Goofy Glasses: Look like a **** but get down long and low with no Neck Pain
#376
Quoted: 3952 Post(s)
Liked 7,297 Times
#377
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,898 Times
In order to remain fit and slim, I think it helps to reduce frontal surface area, by keeping your back fairly level to the ground (requiring, if you wear spectacles, goofy glasses, or a craned up neck).
I did a Google image search for your Canyon Endurace and took screen-shots of the thumbnails where people were riding *on* the saddle.
It seems to encourage are more "relaxed" position, since after all it is a longer distance bike, "endurance" bike but some of the riders are riding aggressively. Bikes like this seem to encourage bursts of aerodynamic riding rather than riding aerodynamically for a long period of time.
Canyon Endurance
I think that the smaller drops of modern pro-peloton bikes tend to result in the same thing. I would love an Endurace. I would slam it, put non compact handlebars on it, and negatively angled stem, and ride for about three hours a day, looking out of the tops of my goofy glasses.
Canyon Endurance
#379
Liked 11,898 Times
Also, the thing about shallow drop bars is that it they allow you do get more aerodynamic than deep drop bars, because you can ride with a level back and level forearms, vs a level back and vertical forearms on deep drop bars. See the article that I posted above, which others posted to you earlier, where people actually tested different positions rather than hypothesizing.
#380
Liked 11,898 Times
Nope. Endurace CF SL 8 Disc and Ultimate CF SL 8 Disc are the same price - $3K.
#381
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 404 Post(s)
Liked 85 Times
Sweet
My Look KG 386 is a bit aero (semi-internally routed cables, rear wheel cut out, shaped tubes -- but perhaps not wind-tunnel tested) but my Trek is not. I would like to try a full-aero road bike but embedded cables, especially through even the stem and head tube, may make for more fiddly maintenance so I think I would need to get generally richer, so that I could employ bike mechanics before I splash out.
But I spend zero time in a pace line, so my sphinx with level forearms, or drops at 45% forearm, or hooks at similar, are okay for me. Forearms are important but torso angle is imho far more important, (since torsos have far more area than forearms) so I want the bike that lets me ride level torso (in a variety of more or less aero forearm positions) for as long as possible.
Tim
#382
Liked 11,898 Times
If I get rich I may buy one. While frame aerodynamics make only a few percent of difference, I bet it feels great to ride. And, according a page that was showing Nairoman's Ultimate, "Professional road racers tend to select frames 1 to 2 sizes smaller than the recommended size by the manufacturer," So I would probably get an S looking like this
Sweet
I remember the article from before and it is very true. At the same time, I find level forearms in the drops or holding the hooks to be tiring. It seems to me that the trend is towards walkie-talkie-connected, super-coordinated pace-lines where the pole rider gets into the mega-aero, level-forearmed, hook position for 10-12.5% of the time (assuming a 8 to 10 person team). Super.
Tim
Sweet
Tim
#383
Quoted: 404 Post(s)
Liked 85 Times
I have determined how low I can go in terms of bar drop and it's about 10 cm. I had a bike with an 11 cm drop, and it was okay for 20-30 mile rides, but after a 60 mile ride - even though I wasn't uncomfortable on the ride itself, I was getting lower back twinges for days. So, as in inflexible old guy who has to roll his pelvis rather than bending forward, I tend to go larger. My Canyon is a Large, with 12.5mm of spacers, and that allows me to get my back basically level in either aero hoods or drops, and still pedal effectively. It took time and practice to be able to do aero hoods for any distance, but now I can hold the position for several miles at a stretch. I tend to switch back and forth between that and drops on several long, straight-ish segments of my usual rides which are level or slightly downhill, where I'm going >25 mph. But I can't do the whole ride like that, and honestly, there's not much point to doing so, given that at slower speeds aerodynamic drag is less of a factor, so mostly I ride on the hoods.
The goofy glasses, stem, aero position are what I aim for and I want to make sure that they are facilitated so that I can exert myself, or conversely that I am not encouraging myself to relax while exercising. As I have often said, I compare my bike to my trousers. Thin jeans and baggy slacks both, encourage me to fit them.
At the same time I have left my steerer tubes uncut because I anticipate that I will need a more relaxed ride as I get older.
It has been fun though.
#384
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
There are bifocal contact lenses, and there is monovision (which I have) where one eye is near prescription and the other is distance.
Some people have trouble adapting to the latter, but I love it.
#385
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I can't imagine what that does to your depth perception if only one eye can see distant.
#386
Quoted: 7652 Post(s)
Liked 3,473 Times
Both eyes can still see .... just one can focus better at greater distances and the other, closer. it is not like there is some range at which one eye shuts down and the other takes over.
#387
Sock Puppet
Liked 863 Times
But if you are looking at a distant object, only one eye will see that object clearly while it will be blurred for the other eye, no?
#388
Liked 7,297 Times
Likes For tomato coupe:
#389
Quoted: 67 Post(s)
Liked 67 Times
I guess if your vision was so bad in the near eye it might be a problem; this might be why some people don't tolerate monovision, but for me it is seamless.
Your brain is pretty good at figuring things out!
#390
Liked 3,473 Times
