My luck can't be that bad, can it? Can it???
I get it now. I totally understand why some of you guys carry a small pump instead of just relying on CO2.
I went for a fairly short ride today, about 20-ish miles. My route is effectively a T. I leave my house, ride out to the highway, about six miles, then turn right for about four miles to my turn around point. I then ride back, past my T intersection, about another four miles to my second turn around point, then back to the T intersection and head home. Easy enough. Total ride is just over 20 miles total. It's one of my "easy" routes.
But today was not my day. Before I left, I aired up my tires to 90psi. This bike had been sitting a couple weeks and they were feeling a little soft, better get ahead of problems, right? Only prudent. So off I go. I make it to my T intersection and make my right turn. I'm about half way to that first turn around and the rear tire is feeling kind of weird. Stop to check and sure enough it's almost flat. WTH??? I pull it off and look but find no signs of a puncture. I carry a spare tube and two CO2 canisters in my tool bag. Swap out the tube, put the tire back on and air it up.
At this point, I'm wondering if I should err on the side of caution and cut the ride short, but this is a short ride anyway, so damn the torpedoes, full speed ahead! I get to my turn around and head the other way. I get to my second turn around and head back towards my T intersection. Is that back tire feeling soft again? Can't be! Pull over, sure enough, it's almost flat again. But I don't have another spare tube.
I do have a second CO2 so I release what little air is in that tube and check for pinches (I did this before I aired it up the first time). I don't see any pinches so no idea what's going on. This tire now has my undivided attention. I check my CO2 charger and surprisingly it still has a little gas left in it. Not much but I'm guessing enough to get a 23c up to maybe 50psi. I ride a little further. I get to my T and the tire is flat again. Swap out CO2 cartridges and air it up all the way this time. That one got me almost back home, but had to stop again and thankfully, I still had just a bit of a charge left in that second cartridge, enough to get me home.
I had other stuff going on here at the house so I haven't had time to check either tube to see what's going on, but I definitely see the advantage to having a small frame mounted pump for just such instances. Damn good thing I wasn't on one of my longer rides that might have put me 30 or 40 miles from the house.
Frame mounted pump added to my Amazon list.
Likes For VegasJen:
Quoted: 3952 Post(s)
Liked 7,297 Times
I don't think the problem was CO2 instead of a pump, it was not checking the tire to find out why you were losing air.
Likes For tomato coupe:
Quoted: 1109 Post(s)
Liked 1,200 Times
I carry one CO2, one tube, one mini pump and one little patch kit. I'll bet the patch kit doesn't take up any more space than that second CO2 and is a lot better when the chips are down. Also, did you carefully check the inside of the tire for whatever caused the flat?
Likes For Camilo:
I did. I generally find a wire or cut or some such thing to explain why I have a flat. Not this time. I spent several minutes on the side of the road, running bare fingers on the inside of that casing, feeling for anything that might be stabbing the tube. Nothing found. At least not then. I'll spend some time this weekend and investigate more thoroughly and report my findings.
I do have very good luck patching tubes at home using old tube patches and rubber cement. Probably better than 90% success with that. But that doesn't do me much good when my verified spare tubes are in the garage and I'm stuck on the side of the road, does it?
Likes For VegasJen:
Liked 7,297 Times
Liked 1,200 Times
Probably because of my own inability, I've never had much luck with those roadside patch kits. I haven't figured out why.
But I agree, it's a royal pain to patch a tube on the side of the road. If it's raining, worse yet. If it weren't for the fact that it's been many, many years since I had two flats on the same ride, i'd probably carry two spare tubes and put the roadside patch even further down the list of interventions.
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
The second one, a similar piece of glass had worked its way all the way through the casing and was lying on the inside of the tire when I pulled the tube out.
So far this year, what with all the rain, I've managed 4 outdoor rides, and flatted on 3 of them. One was supposed to be a quick spin around the neighborhood to try out a new saddle for position. Just 2 miles. Who needs a pump and a spare tube for a 2 mile ride?
