Front XT Derailleur not moving unless pushed by hand
Hi folks
I’ve sprayed wd40 on a front XT derailleur that wouldn’t move at all. I can now move it but only by pushing it in by hand. Do you think i just need to wait for wd40 to loosen the mechanism more or is there something else I need to do?
I should add that the shifter will tighten & loosen the cable (perhaps not enough?) and move the derailleur outward but not inward.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
WD40 is not the best penetrant. Try a penetrating oil, and then keep working it. It may also just be too corroded to repair.
Some auto mechanics make their own penetrating oil with a mixture of acetone and ATF, but I've never tried that.
Likes For andrewclaus:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
If the derailleur moves by hand, but not with the shift lever, it suggests that the problem may be friction in the cable. Disconnect the cable from the derailleur and see if the cable moves freely with the shift lever. If it's stiff or stuck, replace the cable and any housing with new cable and housing.
Likes For JohnDThompson:
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Hi folks
Stuart Black
Stuart Black
Clark W. Griswold
Quoted: 4361 Post(s)
Liked 4,002 Times
If your shifter is not functional make sure you have enough cable tension and that the cable is in good shape. Honestly if you are having issues replacing that is a good way to go to give better shifting performance. I had a front derailleur in the shop recently that someones bike neighbor couldn't get moving, with a few shots of PB Blast and some adjustment to cable tension it was moving again. WD-40 is a water displacer it has some lubricant in the carrier solution but it isn't really a great lubricant and penetrating oil, it can be used in a pinch if you are desperate and have nothing but is not ideal for that job in the slightest.
Regardless of anything new quality polished stainless steel cables and good stiff housing will improve braking and shifting performance without costing a ton of money and if you get the Jagwire Pro and Elite kits you usually have extra bits and bobs for future repairs and replacements.
Quoted: 366 Post(s)
Liked 274 Times
I just wanted to add the obvious - the cabling on any bike part (shifter or otherwise) merely moves the control to a more ergonomic location. That's all the cables are for. Any cable actuated bike part will function 100% moving by hand without the cable. Granted, sometimes the controller adds a forceful cable pull or indexing, but the point remains.
