Totally Tubular
#2576
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 228 Post(s)
Liked 293 Times
For those who are using Stans, how are you putting the stuff in your tires? I've tried with the small bottle, and it tends to make a mess. I've seen kits that seem to be a 5cc syringe, a heavy gauge IV cannula, and an extension tube. Are those good for the job? Despite riding sew-ups since the early eighties, this autumn was my first time trying sealant.
#2577
Quoted: 1949 Post(s)
Liked 2,010 Times
I remove the valve core then put the small bottle tight against the valve with very little mess.
Likes For Classtime:
#2578
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 175 Times
#2579
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
I use Orange Seal which is available in a small squeeze bottle with a clear plastic hose that fits over the valve stem. As mentioned above the trick is to remove the valve core first. Also, position the wheel with the valve somewhere around the 3 o'clock or 9 o'clock position when filling so that the sealant inside the tire flows away from the valve.
Brent
Brent
Likes For obrentharris:
#2580
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
I have such a kit, but the syringe is 60cc. The tube screws onto the valve stem. Works well. Just need to clean it well after use.
And I learned a new word. Thanks.
#2581
Quoted: 228 Post(s)
Liked 293 Times
I do remove the core, but sometimes if the tire moves at all, air coming out pushes Stans out of the stem making a mess. I figure the cannula would get the stuff past the stem making this problem less likely.
#2582
Quoted: 228 Post(s)
Liked 293 Times
You're right. It's much bigger. 5cc would be less than 1/5fl oz. Not very useful.
My oopsie.
I do wonder why some of those kits have a stopcock on the extension tube. Consequence of repurposing medical equipment maybe.
My oopsie.
#2583
Bikes: Waterford W-13, Ritchey road logic; Ritchey SwissCross; Pinarello Paris ; Surly Karate Monkey monstergravel hauler 1983 Mike Mullet, mid 80s Alpina, late 70s schwinn world sport tourer
Quoted: 19 Post(s)
Liked 33 Times
I use a syringe and remove the valve core: very little mess
Likes For chain_whipped:
#2586
Bikes: Indeed!
Liked 3,478 Times
Brent
#2587
Bikes: 1981 Bianchi Specialissim, 1976 Colnago Super. 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1
Quoted: 276 Post(s)
Liked 952 Times
I've been using sealant in tubulars with latex tubes for a few years. But I make sure that my tubulars never go completely flat between rides, which is bad for the tubes anyway if the bike is sitting upright on its tires. This only requires me to re-inflate every week or two, which might get to be a chore if you have a collection of 20 bikes but I only have three bikes with tubulars.
Brent
Brent
Likes For SwimmerMike:
#2588
Quoted: 228 Post(s)
Liked 293 Times
While I'm mainly riding Veloflex these days, I do have a few old Conti Sprinters I'd like to marshal into duty as spares. The main issue is that I've never found a good adhesive for sticking the base tape on those. Good cotton tires do well with Val-A Tear Mender. (Trust the Bish!) This stuff doesn't work in any way with the Continentals. Has anyone tried E6000 for this job? Any success here?
#2589
Quoted: 1324 Post(s)
Liked 927 Times
You can buy a basting syringe at a dollar store. The metal needle is small enough to fit inside the Presta valve sleeve once the valve is removed.
Cheers
Cheers
#2590
Liked 2,010 Times
https://www.bikeforums.net/21100877-post1341.html
#2591
Quoted: 228 Post(s)
Liked 293 Times
Maybe try this?
Incidentally, I've also experimented with several high strength industrial neoprene adhesives from 3M, and the adhesion is still poor. Basically, the carcass rubber seems both very slick and impermeable to most glues. Maybe there's a solvent prep that might help, but I've not experimented here.
#2592
Quoted: 228 Post(s)
Liked 293 Times
Here's a question for the peanut gallery: why the hell is Conti glue so damned expensive these days? My old 350g can for which I payed $25 at my LBS is nearly gone. No matter where I look, it seems they want about $70 for the same thing. While it's been a while since I've purchased glue, the jump in price seems unreasonable to me. The tires themselves have gone up a bit, but by a reasonable amount.
#2593
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Can't tell ya, but Vittoria Mastik One is available at $25/250g.
#2594
Liked 2,010 Times
Yep. I used to use Continental also. I’m about 1/2 way through my can of Mastic One at the moment. I’ve been using it on my Continental tires without problems😉
#2595
Quoted: 2588 Post(s)
Liked 4,824 Times
The rims are Mavic Reflex SUPs with machined sidewall treatment. Compared to vintage tubular rims (on which the braking surface is a mere suggestion), the machined track is a game-changer.
I found them on Ebay, from a seller in Australia. They pop up from time to time. Good luck in your search!
DD
Likes For Drillium Dude:
#2596
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3193 Post(s)
Liked 1,842 Times
It was covid time and affordable spokes were like hens teeth. I had a tubular repair build (two broken spokes side by side on the same ride, used, mismatched build at that). The calculator calls for 296 and 298, and toward the end of that madnness I was able to find a box of 298. Figuring I would build both sides with this length. What say you members of the totally tubular thread? Mavic Monthlery Pro with Campagnolo Record. Just this afternoon I got it taken apart. Now that it's written down I realize I could potentially nip 18 of those spokes if necessary. I'm thinking it's not necessary.
#2597
Quoted: 228 Post(s)
Liked 293 Times
#2598
Liked 1,842 Times
Some of you have probably seen my 1971 Bianchi build - Bike Forums. Several years ago, I found an add on CL a batch of NISI TORO rims.
Fopr the Bianchi, I finally purchased spokes after years of procrastination. Did the measure of ERD to be sure as I could not find specs for the NISI.
Built them up last week and will mount 25 Vittori Corsa G+ on them. They are not glued in the pic.
71BianchiFWTruing on Flickr
#2599
Quoted: 228 Post(s)
Liked 293 Times
In my case, I'm riding Veloflex, but it's more a matter of wanting to stick with a known quality, and not wanting to need to take the rims down to bare metal or change toss tires previously glued with Conti if I patch them.
#2600
Liked 1,842 Times
My weight fluctuates between 180 and 195, but I don't know that it has any bearing on my 'ride requirements'. My riding style demands a planted rear end, and a front end I can lean on, plus I take a lot of feedback from the road surface into consideration when I make moves. All of this requires a hard-blown set of tires with which to transfer the info to my hands, feet, and butt. Sounds funny, but it's true. Low pressures induce a feeling like being on a pogo stick, and the feedback is mushy and inconsistent; I cant plant the rear end, much less do anything with precision regarding the front end, with tires performing with too much bounce/rebound.
High pressures do allow the occasional skipping of the rear or front tire, but again, feedback is such that I know when it's going to happen, and reflexes compensate. Like catching a moment of oversteer in a car.
The Alpina was fitted (unknowingly) with the aforementioned Elites, and taken up to 115psi, which was still squishy and ponderous-feeling, when someone here noted the sidewalls said the pressure was limited to 105psi. First time I noticed the rating didn't match the ad copy, and I couldn't imagine the feeling if I were to let out 10psi.
Anyway, those are still on the bike, but I didn't bring it with me and it won't see much use (now a zero bike in WA), for good reason. The 'cushy ride' many describe when running tubulars at lower pressures simply translates into 'bouncing' for me and my sensitive contact points. I know I'm an outlier
DD
DD
Likes For seedsbelize2:
