Schwinn Paramount vs Trek Domane
#76
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 982 Times
Sub 10 lbs is probably not completely farfetched, either. Sub-13lbs has apparently been do-able since 2021. See the special edition version described at the end of
https://bikerumor.com/585g-specializ...k-catching-it/
Not my cup of tea. I'm not a competitive amateur or pro cyclist; I just ride to please myself and get some exercise. But if it "floats yer boat" and you have the cash, then go for it if you like.
#77
Quoted: 2499 Post(s)
Liked 2,977 Times
They tested steel frames were which were mid range slx steel frames as seen in sheldon brown fatigue test . Would it have been a columbus genius or a columbus nemo or columbus ultra foco or reynolds 853 or reynolds 953 or the dedacciai dr zeo the data would be totally different. The data in this test is more than 30 years old so it isn't really representative, nor very relevant today . How many high end to very high end columbus frames excluding slx such as neuron, genius, nemo, foco,ultrafoco or reynolds 753, 731, 708, 853, 653, 631, 531c or deda dr zero ordeda dr zero uno have you seen broken or damaged ? Please share numbers and pictures because I am curious to know the stats. SLX isn't a high end steel. The high end steel at Columbus starts with Nivacrom and continues with Thermacrom,for Reynolds its 631,853, 725, 931 and 925 steels that are high end and at Dedacciai , its is DR Zero and the DR Zero Uno.
"We also need to think about fatigue strength; what happens after lots of applications of load, after 20 years of continued pedaling forces, for example. Typically, the stronger materials are less ductile, i.e., more brittle. This leads to worse fatigue strength. But in reality, steel is plenty strong, and it is often bad design features and poor welds that lead to fatigue failures.
As discussed earlier, a stronger steel means you can use less of it to achieve a certain strength and stiffness, so less weight. However, there is a bit of a limit to this with regards to wall thickness. If the walls get too thin, they will just buckle under load (a function of Young’s Modulus, not material strength) or they will be susceptible to impact damage."
Physics is inescapable. But, as I said earlier, since those modern high-end steel frames are, of course, great examples of the framebuilder's art and are built in such minimal numbers and unarguably likely to be babied by their owners (and certainly almost never raced), chances are that very few will ever fail, despite their being built with thin-walled, brittle steel tubing.
By the way, just came upon this debunking video:
#78
Quoted: 3016 Post(s)
Liked 3,810 Times
I won't argue that. But entirely irrelevant to the choice of bikes everyone who ever has visited this forum. To claim any one bike is more serious for the likes of us is laughable.
#79
Quoted: 2365 Post(s)
Liked 1,753 Times
Not really. Some of the comments above are fairly close to being equivalent to walking into a C&W bar and shouting out during a lull in the music, "Country music SUCKS - blues/jazz/hard rock/rap (pick any of these) is WAY better!"
If someone does that, it shouldn't be a surprise when some regulars at the bar take offense and yell back.
#80
Quoted: 1250 Post(s)
Liked 1,330 Times
Incorrect. And again, shows astonishing ignorance.
It is hard to believe that any one thinks its about the bike. Bartali on his first team bike in 1934, 49 up front, 16/18/20 in the back and serious contortions to shift, would drop you in your prime on any bike today like a bag of wet sand. Your humiliation would be epic. Kind of like now. But go ahead, keep on telling yourself it is about the bike. The world needs a good patsy.
Likes For Atlas Shrugged:
#81
Crawlin' up, flyin' down
Quoted: 1033 Post(s)
Liked 2,547 Times
With that, we agree. It's a bit harsh to say the Trek will be trashed or discarded because, like most OG carbon bikes, many remain and are still ridden. That Schwinn is not regularly ridden today but placed in storage in some basement or hung on a wall in a coffee shop as a curiosity at that point; why does it matter if it still exists? In general, I view my bicycles as a tool to be used, much like most other items in my life, and I try to use the best tools for the job. In 50+ years, the very few assets accumulated during my life remaining will have been dispersed and disposed of, with a few heirloom items which remain and be passed down to a select few. I don't consider my bicycles in that category; they will be well-used and given to anyone interested after I am done with them. I have lost count of how many performance bikes I have owned since the 70s and have only kept a couple; the rest were sold or given away. My Garmin's are the same way, I am on my 2nd Fenix Series Watch, and I can't remember how many Edge bike computers I have been through; they are fantastic additions to my enjoyment of the sports I love and like footwear replaced when I determine their time has come.
