Drivetrain Swap Question
I’ve got a 1983 Miyata 310 in pretty nice shape, equipped with Shimano Golden Arrow derailleurs and Dia-Compe brakes. I really like the aesthetic of the Shimano Tricolor components, and would like to use them on the Miyata. I’d like to keep the 5-speed cassette, or possible go to 6. Straight swap or in my ignorance am I missing something? What would I need to do to make it work? Thanks in advance.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
It's likely a freewheel, not a cassette. Surprised your '83 is a 5-speed, but maybe it wasn't until '84 the model moved to 6. Personally, I'd go to 6 or even 7. Should be an easy swap to Tricolor.
Quoted: 1608 Post(s)
Liked 2,216 Times
You need to check your OAL of the drop outs to see if they are 120 or 126, 6 speed was the jump unless you find a Suntour Ultra which can fit in a 120 OAL. Even so, you may have to space the hub with a swap, NDS to DS to get the clearance and change the dish of the wheel.
It not a big deal if you have some mechanical experience.
I have not run into a 5 speed cassette.
Edumacator
Quoted: 2440 Post(s)
Liked 3,129 Times
Not an expert, but I think you will run into a few issues.
The shifters...you won't be able to index on the rear, but could run them with current friction shifters (but then you are mismatched). I don't think any tricolor shifters ever had a friction option? Also, not sure I ever saw a banded shifter for tricolor so you would need braze ons? Also an opportunity for brifters...
The bolts for the brakes...are your current Dia Compes bolt or recessed. All tri-color was recessed I think. Levers will be no problem.
The 5 speed freewheel cogs might be too thick for the chain that would be thinner for the 7 speed pulleys on the tri-color.
Honestly, an upgrade would be cool, but you might need a new rear wheel with a freehub, so you can source a 7 speed cassette. Then you get the full benefits of the excellent tri-color stuff.
https://www.ebay.com/itm/29499941711...QAAOSwxh5ijALY
If spacing is made 126, and the hub is friendly, maybe an Ultra 7 freewheel could be wriggled into indexing.
Like I said, I am certainly not an expert so more knowledgeable folks will chime in.
EDIT: Does the 310 have that top braze on mount for aero shifters?
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 532 Post(s)
Liked 1,007 Times
I put Tri-color on my 1984 310 a couple years ago. I have since changed it back to the Golden Arrow components. I had to do some modification to the index shifters to allow them to be used on the aero-mounts. The aero-mounts have 4.5 mm threads instead of the more common 5 mm. I found an old pair of stem shifters that had the correct bolts. After removing the plastic wing nuts, I could tighten them with a nut driver. The wheels were already 126 mm uniglide 7 speed, so they slipped right in.
1984 Miyata 310, with SIS and Tri-color drivetrain.
SIS shifter on Shimano top mount base.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Shimano did offer an aero mount for indexed shifters, both clamp and braze options.
If the bike has side-mounted braze-ons, Shimano's weird shifter bosses would have been used for Golden Arrow levers, so the odd-size bolts would be needed to secure index levers (using Shimano's chromed, concave mounting escutcheons).
Quoted: 3513 Post(s)
Liked 2,926 Times
Where the hell did the name “Tri-color” come from? You mean Shimano 600EX?
Edumacator
Liked 3,129 Times
Shimano 600 ultegra had the stripe with the corporate colors...
Liked 2,926 Times
Tri-color is almost as bad as “brifters.”
Lots of great thoughts here, appreciate everyone taking the time. I knew it was freewheel and not cassette, but it was late and I’m old and had been up 21 hours. Plus I don’t know from Shineola. Anyway, stumbled on some really nice NOS in-the-box 600 Arabesque today. Hmmm, this stuff would look great on the Miyata...
