Dahon Frame Hinge issues?
Hi guys,
I have the opportunity of a good deal on an MU P8 today. However, I just came accross something that really concerns me. Is it true that Dahon have issues with their frame hinges? Should I just wait for a Tern?
Tony
Tony
Bikes: Brompton H6L-X, Dahon Curve D3
DISCLOSURE: My wife and I own a bicycle shop that is an authorized Dahon dealer.
There have been random reports on this forum of Dahons with frame hinge problems. But, from what I have read, those seem to be with individual bikes rather than a consistent issue with a specific model. And some of those "issues" can likely be traced to an insufficient pre-delivery inspection or lack of user maintenance. More important, IMHO, is to confirm that the handlepost has been replaced if this is a model that was subject to a recall a couple of years ago.
-HANK RYAN-
Norman, Oklahoma USA
-HANK RYAN-
www.ocrebels.com
Bikes: Several bikes, Road, Mountain, Commute, etc.
Liked 5 Times
I checked my bike (DaHon Curve 8 SL) regarding the recall and it has the "R" stamped under the handlepost, so it's good to go in that regard.
However, the 8mm bolt that puts pressure on the white plastic (resin?) block keeps coming loose. I get about 5 or 6 folds/un-folds between needing to get in there and re-tighten it. Is there a good fix this problem? If this has already been discussed in detail in another thread, please advise.
Also, in reference to your note above, what user maintenance should be done on the main frame hinge, and approx. how often? The one on my bike is working fine, no complaints, but I want to keep it that way!
Thanks!
Rick / OCRR
New usename ThorUSA
a little loctite, a little common sense ...lol will keep that latch from getting loose ... as for the large frame latch ... same as what Hank replied... millions of dahons with that latch out there...
thor
thor
Bikes: Dahon Mu P24, Trek 7300
My Dahon Mu P24 has the frame hinge creaking. It was really loud. The bike shop (that sold me the bike) tightened it. Not that much of an improvement. I put some lubricant on the hinge parts. I'm not sure if or how much it helped. Somehow it settled down a little bit. Now it creaks occasionally, usually when riding over a bump or pothole. The creaking sounds like a loud sharp crack. The hinge is as tight as it can safely be. I nick-named the bike Fireworks: it's beautiful, fun to use, but can get loud, just like fireworks.
From my limited experience with a MU P24, the main hinge is solid but the stem hinge develops play and requires occasional adjustments. Personally I prefer simpler and self adjusting hinges like the Brompton.
New usename ThorUSA
that was true in the past Michael
I dont know about 2012 pricing for Bromptons, but the Mu p24 will be 1286.00 US dlr.
They are different bikes and shouldnt be compared, and definitely not by price alone ... but I digress
there should not be any loud cracks in the main hinge, period.
Maybe its too tight now?
Maybe its just to agressive riding through just a little too deep potholes or curbs ....
but there shouldnt be any loud noises ...
thor
thor
BTW, the Nova has a Dahon hinge on the main tube, with a Dahon licensing sticker.
www.ocrebels.com
Liked 5 Times
Thanks for the tip on the 8mm bolt! Which Loctite level do you recommend:
Purple = low strength.
Blue = medium strength.
Red = high strength.
Will stop by Home Depot on my way home and purchase Loctite!
Regarding the hinge, yes millions of DaHons use it, but what maintenance is required/suggested? Does it need grease or just a light weight lube (Tri-Flow, etc.)?
Rick / OCRR
-HANK RYAN-
www.ocrebels.com
Liked 5 Times
I believe the "Service Instructions" book that comes with new Dahons has this information for the different types of hinges/latches. PDF versions of these books are currently available at https://www.dahon.com/support/manuals
-HANK RYAN-Norman, Oklahoma USA
The hinge information was concerned with adjustment only and didn't address lubrication, so I guess it's not necessary. Good to have the adjustment info, plus the same for the handlepost (which has been giving me trouble lately!).
Also good to download the tech info on the Nexus hub, though I haven't had any problem with that bit; works quite well actually!
Rick / OCRR
FietsDontFailMe
Folding Bikes
2
05-09-14 03:14 PM
JosephLMonti
Folding Bikes
4
09-12-10 05:06 PM
