Finally grabbed a Schwinn Le Tour 1980 12 Speed
I've been slowly looking into grabbing a bike for a daily commuter/random bike. This bike was $125 which maybe on the higher side I'm not 110% sure but it is what it is!
Bike includes Sakae handles, Siguno crankset, Dia compe, Suntour, & Weinman Rims
The only issue is the front tire is flat and doesn't hold air.
I plan on getting it serviced and probably changing the wheels and get whatever else needs to be changed out.
Pictures are below
Pictures are below
Bikes: 2014 Fuji Cross 2.0 LE, 1993 Santana Vision, 1993 Specialized Allez Pro, 1993 Trek 930, 1985 Panasonic DX3000
Quoted: 49 Post(s)
Liked 75 Times
That should be a fun project. Looks like several areas will need attention, but it will make you knowledgeable for future buys. Have fun, and keep us posted on your progress.
Thanks kermie! Definitely plan on learning more about the bike and taking care of it. looking forward to posting progress
Quoted: 1830 Post(s)
Liked 3,383 Times
Was this generation of LeTours closer to the weight of their competitors? I had an early LeTour, which was a nice bike for the late 70's, but in retrospect, the frame tubes were pretty chunky (i.e. the tubing had thick walls).
With some penetrating oil, new grease, etc., this LeTour should do quite nicely!
Steve in Peoria
Steve in Peoria
Likes For steelbikeguy:
Likes For Mr. 66:
Likes For kermie:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 700 Times
Yes, yours is a later year and better. I snatched a curb find 1980 Letour many years ago. My son has it now. It was lower quality tubing and steel wheels. Interesting historical story on the 1980 model is it was brought back from Japan manufacturing and made in Chicago for perhaps that one year. It actually rides decent considering the lower quality steel and the steel wheels. Yours is a much better find and will serve you well. Have fun.
Likes For sd5782:
Freewheel Medic
Quoted: 1455 Post(s)
Liked 2,197 Times
Keep in mind that if you are having it serviced by your LBS, they will probably want to simply bin your freewheel. If you are running the Accu Shift RD on index shifting, there's no modern freewheel that is fully compatible. The Suntour freewheel should be saved, serviced, and reused.
Can you post a close-up picture with the wheel off the bike in order that I can better evaluate its condition?
Bob
Bob
Likes For pastorbobnlnh:
Quoted: 1821 Post(s)
Liked 1,697 Times
Likes For alcjphil:
Good advice. It would probably be a good idea to earn how to service the bike yourself if you can. If you do take the bike in, before you do give it a thorough cleaning. From my own experience working in bike shops one thing we all hated was working on a dirty bike and we would charge extra to clean the bike before we worked on it
Likes For RidingAroundCT:
lurking nightrider
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Likes For LittleGinseng:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,009 Times
It looks like a 1988 Le Tour. There should be a four digit number stamped into the head badge. The first three digits are the day of the year, the last is the year. Mine is 0888, so March 17, 1988 if I counted the leap years correctly. They were built by Schwinn in Mississippi. I rebuilt my wheels with wider rims to make it easier to mount the tires. It weighs about 25 pounds, which is where most of the sport touring competition was. There is not a lot of love for the Sun Tour AccuShift, but I didn't have any issues with it. Even with a triple crankset and a mountain bike derailleur, it worked well.
1988 Le Tour
Here is a link to the catalog page:
https://bikecatalogs.org/SCHWINN/1988...LL/1988_12.jpg
1988 Le Tour
Likes For Pompiere:
1988 Le Tour
1988 Le Tour
Freewheel Medic
Liked 2,197 Times
RidingAroundCT unfortunately my eyes are not good enough to do a proper evaluation of thumbnail sized pictures. The best I can tell you is to confirm it is a Suntour Accu Shift model freewheel. In one photo it appears to be rusty. How does it feel when you spin the sprockets? Smooth, gritty, stiff, catches in places?
I would service and preserve your freewheel. Searching ebay only finds two Accu Shift 6-speed freewheels, and both are pricey. Most Accu Shift freewheels that I've worked on were 7-speed models.
Bob
Bob
Freewheel Medic
Liked 2,197 Times
I'll just add one here in order that others don't need to jump through the hoops.
While a bit tarnished with a tattered finish, overall, it looks to have had little use. It is a great candidate for cleaning, lubrication, and service. Don't let the LBS throw it away for a new one.
Bob
Bob
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Likes For SurferRosa:
I tried this earlier today and they each remained small. This time I asked my browser to open your pictures in a separate link and then had to double click them to enlarge.
An ‘80s bike for sure but yes late ‘80s! Definitely going with the 1988 suggestion. Headbadge code and frame # will provide more info. Depending on date of final assembly (headbadge) it’s possible that the frame could be from the previous year. Also, if the the final assembly was late enough in the year, the bike could be part of the next year’s model lineup. I think that, with Schwinn bikes, catalog photos are the final confirmation.
I do have a 1980 LeTour and agree that the OP’s LeTour is a much better bike! Being one of the last “Chicago Schwinns” does give the 1980 LeTour some degree of “desirability” tho .
I also have a 1989 LeTour which is quite similar to the OP’s ‘88 model. It too, has the Sun Tour AccuShift groupset but in 1989 it was labeled “Blaze”. Glad to learn that I should definitely keep the OEM freewheel and recommend that the OP heed that suggestion made by others too. Freewheels aren’t that hard to rehabilitate and if the teeth show minimal signs of wear/abuse, should perform well.
The ‘88 LeTour is a nice looking bike and if it performs anything like my ‘89 model, will be a nice ride too!
Likes For sovende:
Thank you for the info and honestly thank everyone for all the details and help I appreciate it. I'm away on a business trip today through next Thursday but once I'm home ill definitely do some looking for a serial.
Also a few questions (warning they are silly)
1. Are these tires (ones that aren't flat) ok for commuting and general riding?
2. Can this bike safely pull a trailer? I think it can but my wife wants some others to chime in, who know. I'm looking at a trailer like this https://www.ebay.com/itm/18547440274...mis&media=COPY
Quoted: 49 Post(s)
Liked 75 Times
To the tire question, if it were me, I would buy new tires and tubes. Rubber does degrade over time, so you want to keep it reliable. As to the trailer, Im sure it would be fine, but someone with experience with the bike could better answer that one
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 874 Times
The trailer will add weight which will work against the brakes. How old are those brake pads? If you are going to pull this trailer in wet or rainy weather Kool Stop brake pads will greatly improve stopping.
If you are in a hilly area, you may find the gearing a bit high for uphill work. The trailer will make that worse, if it is heavy.
Likes For daverup:
