looking to get a second bike
Old 09-11-21, 11:13 PM
Geo_Zegarra2016
Bikes: Raleigh 2015 Revenio 1.0, 2021 Canyon Endurace AL Disc 6.0
Quoted: 39 Post(s)
Liked 8 Times in 7 Posts
I've decided to get the Canyon Grizil. Not going to buy until next year or so. Maybe early 2023 or late 2022. I feel like it will be better in terms of gravel trails and such. I was thinking of getting the Grail 7, but I feel like is my current bike (Canyon Endurace AL 6.0) can be converted to it since it has tire clearance. When it comes to these types of bikes. Does the groupset matter? When it comes to road bikes, groupset does matter but for gravel is it the same? I'm between the SL 8 and SL 7. It will be my first carbon bike too. Is Canyon the only bike brand that is good for rough gravel? I was thinking of getting an MTB but I really dislike the one position. So I hope the grizl is a good second bike for me.
Geo_Zegarra2016 is offline
Old 09-11-21, 11:54 PM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
The groupsets matter in exactly two ways, IMO, and these are very personal. But, asking these questions will help you get pretty close to what you desire.
1) Does it offer the gear range (in terms of gear inches) that you require? Or, can it be easily modified/upgraded to get there?
2) Maintenance, DIY. Are you able to do the maintenance required, or are you willing to buy the tools and learn?
With respect to point 1, there is no bike, or groupset, available today that I cannot utilize, but more than a few that geared too low for my taste, so I have to make sure I can make the necessary adjustments. In the case of a 1x gravel bike I bought in the spring, swapping the rear hub, and mounting a SRAM cassette instead of the Shimano offering that it came spec'd with, and bumping my chainring size got it right where I wanted it. With respect to point 2, I don't care for SRAM hydraulic brakes- use or maintenance, therefore, I don't buy SRAM equipped bikes.
Badger6 is offline
Old 09-12-21, 09:04 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10964 Post(s)
Liked 7,491 Times in 4,189 Posts
Of course it isn't the only brand.
mstateglfr is offline
Likes For mstateglfr:
Old 09-12-21, 03:53 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
Eh... No. IMO probably three of the top choices would include the Salsa Cutthroat, Open Wide and maybe the Bombtrack Beyond 1.
dwmckee is offline
Old 09-12-21, 07:05 PM
Geo_Zegarra2016
Quoted: 39 Post(s)
Thanks, but after looking at these brands. i will stick with Canyon
Old 09-13-21, 05:21 AM
Fentuz
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 240 Times in 176 Posts
it tends to got with tyre clearance. if like the grizl the approved tyres are 47-622 (700c) or 52-584 (650b) or greated, them it will be orientated towards the rougher side.
gearing seems to be usual 1x11 using 42x11-42 and the rougher side sometime come with 40 or 38 x 11-42.
Rougher is usually hydro brake.
As above, Sram works (that what I have on the gavel) but I prefer shimano and the shimano maintenances is easier (I don't need to work much on my shimano geared bike or my kids shimano bike).
Fentuz is offline
Old 09-13-21, 08:00 AM
mstateglfr
Sunshine
mstateglfr's Avatar
When you ask such a basic question as 'is Canyon the only brand good enough for rough gravel', you are clearly coming into the genre with no experience or knowledge. Everyone starts somewhere, so it isnt an issue, but I mention it because I am confused why you are so confident that Canyon is the right brand and the Grizl is the right bike when you didnt even know other brands have quality offerings.
Old 09-13-21, 09:38 AM
msu2001la
msu2001la's Avatar
Quoted: 1461 Post(s)
Liked 1,486 Times in 870 Posts
"Does it matter" is a fairly vague question.
The SL 7 and SL 8 have very similar groupsets. Both have GRX 2x11. The SL8 is full GRX800 and the SL7 uses a mix of GRX600/800. (
Are you asking if these upgrades are worth the extra $500? The GRX800 stuff is a bit lighter, but functionally will work the same as GRX600. It's the equivalent of 105 vs Ultegra.
It also looks like there's a 1x version of the SL7. Are you asking about 1x vs 2x?
msu2001la is offline
Old 09-13-21, 09:41 AM
Geo_Zegarra2016
Quoted: 39 Post(s)
Because I have a canyon bike already. Every bike is different. The geometry and feel of the bike. You know
Old 09-13-21, 09:44 AM
Moisture
Drip, Drip.
Moisture's Avatar
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times in 163 Posts
I like the added reach of drop bars and regular bars which keep your wrists in a neutral position. It's more comfortable than flat bars. 650b with thick tires would also be good. Ideally a tall stack for better comfort. This would be mostly for sport riding and quick commuting, seems like a cyclocross bike would fit the bill. But they usually don't have enough stack for me.
Something like a kona libre or salsa fargo would fit the bill.
Moisture is offline
Likes For Moisture:
Old 09-13-21, 12:12 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,437 Times in 2,763 Posts
Ummm, the "geometry and feel" of whatever gravel bike you buy is unlikely to be the same as your current bike. You know?
shelbyfv is offline
Likes For shelbyfv:
Old 09-13-21, 02:24 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Do what you like, but this isn't an actual answer to my questions.
You are confident the Canyon Grizl is best, yet you werent even aware other brands have bikes that are in the same category.
Your current Canyon will feel different from the Grizl since geometry is different. Canyon doesn't make every bike of theirs feel the same.
Old 09-14-21, 09:37 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
Well, on the Canyon spectrum - you really need to choose based on your favorite tire size. The Inflite and Grail are pretty road like in the positioning and feel - although the Grail is gonna be more endurance geometry than the Inflite. But both of those max out around 40mm more or less. If you want to run bigger, Grizzle is the answer. If you will never go bigger than 40mm, you don't need it. (you can put a 50mm++ tire in the front of any of those bikes though.
chas58 is offline
Old 09-15-21, 06:14 PM
pbass
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times in 211 Posts
You just described my Kona Rove ST. Eats "rough" gravel for breakfast, and then has singletrack with huge rocks for lunch.
pbass is offline
