Stop grips from twisting?
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
as the tittle said, how i can stop grips from twisting?
i have those https://fabric.cc/products/grips/sil...slip-on-grips/
for now i have installed some zip ties but honestly the aestetics of ziptie bother me a lot.
do you use something between the handlebar and the grips? any hack?
Really Old Senior Member
One trick is hair spray. it's slick when wet to slide the grip on and then sets like a water soluble "glue" when it dries.
Likes For Bill Kapaun:
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
I would recommend hair spray as well but I would also just use lock on grips specifically Ergon grips but only because they are the most comfortable grips I have ever used. I hate dealing with slip-on grips especially after years of them sitting on a bike having to try and get them off.
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Hair spray does a good job most of the time. For foam grips (like ESI), I find that the hair spray gets absorbed into the foam too quickly, and the last inch or so of the grip is a beast to finish. Hair gel, however, works great!
Habitual User
Liked 8,099 Times
Slice them down their length with a razor blade (don't cut into the bar, though!), and peel them off. I consider slip-on grips sacrificial from the start.
Likes For Eric F:
Clark W. Griswold
Liked 4,001 Times
Oh I know, I have done that enough either that or use a nozzle on the compressor system and some liquid usually isopropyl but sometimes a cleaner of some sort but I just hate doing it.
Likes For veganbikes:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12782 Post(s)
Liked 7,696 Times
many grips will stick after cleaning the bar and inside of the grip with isopropyl (put a couple capfulls in the grip, close off any openings and shake vigorously, then slide onto bar, let dry)
If no joy, hairspray can help.
If still no joy, I know some people used to resort to spraypaint (sounds messy)
I'd shop around for some clamp on grips you like, so much easier
Quoted: 333 Post(s)
Liked 168 Times
The default one were the dame brand as the bike. Never had any problem and they were very stable. Next i used those lock on, can't remember the brand but they had lots of lamellae very helpful during summer for the sweat but i think they lasted 2.000kms... until i decided to use the ones I mentioned above. The lock on with bolts yes they were stable but i had to cut down all 4 bolts because they were very oxidated and stuck as heck.
Clark W. Griswold
Liked 4,001 Times
Quoted: 1562 Post(s)
Liked 1,734 Times
Lock-on grips are common in BMX:
https://www.danscomp.com/grips-bar-e...e-parts/c16404
Quoted: 2488 Post(s)
Liked 2,957 Times
Many don't believe it, others are too wary to try it, but the solvent (kerosene?) in WD-40 melts the grip, resulting in a good bond. I always preferred that method to the sticky, smelly, messy use of hair spray.
Quoted: 503 Post(s)
Liked 436 Times
Grips, like tyres, often seem to have some mould release residue on them which can be cleaned off with soapy water or alcohol.
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
I second or third or whatever using hair spray. White Rain in a pump bottle works for me and is exceedingly cheap. I just used up my first bottle of it a couple of years ago. I bought it in the 80s. Pretty good value for $1.29
Stuart Black
Stuart Black
Likes For cyccommute:
Clark W. Griswold
Liked 4,001 Times
They are simple to get off. Slide something under the grip…I use the 2mm allen wrench from Park because it’s the least used allen wrench in their set…and spray some alcohol or water or just about anything water based in there. Remove the allen wrench, twist the grip a few times until it loosens, and the grip slips right off.
Quoted: 1034 Post(s)
Liked 1,292 Times
Old MC riders used to wire their grips on, as did some old MTBers. I used to run some A'me grips with grooves for the wires, but I never did the wire thing.
Getting them off is a nonissue, since you can cut them off if necessary.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I just stick a piece of medical cloth tape to the handlebar ahead of putting the grip on. A piece is enough to prevent the rotation. If you put too much it may get hard to take the grip off.
Liked 4,221 Times
There’s no grip harder to get off (or on) in my experience than ESI Chunkys. The alcohol or water under the grip works quite well on those. I also take grips off bikes at my co-op regularly and haven’t found any that can’t be removed with the method I describe above. Even the ones that are sticky with age.
Stuart Black
Stuart Black
Clark W. Griswold
Liked 4,001 Times
Bikes: everywhere
Liked 7,696 Times
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I just use rubbing alcohol and ESI or Wolftooth silicone grips. They set up in about an hour and stay put thereafter. You can shoot some Dust-off compressed air under the grip to accelerate the evaporation.
Quoted: 503 Post(s)
Liked 436 Times
There's a lot of dirt bikers will disagree with you, although it's normal to put two turns of wire around the grip before twisting it tight. Put the twists where they're not going to snag your hand, cut the tails so there's three twists left, and tuck them in well. It works.
Quoted: 333 Post(s)
Liked 168 Times
update: i used the hair spray and seems work! can't wait to test it during a ride..
dang it! hair spray on the grips sound so funny but that's an amazing solution,,,,
Likes For CrowSeph:
