Peugeot ID?
Peugeot ID?
I’ve had this bike for a few years now. It was painted when I bought it. Trying to find out exactly what I’ve got and to figure out correct decal set. The only info I have is the numbers on the bottom of the frame:
2926873
UE8M 6C (I think it’s a U)
Any ideas?
If I did this correctly, this should be the photo album where I have uploaded pictures: 24159151 (won’t let me post directly…)
2926873
Any ideas?
Forum Moderator
Quoted: 3093 Post(s)
Liked 6,612 Times
Forum Moderator
Liked 6,612 Times
Likes For rats_rod:
SE Wis
Quoted: 2747 Post(s)
Liked 3,403 Times
That looks a lot like it, my front badge is different. It’s black plastic with chrome outline. Could the previous owner have switched them out?
UE8M size 60, here’s one listing for similar bike in it’s original livery:
https://foresthill-md.americanlisted..._28201527.html
Likes For gesta:
SE Wis
Liked 3,403 Times
Bikes: Fuji Sportif 1.7C, Shogun Metro AT, Jamis Durango SX, Miyata Alumicross, Fuji Special Road Racer, Mongoose ATB, Fuji SST 1.0 Team, Gitane (?), Specialized Rockhopper SS, Univega Gran Turismo, Univega Supra Sport Mixte, Nishiki Tri-A, Diamondback Coil
Quoted: 82 Post(s)
Liked 141 Times
Nice bike, at any rate. Looks well-sorted.
Quoted: 478 Post(s)
Liked 634 Times
Appears to me that the new paint was applied without much (or any really) prep right over the original colours. Bet you could simply do some work with some cleaners and mild abrasives to expose the original paint and likely the original decals. I assume you would be repainting before applying decals so its a step you would likely take anyway. Unless you want to keep it black, in which case why not use whatever decals you like the best?
Forum Moderator
Liked 6,612 Times
Quoted: 4722 Post(s)
Liked 3,039 Times
The sticker and headbadge point to circa 1982 but the bicycle looks older. There should be a serial number on the non-drive side rear dropout. That should tell us the exact manufactured date.
Liked 3,039 Times
T-Mar Isn't the serial number on the paper sticker in the photo of the bottom bracket? Or do you suspect a mismatch?
feros ferio
Quoted: 1393 Post(s)
Liked 1,332 Times
When did Peugeot switch from the riveted plates of the early 1970s to the BB shell stamp on my 1980 PKN-10?
Liked 3,039 Times
Yes, that's the serial number. If transcribed correctly, it indicates that the frame was built during May 1983 at Peugeot's Romilly Sur Seine facilty. However, I wouldn't rule out the "3" actually being a poorly stamped, partial "8", which would make it 1978.
Liked 3,039 Times
I've seen the riveted S/N plates on some 1976 models produced in very late 1975. I've seen the frame stamped serial numbers as early as 1977 models. It looks like the turnover occured sometime during 1976, for at least one of the Peugeot facilities.
Quoted: 3815 Post(s)
Liked 3,348 Times
between the two possible dates mentioned you may be able to narrow it down by checking some of the fittings for possible date markings -
barrels of the Normandy Sport hubs
backside of the Weinmann brake calipers
RIGIDA SUPERCHROMIX wheel rims - look for a two digit number inside a small diamond symbol
portion of handlebar stem down inside steerer
right end of handlebar
underside of Simplex Prestige front gear mech
backside of Simplex rear gear mech
pedal barrels
gear block
pedal barrels
gear block
