1986 Schwinn High Sierra (bronze/brown two tone)
Quoted: 1136 Post(s)
Liked 650 Times
I've REALLY wanted an 80s High Sierra for a while now, but finding one in good shape in one of the smaller sizes has been difficult, especially because I don't want one of the black chrome frames (I already have a black chrome Giant ATX 760. Giant also made the High Sierra). Finally saw a frameset posted on eBay with one of the two tone paint jobs from 1986 and jumped on it.
This is the "Sahara Bronze/Sable Brown" colorway. The paint is pretty nicked up. Looks good from 10 feet and no rust anywhere. Frame and fork are straight and threads are good everywhere. In 1986 the High Sierra came with Suntour Roller Cams front and rear, so it has U Brake mounts on the fork and seatstays. The frame/fork are LIGHT. Haven't weighed it but compared to other ATB framesets of the era this feels pretty feathery. The tubing is Schwinn's "Tri-Oval Tri-Caliber Chromoly". Meaning triple-butted and ovalized in certain places.
Serial number on bottom bracket: G0186. According to @T-Mar database , made by Giant in January of 1986.
Liked 650 Times
Here is a scan of the Schwinn catalog specs for 1986 ATBs. The Waterford catalog site doesn't have the ATBs for 1986, but @Scooper has linked to this scan in the past so here it is.
Likes For TenGrainBread:
Liked 650 Times
As for build - I am thinking of keeping it traditional and close to the original ATB/expedition intent. Meaning no drop bars or slick tires. I will be building it as a mid-to-late 80s ATB, with major period-ish upgrades to the original spec.
The first question is, Suntour Roller Cams or Deore XT U brakes? I have an NOS pair of each (Suntour XC Sport Roller Cams and Deore XT II U-brakes). Anybody have any opinions? I think the Roller Cams will look the part and of course are the OEM brakes for this model. The XT U-brakes are a little more unique though.
@pastorbobnlnh I feel like I'm slowly becoming you First the Sports Tourer and now this. Soon I'll be looking for a congregation
SCORE! and preach it brother!
Congrats on getting a High Sierra which you have wanted for awhile! I enjoyed my 84 as a city rider for awhile. They are nice riders.
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
Jeff Wills
Jeff Wills
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,195 Times
My riding buddy from church has an '86 in that color. He's the original owner and we keep it in tip-top shape. We ride our High Sierra's mostly on our local packed gravel Rail Trail, which is the longest continuous one in NH. This is a picture of us at the beginning of an end to end ride (60+ miles) one October. My yellow one is an '88. "B138" on the post tells us that Boston's North Station is 138 miles to the south.
Bob
Bob
Quoted: 2363 Post(s)
Liked 1,749 Times
I was never a fan of how U-brakes worked. On the couple I have now, when you release the arms to move the pads away from the rim, they move "down" where they converge and contact the tread. Just not an elegant design, esp wrt. wheel removal. And I think it would look way out of place on the front. Can't say a thing functionally about the roller cams, but visually, they look like gorgeous bridge architecture. I'm guessing they're semi-unobtanium, though, eh?
Yummy find, BTW. the build.
Bikes: The Good Book of bicycling
Quoted: 535 Post(s)
Liked 36 Times
enjoying this thread, the high sierra helped get me back into riding after the ten speed boom of the seventies.
Liked 650 Times
The XC Sport Roller Cams are actually far more common than the Deore XT U-brakes. The Roller Cams were specced OEM on quite a few bikes in the mid-80s, so a lot were made and are still around, whereas the XT U-Brake was more of an aftermarket upgrade option than an OEM brake, so far fewer lying around.
Quoted: 796 Post(s)
Liked 522 Times
I think the cool lugged uni-crown fork on lasted a year or two - nice score
If it still has the original headbadge the 4-digit number stamped on it will indicate the day the bike was built.
Quoted: 235 Post(s)
Liked 349 Times
I've got the Rollercams on my Cannondale and they're RAD!
Using Grey Kool-Stop pads.
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
My Project KOM-10, the next-generation version of the Parmountain, came with a RollerCam up front and a Shimano U-brake under the chainstays. Stopping power and brake modulation control are superb on both, when equipped with KoolStop pads.
Liked 650 Times
It's been a while but I finally started the build.
NOS Suntour XC Pro/WTB Greaseguard headset installed. These are normally very expensive but since this is a JIS headset it was quite cheap on ebay.
Also am using a Campy QR seat binder.
Liked 650 Times
Mounted the XC Sport rollercam set I had new in the bag. Upon opening the bag I discovered Suntour also sent the matching U-brake braze-on studs, which is pretty cool. I'll have to build a bike with these some day. It also came with instructions, including the proper spacing of the mounts depending on the rim being used.
I had to sand down the fork studs about 0.005". They were a bit too thick for the brakes' brass bushings to slide on nicely.
