lube ?
Quoted: 14 Post(s)
lube ?
I want to clean and re- grease my bike's pivot points, which lube is best? I have Parktool HPG-1, will a marine grease be better? I am in Arizona and my trails are always dry and dusty.
Thanks
Thanks
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
The Park grease should be good enough.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 569 Post(s)
Liked 582 Times
↑↑↑ is good advise, HPG-1 is very good and I have been in and around Tucson for over 70 years.
Likes For easyupbug:
Quoted: 540 Post(s)
Liked 416 Times
This is like asking what's the best beer.
To each their own.
You really need to try many diff kinds out there. Easier when you are wrenching on a ton of bikes in a shop or flipping them.
When a DIY doesn't know what to choose, your choice of Park Tools is always a safe bet to start from, and then build personal preference from there.
To each their own.
Clark W. Griswold
Quoted: 4356 Post(s)
Liked 3,994 Times
The Park stuff is fine. I like to use Phil Wood Grease but the HPG-1 is excellent grease and will do the job quite well.
As far as the best beer, it is actually not beer but Skrewball Peanut Butter Whisky (they probably use the "e" but whatever)
Quoted: 506 Post(s)
Liked 639 Times
The grease/heavy oil you have on hand is the best. You can find a good selection at your hardware store, or pay significantly more for the same thing in a bike shop. As long as it is waterproof, you're good. Don't overthink.
Likes For KerryIrons:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Yes it would be "good enough" but there are other less expensive options that would work just fine.
KerryIrons hit the nail on the head with his advice:
"The grease/heavy oil you have on hand is the best. You can find a good selection at your hardware store, or pay significantly more for the same thing in a bike shop. As long as it is waterproof, you're good. Don't overthink."
Liked 4,218 Times
Try to keep up.
Stuart Black
Stuart Black
Quoted: 1944 Post(s)
Liked 2,164 Times
My advice, use the Park grease and don’t bother to read the next hundred posts that will probably follow as the thread spins off to parts unknown.
John
John
Quoted: 327 Post(s)
Liked 250 Times
Try to keep up ?
Ouch, you seem to be unable to express yourself with out adding sarcstic jabs.
I won't correct your analogy............ nuff said
Likes For frogman:
Quoted: 1562 Post(s)
Liked 1,734 Times
If you are taking the parts apart to grease them, then any grease will do. However, if you are too lazy to take every pivoting point apart to grease them, then I suggest something that allows you to drip the lube into the pivots. I use Finishline lube for this purpose but there are lots of other suitable lubes, including silicone spray.
Likes For soyabean:
Liked 2,164 Times
John
Liked 4,218 Times
Perhaps you’d better say more. What “analogy”? I made no analogy.
Stuart Black
Stuart Black
Liked 2,164 Times
No, but a lot of posts and advice given over those years. And a lot of people have come and gone.
Everyone posts replies that aren’t “kinder and gentler” from time to time, some more than others, it is just the nature of posting on the internet.
I know I’ve posted replies that I stumbled across years later and think, “Wow, what a jerk.”
John
John
Liked 2,164 Times
Liked 4,218 Times
Who is trolling whom? How is my advice any different from yours or veganbikes’ or KerryIrons’ or easyupbug’s? frogman even quoted KerryIrons’ post with the same advice I gave.
I don’t think you are using that word properly. From vocabulary.com
Often I learn things from people on line. Even trolls can make me go out and learn something new,or at least reconfirm something, like “edification”.
It's important that they can prove themselves to get edification from strangers on the internets because they can't otherwise from real life
If something is for your edification, watch out! It means it's designed to improve you in some way, whether morally, educationally, or spiritually.
Stuart Black
Stuart Black
Likes For frogman:
Quoted: 14 Post(s)
Thank you for all your input everyone.
Perhaps, I should rephrase my question a bit. Since I really don't like taking stuff apart too often, is there any better grease that will last longer and better than the parktool grease I have on hand, so instead of re-greasing every 6 months, I will do it once a year or even longer.
Like I said above, I am in the dusty desert, and I forgot to mention, I wash my bike every after ride because I'm "ocd" ...
Thanks again
Thanks again
Liked 2,164 Times
Not sure what the maintenance schedule is for the bushings, but if you are in dry conditions, I would guess the grease will last longer than the maintenance interval.
John
John
Likes For 70sSanO:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Apologies in advance for the off-topic post.
First, this being a written "conversation" in a language that isn't my native, it should be stressed that I'm not being sarcastic nor trying to address any single post or poster in particular. With that out of the way:
What I love about bikeforums is that practically every question gets some very good advice/answers within a really short time.
What I don't like is when people start doing 1-up on each other (is that the right expression). It doesn't matter "who started first."
Forum is what we all make of it. Let's try to make it as good as possible. "Let's all get along."
As for the topic, I have nothing to add - great advice as usual.
Likes For Bike Gremlin:
Liked 4,218 Times
Thanks again
Thanks again
I also question the need for greasing pivots anyway. With the exception of some really low end bikes (think HelMart), modern mountain bike pivots (like post 2001) use sealed bearings which can go for hundreds of thousands of miles on a bicycle without service. Even then, it’s best to just replace them if they have issues.
And you really don’t need to clean your bike all the time. Dirt won’t hurt it.
Stuart Black
Stuart Black
