Using maths to calculate chain length? Singlespeed.
Old 07-10-22, 08:20 AM
bikethis
Quoted: 21 Post(s)
Liked 9 Times in 4 Posts
My chainstay is 16.92 inches, my rear cog has 18 teeth and my front chainring has 42 teeth. Using maths, I can calculate the perfect chain length.
16.92 * 2 = 33.84
18 / 4 = 4.5
42 / 4 = 10.5
33.84 + 4.5 + 10.5 + 1 = 49.84
However, since I am converting to a singlespeed, how does throwing a chain tensioner into the mix affect this calculation? The equation tells me I need 50 links, but if I need to use a chain tensioner, will this be too tight?
bikethis is offline
Old 07-11-22, 07:37 PM
SkinGriz
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times in 582 Posts
Order good amount more than you think you need and remove the excess.
SkinGriz is offline
Old 07-12-22, 05:06 AM
Bald Paul
Bald Paul's Avatar
Quoted: 825 Post(s)
Liked 1,659 Times in 784 Posts
I think you may need to buy some new maths.
Bald Paul is offline
Old 07-12-22, 05:37 AM
bikethis
Quoted: 21 Post(s)
Do you mind telling me how kind sir? I used this equation to calculate my current chain length and it works absolutely fine, bike rides perfectly. I'm looking at getting a tensioner because I want to hot swap my chainrings and sprockets on the fly. I'm guessing you know the answer to the question?
bikethis is offline
Old 07-24-22, 05:35 AM
Apetimberlake
Quoted: 14 Post(s)
Liked 7 Times in 3 Posts
There are several websites that can help you. Just google it
Apetimberlake is offline
Old 07-28-22, 10:31 AM
ceelint
^that guy^
ceelint's Avatar
Bikes: '17 Wabi Classic, '17 Trek DS3, '12 S-Works Tarmac SL
Quoted: 91 Post(s)
Liked 137 Times in 51 Posts
https://eehouse.org/fixin/formfmu
ceelint is offline
Old 07-28-22, 10:59 AM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
I'm not sure I get why the math is needed. Mount the tensioner, Put on the cogs and chainrings you plan to use. Wrap the chain around the cog, tensioner and ring for each application. Break chain to suit and fasten with a quick link (that probably came with your chain). Yes, does require a chain riveter to break the chain. Buy, have a shop do the work or go to a bike coop if you have one.
If money is the issue, try asking for a used, junk chain. Use it to determine the length.
Ben - who's been riding single-speed and fixed for 50 years and has yet to calculate his first chain. In fact, who's never known how many links he's riding.
79pmooney is offline
