Is this classed as a "Horizontal dropout"?
Quoted: 21 Post(s)
Liked 9 Times
So I have this Raleigh bike and to me these dropouts look horizontal, but they are slightly slanted. What would these be classed as?
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Yes, that would be a "horizontal" dropout.
N.B. the quick release in your picture is intended to be used with vertical dropouts and may not clamp firmly enough to prevent the wheel from pulling out of alignment on a horizontal dropout. Consider replacing it with a traditional enclosed-cam quick release.
Likes For JohnDThompson:
Quoted: 21 Post(s)
Liked 9 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
The late Sheldon Brown's website has a page with an explanation of the various dropouts and an excellent diagram showing the differences between them. The diagram is found not quite halfway thru this page:
https://www.sheldonbrown.com/no-derailers.html.
For the reasons noted in the other Sheldon Brown page cited above, you really should use an enclosed-cam skewer with that type of dropout.
I’d add that having the lever in the position shown in the photo increases the risk of it being inadvertently flipped open if caught on something while riding!
Quoted: 21 Post(s)
Liked 9 Times
As others have said, that's indeed a horizontal dropout. It looks to be the short version; can't tell if it's stamped or forged from the photo.
Quoted: 4211 Post(s)
Liked 3,880 Times
I will disagree with this statement. The most easily snagged position for a QR skewer lever to be at is when is points away from the stays/blades. For a front wheel this means pointing forwards or down. For a rear wheel down or rearwards. Having the skewer lever run parallel or slightly crossing the stay/blade reduces the ability for something to snag the lever as the frame acts as a guard of sorts. Additionally if a rear QR lever is positioned running rearwards the rider behind you might not like having their ft wheel trapped between yoiur lever and rear wheel when you slow down faster than they do and they overlap wheel with you.
I generally position the lever to run parallel to the blade or stay, just off enough to easily grab with you hand but not hanging out like a hook looking for it's fish. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Old fart
Liked 3,401 Times
The larger radius of the open-cam design has less mechanical advantage than the traditional enclosed-cam design. The wheel can't shift out of position in a vertical dropout, so less mechanical advantage doesn't matter.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Turns out the number one reason for through axles on new road bikes is people on Bike Forums saying, “Your skewer is wrong. It’s the wrong kind of skewer, the handle is pointed in the wrong direction, it’s on the wrong side of the bike, it’s too far back or forward, it looks like it’s open, just think what would happen if you were riding this very old ten speed bike in a peloton and had a crash… but I don’t need lawyer lips on my fork.“
Likes For Darth Lefty:
Liked 3,880 Times
While I still believe that having the lever pointing to the rear is "best practice" (and I believe it's the way the designers intended), I can see some validity in your method IF the tip of the lever crosses the blade or the stay as that would offer some level of protection from a branch snagging the lever and popping it open. You lost me tho on your description of how the front wheel of a rider to the rear would somehow manage to wedge itself between the rear pointing QR lever and the rear wheel and pop the lever open. In a tight peloton of highly competitive riders, I would suppose the situation COULD present itself but for the majority of the rest of the cycling world, I doubt it. For the record, the position of the lever in the OP's photo does not seem to meet the description of how you describe the best method and I stand by my suggestion that it could be subject to being popped open if snagged by a branch! There's no need to start a "range war" over this issue so we may have to "agree to disagree"!
Two shots of my station wagon bike QEs. The rear could be a few degrees more up and parallel to the chain stay. But I think my preference is shown well. Note that the skewers are steel and enclosed cams even though I built this frame with vertical drop outs. Also note the lack of front dropout retention lips. Only my disk braked bikes have them. Andy
AndrewRStewart
AndrewRStewart
Quoted: 3514 Post(s)
Liked 2,927 Times
Quoted: 4806 Post(s)
Liked 3,932 Times
Actually it is more among the non pros that wheel overlapping, and the risk of that point rearward QR lever acting as a hook or latch, that is likely the greater concern. Any one who hasn't ridden up the backside of the rider who they were following (drafting if at speed) doesn't yet have that school of hard knocks pig skin. If the QR lever is pointing rearwards it will prevent the front wheel of the rider behind you from easily steering out and away from you. Generally the pros have had coaching and mentors to heed from, besides their pack riding skills are far more practiced. Gym strong locals, who think riding a trainer or spin bike is great training, are a whole 'nother issue with club packs.
Liked 3,932 Times
I bet it has happened. You'd be surprised what you see if you do not own a car, live where distances start at three miles and there is no public transportation. (And you live in a place of real weather.) I didn't own a car until my early 30s. I've ridden in storms more than a few times. I build and mount my front wheels inside spokes pulling because I fear that branch wedging between wheel and fork. Fallen branches have taken me down but so far, not by opening rear facing front QRs or jamming in my fork.
Liked 2,927 Times
I place my rear QR facing forward over the stay so I can use the stay for leverage, squeezing the stay and the lever together.
Quoted: 1110 Post(s)
Liked 1,204 Times
For the rear lever, I've always set it in the triangle/V of the seat and chain stays, kind of "tucked" in there.
I guess I've always assumed that the tendency to set the levers horizontal and rearward came from mountain biking? I don't think I ever saw it on a road bike until MTB entered the scene?
But I'm an old guy who is, in regard to QR skewers, stuck in the way it was done in the 70s. Dumb, I know.
Likes For Camilo:
Quoted: 1821 Post(s)
Liked 1,697 Times
After reading the last posts about quick release levers I think I will go check the ones on my bikes to see if I am doing things the right way
Likes For alcjphil:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Hi, 90’s MTB guy here:
Generally, on a rigid, it wasn’t a whole lot different than a road bike, but often we’d run the front lever on the right, so you could put it vertically behind the fork blade. (Especially East-Coast woods bikes)
Rear QR would usually go inside the triangle, just above the chainstay, so the lever tip would be “in the shadow” of the frame tubes. Oversized chain stays and chunky dropouts sometimes prevents this, but straight back was usually the last resort; you don’t want anything unnecessarily sticking out, in any direction.
Likes For Ironfish653:
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
I’ve personally seen a rear (external cam) QR shoved open mid ride. Exactly as described above. Two I experienced riders in close formation. Front one slowed suddenly for a car. Rear rider overlapped wheels and turned away to the left at the last minute. It swung open the rear QR of the rider in the front. Fortunately it was a vertical dropout bike, so nothing catastrophic happened. The front rider felt something off, and slowly came to a stop to fix the issue. This could also get a front QR that was forward facing, though you seldom see that.
I’ve also seen a front QR open, though the bike was static. Bike parked at a bike rack. Someone else trying to force another bike into a not big enough space, and opened the backward facing front QR. Easy enough to find if you do a basic pre-ride check, but less so if you don’t.
I put my front QR parallel to or just behind the fork as shown above, depending on QR type and handle shape. The rear I tuck between the stays.