Liked 2,971 Times
Wait until a wire bead tire decides to poke its' metal wire inward. Defective tires get me more when everything is new, compared to road debris.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 966 Post(s)
Liked 1,629 Times
Yep... And ya do carry a spare tube... Before I went to Continental Ride Tour tires I was getting flats every now and then. I don't carry a spare tube but still think I should. I do carry a small hand pump, and a Mini Patch kit in which I have added an unopened tube of Super Glue along with the vulcanizing cement, tooth pick, razor blade, and a scab patch. I prefer the Lezyne type mini pump. Its not much bigger then your CO2 device. Ha... Ya probably won't get another flat for years to come. Also, some times with flats it's just your turn...
Amazon
Amazon
Quoted: 896 Post(s)
Liked 2,064 Times
With a pump and patch kit, you can fix a lot of flats. Adding n tubes makes the first n repairs quicker. Same for CO2. But ride long enough and far enough, you'll hit n+1 flats.
The pump also lets you inflate the punctured tube, to find the hole, as many times as necessary.
Glue less patch kits can be a lifesaver when you run out of spare tubes on a ride. I've had the situation of having mystery flats on a ride & went through all my tubes. The glue less patch kit takes up so little space & can make the difference between getting home under your own power vs being stranded in the middle of no where. The mystery flats were caused by rim tape failure. Although the wheelset wasn't used as often, it was older & the rim tape had deteriorated due to age. Once I replaced the rim tape, no more flats. So if there is no evidence of glass or any other debris causing flats or snakebite marks....then inspect your rim tape carefully.
Just another caveat. If you do use glue less patches on a ride, be sure to replace it with a real patch after you get home. Glue less patches are only a temporary fix & are not meant as a long term fix because from my own experience they will eventually fail sooner than later.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2582 Post(s)
Liked 5,639 Times
Ran into a guy with a flat last summer and offered help. He told me he was 25 miles from home and already had 3 flats. Used both spare tubes and his only patch and now was SOL. I was riding one of my tubeless bikes and remembered that I had a new patch kit in my saddle bag (which was now useless to me). I gave him the kit and wished him better luck and told him to sweep in the inside of the tire with his fingers.
I run both tubed and tubeless road bikes. I only do short hauls (less the 40 miles) on the tubed bike because I hate repairing flats. Over 8000 miles on the tubeless with zero flats, but I live in the country with little broken glass and crap like I used to encounter in the city.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Liked 2,971 Times
I like running TL, but I still carry a spare tube, a HD patch kit that can serve as a tire boot, & some spare sealant (that I replace annually) . The sealant has been all I've used up so far in the event of a PSI loss. Once below a certain PSI, I pick out the debris, I dump in the sealant & air it back up.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Amazon
Amazon
Quoted: 4227 Post(s)
Liked 2,488 Times
Always carry a pump and always carry more than one spare tube. Don't rely on C02.
Likes For wolfchild:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
"My luck can't be that bad, can it? Can it???"
Luck falls to those prepared to receive it.
You have a lot to learn and an attitude that prevents you from doing so.
Not a great combo.
Not a great combo.
Quoted: 2975 Post(s)
Liked 1,182 Times
Get yourself this patch kit. You'll never mess with old school glue patches again after using these.
https://www.parktool.com/en-us/produ...patch-kit-gp-2
Quoted: 8280 Post(s)
Liked 9,042 Times
Likes For big john:
Indeed.
Quoted: 2604 Post(s)
Liked 1,933 Times
It's not that your luck was that bad, it's just that your time to learn that lesson came. Pump plus patch kit will (almost always) get you to the end of the ride.
Almost always? Like Troul, I've had the wire in a tire break through to the inside. I was over-prepared for my first tour, and went through four (4) tubes before I figured out that rough spot on the tube correlated with a busted tire. Fortunately I had a spare tire with me...
Likes For pdlamb:
Liked 2,971 Times
-Oh Hey!
-Oh Hey!
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 915 Times
PRO BIKE TOOL has apparently made their mini pump even mini-er. It is now about 6 inches long, where the original was about 10 inches long. It has a gauge, does presta and Shraeder, and the bigger your tire, the more you benefit from the longer stroke, so I found another of the longer ones on ebay.