Liked 650 Times
Also installed a Specialized slingshot stem with the matching Specialized X-1+2 riser bars. This is the version of the X-1 bars with a couple more degrees of sweepback than the regular bars. The bars are heat-treated aluminum made by Nitto. Probably the thickest alloy bar I've seen! Don't think these will break anytime soon.
The stem has a set screw underneath that lets you lock the cable hanger in position once rotated to the right angle.
Liked 650 Times
Finished the build today. Drivetrain and brake levers are all first generation Deore XT (M700, aka "Deerhead"). The wheels I got for $20 off craigslist. They were probably stock wheels on a mid-90s Cannondale. They were covered in grime and bird crap but once wiped down I saw they had never actually been used. Brake track was spotless and Shimano red grease still in the hubs. The headset, crankset, seatpost, and wheels are slightly anachronistic, coming from the early-mid-90s rather than 80s, but close enough.
Headset: WTB Greaseguard/Suntour XC Pro
Stem: Specialized Slingshot
Bars: Specialized X-1+2 risers
Grips: Ritchey WCS
Brake levers: Deore XT M700
Shifters: Deore XT M700
Brakes: Suntour XC Sport roller cams
Front derailleur: Deore XT M700
Rear derailleur: Deore XT M700
Crankset: Suntour XC Pro
Pedals: Suntour XC II
Bottom bracket: Tange
Seatpost: American Classic
Saddle: Fujita Belt
Seat QR: Campag
Wheels: AceraX hubs with Sun TL18 rims
Tires: Panaracer/Swift "Ripp Johnson"
Grips: Ritchey WCS
Saddle: Fujita Belt
Seat QR: Campag
Liked 650 Times
The roller cams were not as difficult as I expected to set up. I did not have the Suntour "third hand tool" but you can easily make do with a clamp holding the bottom of the brake arms in so that the brass rollers are set in the correct position. They work pretty well.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
Sweet build.
You have an interesting criteria- most people gravitate TOWARDS the black chrome. IMO- the fillet brazing on the later models is a huge attraction. The High Sierra (and the Cimarron) were such cool, cool bikes. I got mine in 1991- so this was "bike" to me. When I started getting into bikes, this bike imprinted what I think is cool- and I conflated those characteristics with "mountain bikes" instead of the way ATBs were kind of a give and take with touring bikes. I used to lust after bikes like the Paramountain and the MB-1 and MB-Zip- but these mid 80s ATBs had the really cool stuff- the long LONG chainstays, dozens of braze ons for bottles, racks, pumps, fenders... then the top notch wide range badass, yet beautiful components. Mine came with MT-60 Deore stuff- it really doesn't get more understated, yet ballzy.
The parts on there are awesome- XC Pro stuff is the best. I like that you mixed and matched Suntour and Shimano- just like the stock builds. Right now my 87 High Sierra is living with trekking bars- I've done the drop bar thing with them- but it didn't do what I wanted it to do. I was also able to score a set of sealed bearing XC wheels- which would have been pretty close to period correct.
You can get the 3rd hand tool pretty inexpensively... it's just a piece you stick in the roller Allen heads- to hold them 33mm apart.
I hope you really enjoy that bike- it's so cool and has so many cool features- maybe some might consider them evolutionary dead ends- but the roller cams (especially on the front) look so cool- and that lugged unicrown fork- quirky, but it speaks of how fast technology was developing back then.
BTW- the tires look like they could almost pass for the original Schwinn Terra tires!
Commence to jigglin’ huh?!?!
Liked 1,749 Times
Dang that's pretty! And +1 on the brake setup; I just picked up a High Sierra at (get this) St. Vinny's (one of two!), and I just used a piece of old innertube rubber as a "clamp" to set/center them. I love how they work, even with the stock pads. They must rock with those Kool Stop duals.
Any special tricks you used to clean up the rollers? I've got mine de-crudded, but they don't shine like that ^^^^^ . I wonder if even a little baking soda and water on a shop towel might do it without being too rough.
Liked 650 Times
Interesting points @The Golden Boy. I already have a black chrome early 90s Giant, so I didn't want a second black chrome bike (though the Schwinn was made by Giant as well). The real attraction of this frame was the double U-brake mounts. I have a thing for weird brakes (self-energizing Pederson cantilevers going on the next build). I also like the two-tone paint jobs a lot.
Yes, this bike was right before the NORBA craze started to take off and racing dominated mtb design. The last gasp of mtbs as primarily off-road expedition machines. This will be my touring bike. I'm making a custom front rack that will host low-riders and a top section for a basket.
Your point about these bikes having a lot of tech dead-ends is interesting and true. The three that jump out at me on this bike are the roller cams, the Greaseguard caged bearing headset, and the slingshot stem. The roller cams did not live on, although U-brakes are still ubiquitous in BMX and the cam design is used here and there. Greaseguard probably died because cartridge bearings won out, another nail in the Suntour coffin. The slingshot was short-lived, but recently Nitto has been making a chromoly version (V-4) popularized by the Japanese bike shop Blue Lug.
