Chain replacement problem
I changed the chain on my 2018 Domane SL 5 disc with 105 components. I installed an Ultegra chain. Now the chain makes noise and back pedaling is noisy and not smooth. Are the 105 comoponents not compatible with the Ultegra chain?
Quoted: 3056 Post(s)
Liked 1,218 Times
Your chain isn't "worn in" with your cassette and chain ring so that is why you are hearing noise. If the noise doesn't go away after awhile then replace the cassette and possibly the chain ring. If the bike is 6 years old and has lots of miles, it may be time to do that anyway.
Really Old Senior Member
I don't know know if it applies to your chain, but I believe some chains are "directional".
Likes For Bill Kapaun:
aged to perfection
Quoted: 852 Post(s)
Liked 1,282 Times
agree on the above - by all means reverse the chain and see if that helps.
Also if your bike is a 1 by (Single chainring) there is a possibility that the narrow / wide teeth are not clocked correctly with regard to the chain.
not sure if that applies to your bike
/markp
/markp
Clark W. Griswold
Quoted: 4445 Post(s)
Liked 4,102 Times
As people have said some chains are directional but also if you put a new chain on a worn cassette it can also cause noise and shifting issues. Depending on wear it could be time for a new chainring as well. What I recommend is making sure the chain is on correctly but also you might replace that cassette and I would also remove your derailleurs and clean them well as well as chainring (if not need replacement) and just get your drivetrain nice and clean so you aren't wearing things out prematurely and you have better shifting.
Quoted: 521 Post(s)
Liked 455 Times
Are you sure you threaded the chain on the correct side of the retention tab on the pivot arm of the rear derailleur?
Likes For oldbobcat:
Mad bike riding scientist
Quoted: 6254 Post(s)
Liked 4,280 Times
Yup. Common mistake
Stuart Black
Stuart Black
Method to My Madness
Quoted: 2037 Post(s)
Liked 1,530 Times
Quoted: 6318 Post(s)
Liked 4,906 Times
As long as it's for the same number of speeds on the rear, 105, Ultegra and Dura Ace matches up in almost every case. The Shimano chains want the plates that have Shimano on them facing out to the right side of the bike. Doesn't matter if upside down or not.
Did you clean the cassette real well? Usually gunky cassettes are quieter. So maybe you are just hearing the sounds of cleanliness.
What's it doing when you backpedal? Have you looked at it while you are backpedaling? If the top run of chain is going slack that might be some other issues.
You sized the chain to the proper length?
I neglected to notice that I threaded the chain on top of the tab instead of under it. I rethreaded it correctly and now the crank turns smoothly without the problem noise. Thanks to all of you for getting me on the right track. I must have examined that darn derailleur a half dozen times and never noticed the problem.
Likes For jackb:
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 162 Post(s)
Liked 135 Times
I've done that more often than I care to admit :-)
Clark W. Griswold
Liked 4,102 Times
