Just How Critical is Brake Rotor Direction?
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Regardless of the reason - be it technical or esthetic - just how dangerous is it to mount a brake rotor the "wrong" way around? There are rotors from Grimeca with the arrow seemingly pointing in the wrong direction...
And there are some Hope Tech rotors that don't have an arrow at all...
I mean, in both cases, it would probably make more sense to mount the rotors with the "spokes/arms/whatever" pointing forward so that they compress rather than stretch out under braking, but, from a non-competitive, everyday-use kind of perspective, is the direction the rotor is mounted in really that critical?
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I'd assume it would the other way around.
A thin strip of steel would be more stable to stretch than compress.
Barry
Barry
Quoted: 792 Post(s)
Liked 1,494 Times
So, you're saying that, other than that Grimeca rotor above, all arrows on all brake rotors in all the world point in the wrong direction?
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Never said that!
But if were handed a rotor with no arrow markings, I'd go for tension over compression.
But what do I know, I'm and electronic engineer turned IT guy.
Zero credentials in the ways of physical properties.
Barry
Barry
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I don’t think “competitive” vs “non-competitive” makes any difference.
Likes For Kapusta:
Quoted: 792 Post(s)
Liked 1,494 Times
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
FWIW, the Shimano rotors on my bike are opposite of the ones with the arrow in the OP. I'd wage though that this thread is going to turn into a big pissing contest going 20 plus pages.
Likes For Chuck M:
Quoted: 792 Post(s)
Liked 1,494 Times
Except for this and another type of Grimeca rotor (and a couple of Hope models that don't have arrows at all,) every rotor I ever see has its spokes pointing in the same direction as the arrow, just like the Shimano ones you mentioned. Which makes me wonder if Grimeca made their rotors this way by design or someone goofed up at the factory and they didn't think it was critical enough to initiate a recall. It also makes me wonder if Hope's rotors would be fine mounted either way.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
The narcissism of petty differences.
As to the rotor direction. I would bet it doesn’t matter as long as it lines up with the caliper.
Likes For SkinGriz:
Advanced Slacker
Liked 2,537 Times
I assume they have there reasons,
Quoted: 792 Post(s)
Liked 1,494 Times
I've seen remarks being made online about this being/not being an issue dating at least as far back as 2005, but I've never seen any incidents being reported of people losing life and limb because of a backward-mounted rotor. Im fact, I've seen a good number of people - with some comments dating at least as far back as 2005 - stating that they never noticed any difference in braking performance or reliability with the rotor mounted either way. One rider quoted an email he got from Hayes in response to their query about this saying that the direction marking is just for better cooling.
Quoted: 3952 Post(s)
Liked 7,298 Times
The arrow points in the direction that would put the "spokes" in tension during braking. That said, my rotors all mount in the other direction.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
The wrong way it can buckle, the right way it can’t. Follow the directions. Eeesh
FWIW, brakes are way more powerful than legs. Don’t screw around.
Likes For Darth Lefty:
Quoted: 1109 Post(s)
Liked 1,200 Times
Narcissism is a great descriptor.
Quoted: 792 Post(s)
Liked 1,494 Times
Thanks for this! I've been searching for the right description for the ceaseless, stupid, trivial, and mean-spirited arguments that have been going on. I was thinking of words like "no life", "juvenile", "insecure", "grandiosity", "manic" (i.e. the phase of bipolar often showing irritability and grandiosity at once), and many synonyms thereof.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
If you mount them backwards the brakes will make the bike speed up instead of slow down.
It's like riding a bicycle
Likes For urbanknight:
Likes For retswerb:
Quoted: 2483 Post(s)
Liked 2,955 Times
At least one Japanese crankset manufacturer made at least one model with arms that were not tangent to the center of the crank. Every example I ever came across had arms that were in tension rather than compression. My guess about why discs with swept-forward or swept-back arms appeared on the market is the same as it was for those cranks---that someone thought it looked racier that way.
The one benefit to directional arrows on discs is probably the same as that for directional tread pattern arrows on skinny bike tires: consumers asking fewer questions. You have to feel sorry for the crank manufacturer, since the crank can only be installed one way.
The use of tangential arms for discs to offer slightly improved cooling might make sense (depending on the designs being compared), since there could slightly more surface area for a given cross-section. Can't see how the choice of rotation direction would make an iota of difference, though.
Likes For Trakhak:
Quoted: 4227 Post(s)
Liked 2,488 Times
Just follow what the manufacturer recommends and mount them the way the arrow is pointing. The ones without the arrow should be mounted the same direction as the ones with the arrow...It's that simple.
Liked 2,955 Times
Likes For Trakhak:
Quoted: 7652 Post(s)
Liked 3,478 Times
Anyway, i was thinking of starting a thread about the tendency for people (really bad people---like me ) to get tendentious and downright nasty in debates on this forum (as in almost every other part of life ... but ... )
I am on forums where no one would ever use the derision, the disrespect, that I and others sometimes use here .... and how can we all change?
Of course, we all know exactly how such a thread would turn out ..... but it would be popular until it was closed.
Likes For Maelochs:
Quoted: 4411 Post(s)
Liked 4,862 Times
Is it actually dangerous to mount it the wrong way round? I wouldn't like to answer that 100%, but as a qualified mechanical engineer I wouldn't expect it to assplode.
Quoted: 792 Post(s)
Liked 1,494 Times
The problem here is that the OP's disc has the direction arrow opposing the normal mounting convention for disc rotors. It's not made out of some magic material, so it's obviously a production error. I would mount it like any other disc, i.e. ignore the arrow in this case.
FWIW, I have one of those Grimeca rotors in the OP on my bike and I have mounted it the "wrong" way around, i.e. with the spokes pointing forward (and the markings facing inward, just like in the second picture in the OP.)
Liked 4,862 Times
I would think it is all about putting the spokes in tension, which is why they are invariably mounted with the spokes pointing forward. If you mount them that way then the spokes will tend to straighten out under load. If you mount them as per the arrow, the spokes will tend to collapse under load.
If you mount the rotor backwards, does it make it easier to ride the bike backwards?
Likes For BlazingPedals:
