Either that or hose down after every single ride. Which isn't a lot of fun when it is really cold out.
Likes For scottfsmith:
Quoted: 20810 Post(s)
Liked 9,456 Times
I ride my nice road bike outside in the winter if the roads are dry; dusty, salty road grit hasn't been an issue. If there's snow, ice, slush, etc, I'll ride a bike with studs.
Likes For WhyFi:
Likes For Bmach:
Quoted: 769 Post(s)
Liked 1,748 Times
I ride mine outside, but.....I live in Florida, so I guess it does not matter what I say.
Likes For jaxgtr:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
You violated the N+1 rule. but ride what you got. Then clean and lube when the weather is nasty.
Likes For biker128pedal:
Quoted: 18883 Post(s)
Liked 10,646 Times
Hi All
Versus not riding when it's nice, which just sucks. Definitely ride. 🙂
Likes For Seattle Forrest:
Quoted: 645 Post(s)
Liked 797 Times
Hi All
I won't risk crashing if the roads are wet or black ice might occur. Dry winter roads only. In Colorado there's certainly some salt or magnesium chloride, but not that much. I use a damp rag after each ride.
Likes For DaveSSS:
Quoted: 314 Post(s)
Liked 683 Times
^ Basically this. I'd only add that you should clean it shortly after any rides where it gets covered in loads of salt and grime. Don't let it sit dirty for days.
Look after your bike and it'll look after you. After all, it was made to be ridden! 🙂
Thread Killer
Quoted: 3152 Post(s)
Liked 1,717 Times
I’ve ridden both aluminum and steel frames through decades of Michigan winters, and based on that experience, I can tell you that there is not much to worry about, regardless of how often you clean it.
The biggest consideration, I think, is to let the bike thaw and have the slush melt off. Next is to use stainless steel and aluminum hardware for bolts. Next, lube the chain. At the bottom of the list is washing. My commuter of 15 years was an alloy Novara Buzz, and yeah, while I’d wash it periodically, I was never obsessive or even habitual about it, and only bothered to wash it when it looked bad.
Depending on your storage circumstances, washing in the winter can be a real pain in the butt. My advice nowadays— and I never thought of this or did it before last year— is to get a garden sprayer from Home Depot, put some warm water in it, and rinse the bike down as needed. Sometimes I even do a two step thing, where I put soap in and suds it with the sprayer first, and then do another fill of clean water to rinse. It’s a bit of a PITA rinsing soapy water out of the tank, so if you have a bucket and brush, I’d probably just do that and use the sprayer to rinse it off. The nice thing about the sprayer is that it’s a very fine spray that can be precisely targeted, so you’re not slinging water all over the garage, driveway, or wherever, which then turns to ice.
But, since we’re in the Road forum here and not the Commuting forum, I don’t suspect you’re going to be riding through slush, and are instead dealing with light, salty spray and salt dust, so just rinse that stuff off, lube your chain, and you’ll be fine…for many, many years.
EDIT: this is my winter/spring trainer. This is it’s seventh winter, and it’s had no major overhauls, not even bottom bracket. It did get one new BB, but it was a misdiagnosis chasing a squeak which turned out to be a missing chainring bolt. Whic reminds me: grease your threads! All of ‘em.
aluminum Kinesis Racelight 4S
Likes For chaadster:
Quoted: 1461 Post(s)
Liked 1,486 Times
Dry roads are no problem. The challenge I have is once snow is on the ground, even if it's dry and sunny there are often puddles and roadway moisture that is unavoidable. Hit a few of those and you'll find salty grime all over your bike. No big deal if you wash it off - but also washing bikes in the winter is a bit more challenging too.
I have a few bikes that I ride in really gross conditions (cyclocross and winter road riding). At the end of the season, I'll have my LBS overhaul these bikes. They strip the bike down to the bare frame, clean everything, replace cables, replace or repack/grease bearings, overhaul the rear hub, install new bar tape, etc. This service is usually around $200 and my bikes come back looking and feeling brand new.
Likes For msu2001la:
Thread Killer
Liked 1,717 Times
I keep my bikes on fleek, no doubt, and think they’re quieter and better performing than most, so we share that standard, however, as I said, I don’t do much more than basic maintenance and keep the bikes garaged. Component quality is a big deal; some bits are not as robust as others, e.g. cheap cables compared to performance sealed cables.
Quoted: 6199 Post(s)
Liked 4,816 Times
How did your old bike fair in the winter? I expect your new bike will experience it pretty much the same way.
Likes For Iride01:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
Hi All
I think that many over think the fragility of carbon. Heck, they make race cars and airplanes out of the stuff. Bike are meant to be ridden.
That said, I don't ride mine when it is cold and slushy. It's just not fun. I hate winter.
Good to know. I live in the Twin Cities too but I've been riding my fat bike in the winter when it's slushy. It's got a carbon frame but there has been really no issues with salt damage on the bike. That said, I was hesitant to ride my gravel bike on the roads (stainless steel frame) that has couplers. Since it could accept studs, this seemed like a reasonable idea. So when the roads are dry with dusty dried salt on them, it's ok?
Liked 9,456 Times
Yeah, I haven't had any issues and I'm not particularly fastidious when it comes to cleaning. I mean, realistically, that crap is on the roads through spring until the street cleaners come out in, what - April? May? It's always particularly gross when, after a long ride, I forget, lick my lips and get a huge dose of salt.
Likes For WhyFi:
Old newbie
Bikes: 2022 Trek Emonda SL 5, 2002 Klein Quantum, 2000 Trek 8000, 2011 Trek 7.5 FX
Quoted: 18 Post(s)
Liked 77 Times
I'm still riding in November, but only if the roads are dry enough. I sometimes ride at a local state park which is basically a sandy peninsula that extends out into Lake Erie, with roads on it. If I ride on partially wet roads there, my frame gets a good bit of sand on the frame in some places. After the ride, I use a water bottle to squirt and remove the sand from the affected areas and then wipe it down with a damp faux chamois that I carry in my car. It only takes a couple of minutes. It gets dried and windblown on the rooftop rack on the way home, which is only about 5 miles.
No salt yet to worry about. I hope to take my new Emonda out today, tomorrow or both days. I'm leaving for our winter residence in a couple of weeks and taking my old Klein with me. It's geared better for the flat roads there. I won't have to worry about salt there either.
just another gosling
Quoted: 3893 Post(s)
Liked 1,942 Times
Only if it's a dry roads day. I built up an inexpensive rain bike, alu frame, cheap carbon fork, cheap wheels, other spare parts, but new drivetrain with the same cassette and similar crankset to my nice bike, except that instead of expensive brifters and derailleurs, I used unindexed bar-end shifters and cable derailleurs, I built it maybe 20 years ago, still rides great. The frame and fork have fender clearance, so the bike has them. You could start with something used and go from there.
Results matter
Results matter