I incorrectly weighed into the C&V subforum to debate the premise that modern bikes are inferior to vintage ones for the sport of cycling; I was on a fool's errand. Much like jumping into a Catholic forum defending Judaism would be irrational, nothing positive would come from that kind of interaction, especially on an online forum.
The second highlighted quote reflects a common failing; saying Widget A is "better" than Widget B without any discussion of the criteria one is using to determine what "better" means. That ends up being a pointless back-and-forth of "Mine is better because it's better" and "No, mineis better because it's better." It is also why this thread as generated so much heat and precious little light.
#82
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 388 Post(s)
Liked 695 Times
Where in any of my comments on this ridiculous thread or any others do I state that is about the bike? With your logic we should all ride single speed beach cruisers because we can’t beat Bartoli? I just believe that modern bikes perform better than vintage bikes in the areas I and most cyclists consider important. A vast majority of cyclists feel the same way including C&V owners that’s why you never see them out and about only in garages or hanging from walls. I have participated in mass start events in numerous countries including L’Etape and the Maratona, ridden the bucket list of iconic routes C&V bikes are nonexistent. You could sit at the top of Ventoux or the Stelvio all day before someone rolls in on a C&V bike. The only time they are seen in any numbers is during designated events where they are dusted off and paraded about like hogs at a 4H fair. Modern bikes are amazing tools and have substantially improved the experience for cyclists in every way.
Hanging on walls and garages? Hardly. You keep coming back to take pot shots, in a sub-forum you yourself admit you mistakenly entered. Now you keep arguing against various strawmen.
Move along, or better yet, take a deep breath and go take a bike ride.
Likes For panzerwagon:
#84
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
None of my old steel bikes are wall hangers. They all get ridden.
Likes For 52telecaster:
#85
Liked 3,810 Times
Originally Posted by Atlas Shrugged
But who in their right mind would choose to ride it over a top end modern bike for a serious ride or multi day event.
But there is absolutely zero reason that a shiny Paramount can't do a serious ride or multi day event. I understand your perception is your reality. But you seem to be dead ignorant of the fact your reality is that, just yours. And quite frankly unless you are putting food on your table from racing a bike professionally, "performance" from a bike is purely an illusion. And laughable.
First pic is a 150km ride with 10k+ of climbing. Second is from a 200km ride over gravel mountain passes in Montana. The third is an easy ride, going up Going To The Sun road. All on that same bike Bartali got as his first team bike, only 80 years later. Yeah. That's not ******g serious at all.
106100-002-026f by iabisdb, on Flickr
Cino 146 by iabisdb, on Flickr
Going To The Sun by iabisdb, on Flickr
Likes For iab:
#86
Quoted: 981 Post(s)
Liked 1,844 Times
More modern, in that regard, may be the choice between a 1950s single speed and a 1970s 10-speed, or between the latter and a contemporary 22-speed. Just depends on the objective(s) of the ride.
-Gregory
#87
Liked 3,810 Times
I get that, but I also get that when I'm out for a long day ride and would like to get home before dark for safety reasons and because I told my wife I would, I sometimes do choose to take a more modern bike to ensure that I can take advantage of that 5-10% advantage I gain in speed, which may account for up to an hour of my saddle time before the end of the day... And I'm just out putting around, for sure, but meaningfully as it goes.
-Gregory
-Gregory
Likes For iab:
#88
Quoted: 981 Post(s)
Liked 1,844 Times
95% I'm riding at dawn (not counting the commute home ). I understand that a 3-hour ride on my off-topic bike would last 3.5 hours on a vintage bike. I understand safety and won't argue against it. But it has never been an objective of mine to spend less time on a bike. I don't understand if you like doing something, why do less of it?
-Gregory
#89
Quoted: 1095 Post(s)
Liked 1,034 Times
Likes For Russ Roth:
#90
Quoted: 4520 Post(s)
Liked 6,406 Times
Not my cup of tea either but I would rather have 40th Anniversary Allez in Reynolds 853 made to 74 units
#91
Quoted: 175 Post(s)
Liked 452 Times
Wrong, wrong and wrong.
Do we need to teach the difference between carbon fiber, composites vs. plastics?
Not all are lightweight. Matter of fact, many are heavier than frames made of other materials, especially in the mountain bike segment. There's reasons for it, but this not the place to get into it all.
Most are repairable and again, you like many have zero experience in any of this, yet even some simple fingering of your keyboard will lead you to companies whom repair those frames, state of the art work and with expertise. Not Band-aid work. Most repairs cost are comparable to steel frame repairs.
Ps. Frames made of carbon fiber have greatly evolved in 40 years. There's C&V subforums on many and differences through its era's. The 'V' stands for vintage.
I don't care to discuss more of the subject and it’s not worth the time. Too many [ mod edited] whom can't respect the remarkable engineers and science. If looking at the best available in today's carbon race bikes doesn't insult or hurt your brain, no imagination but there are concept / prototype weighing 40% less and equally strong. None of it will ever be UCI legal, hence no reason to market.
Likes For chain_whipped:
#92
Liked 1,753 Times
#94
Quoted: 3535 Post(s)
Liked 2,942 Times
WE DON'T CARE! WE DON'T CARE ABOUT THESE METRICS! NO ONE GIVES A FLYING F!
Now...why is that so difficult for an enlightened, rational adult to understand?
Likes For smd4:
#95
Liked 2,977 Times
You are 100% correct. Modern bikes are better in nearly every measurable way. The have more gears; they're faster; they're lighter; they stop better. And yet...how should I gently put this so it's easily understandable?
WE DON'T CARE! WE DON'T CARE ABOUT THESE METRICS! NO ONE GIVE A FLYING F!
All true, and all beside the point: all you'd said was that you just like riding those tires at that pressure. Dunno how people can argue with that, and yet they did.
Where this thread went wrong was when people started making easily refutable claims about the superiority of steel to carbon fiber in bike frames. Sorry, but that triggers the "Someone is wrong on the internet!" reflex.
Some people like steel frames better than aluminum and carbon fiber frames. Great! If they had simply said that, this thread would have petered out immediately.
Likes For Trakhak:
#97
Liked 2,977 Times
. . . My steel bikes were state of the art back then. My aluminum bikes are (to me) state of the art now. Nothing to get riled up over.
Threads like this are puzzling. The C&V section has become far more vicious than it was only 10 years ago (let alone compared to how it was when I started reading it in the first years after Joe G started BikeForums). Worse than the Road subforum, self-congratulatory claims here to the contrary. Why is that? What happened? They're all just bikes.
That's precisely the same claim as seen in the threads where someone declares hotly that "Lycra-wearing Lance wannabes" look down on him. Yet, if it happens (anything is possible), I can't remember ever seeing an example on Bike Forums. Again, only the reverse.
That's what we call "projecting." It's just high school, all over again---the Jets versus the Sharks, the Goths versus the punks. Us versus the Others.
#98
Liked 2,942 Times
Not disdainful at all.
Likes For smd4:
#99
Liked 2,977 Times
In this thread, outrageous (and nastily personal) claims have spurred outrageous responses. How about in other threads?
#100
Liked 2,942 Times
Stop moving the goal post. You asked for a "post on Bike Forums where an owner of a carbon bike has expressed disdain toward an owner of a steel bike" and I gave some to you. If I get the time or the inclination to find more, that should be pretty easy.
Likes For smd4:
