Big & small motors vs big & small batteries
Bikes: repco MTB 26" + sram 2 speed automatix hub , road king cruiser 26" + lifepo4 48v x 12ah + 200w motor
Ive been thinking about this recently and haven't come to any real conclusions , so im all ears to peoples opinions here . Its got to do with small and larger motors with batteries .
my first kit is the 200w motor I now have , it came with a 36v 9ah li-ion bottle type battery . It gave me around 40kms @30kph (20mph)
I then bought a 350w elifeQ100 motor and built another bike thinking it would go faster (which it did) , though using my 36v battery it only travelled HALF of that distance . The motor , though it went faster , i was disappointed about the battery running out of steam after 10 kms . I then heard on the forum that a more powerful battery can be used to power the 200w providing the controller caps are up for the task . Pulling the controller apart I soon found out it was ,,, so i went and got the (lifepo4) 48v x 12ah battery . Now to my amazement , not only am I getting over TWICE the original distance (80kms +) ,,, but it goes almost 15kms faster (40-45kph or nearly 30mph )
So im wondering,,, why would you buy a bigger Watt motor and use a 36v battery , when a small watt motor with a bigger battery will do it better ? Im not real cluey on technical issues here , so this is what I have found in my short experience playing with motors and batteries .
This is where technical knowledge comes in handy i suppose i need ?
rick
rick
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Hey Rick,
Your motor “size” (aka power) does not make much of a difference. The power is not determined by the motor. The power is determined by the Volts (battery) X amps (controller). The battery and controller determines your speed, power, and thus range.
a “350 watt” motor may have a 36v battery * 15 amp controller giving 540 watts max power (your Q100), and typically 10 amps at a steady state (360 watts), while a 200 watt motor typically lowers the power by using a 24v battery.
If you use the same controller & battery for your 200 watt and the 350 watt motor, you would get the same range. But I assume you used a different controller, giving you more amps, more power, and less range.
The Q100 is a nice motor (I have 3). If you got the 200rpm version, you can run it at 48v and have a motor that runs at 260rpm (200*48/36). Of course if you over volt a motor you will have to be more careful about having the motor or controller overheat (i.e. it may burn up on hills or other places where sustained high power is needed at lower speeds).
Any more questions?
Any more questions?
rick
rick
There is a lot to electric bicycle motors, many different approaches.
Direct drive hub motors have no gears inside, no clutch (don't freewheel) and are large and heavy because they spin at a 1:1 ratio. They need a very high pole count to achieve a reasonable level of efficiency during from stop acceleration and hill climbing. Due to their larger surface area though, direct drive hub motors will often have a significantly higher thermal capacity. What does this mean? It applies directly to your question, your limit is how much power you can put through the motor without burning the motor. The higher the thermal limit, the more you can do with it, very simple. So why would someone want a higher thermal capacity motor? The rider weighs more, they carry heavy loads, they climb mountains, they like to accelerate really fast or go really fast and so on.
Your motors are geared hub motors. Geared hub motors have planetary gears that turn the motor a certain number of times for every 1 revolution of the motor. Maybe your Q100 has a reduction ratio of something like 8:1, this yields certain advantages and disadvantages. The summary of this is you can make a much smaller and lighter motor, while not necessarily having the same capacity, can achieve a lot for it's size. The down side to geared hub motors is the gears themselves. They aren't anywhere near as quiet as direct drive, they can wear out and break. The gears themselves provide some friction as well, so lets say you hypothetically had two identical motors, one was direct drive and one was geared, you would get more propulsion from the direct drive motor at it's peak efficiency compared to the geared motor simply because the drag from the gears wasn't present.
Geared hub motors have the potential to yield advantages in acceleration and hill climbing, due to their reduction ratios they have a higher efficiency at slower speeds. The idea that I am talking about is efficiency curve. Electric motor efficiency is directly tied to it's RPM. This subject is extremely broad and many variables go into, ideas like KV, winding, wheel size, voltage, laminations and so on are all probably wildly beyond the scope of your question, but they are subjects that are directly correlated.
Beyond direct drive and geared, there is side or left side drive, mid drive, and friction drive methods for transmitting power from the motor to the wheel. All of these routes have pros and cons.
Side drive is a bit more simple, but not as visually appealing.
Friction drives are pretty simple themselves, but wear down tires faster, and sometimes even slip or fail to transmit power to the wheel.
Mid drive is pretty popular in it's variations. Mid drive allows you to use your bicycle chain and gears to transmit power. I won't go into the down sides of this approach, the main benefit is that you can keep the motor in a pretty ideal point in it's efficiency curve, where this is of most benefit involves really intense levels of acceleration or hill climbing. A lot of motors will turn most of it's power into heat during really slow sharp climbs, but being able to shift into the right gear will allow the motor to turn many times while still keeping the bike at a reasonable speed and allowing the motor to stay in a fairly ideal level of efficiency.
Personally, I place the highest value on a motor much like yours for electric bicycles. I am working on new designs for a motor like the Q100 and Q75. I think there is a pretty substantial amount of room for improvement on these types of motors which will largely eliminate their down sides and provide a pretty intense amount of value. Small, lightweight, stealthy, really great. Not everyone can get by with a Q100, but really many of those people are probably riding lightweight electric motorcycles in disguise.
Chas ,,, yes I used a different controller . I was impressed with how the Q100 motor performed but it flattened the battery in no time . What you say makes sense ,,, I should have used the controller that came with the battery on the 200w .
Sheeeeeesh !,,, if id known that I probably be using it now with the new battery ,,,and getting even better performance . Possibilities are endless .
Yes , they are a nice motor . I may invest in another later on down the track . Heres a photo I took after the build .
Liked 415 Times
That is a cool looking bike!
FYI, I get about 24 miles on a Q100 at 23mph and 36v10ah. But, I do a lot of pedaling, so I'm not sure what the motor will do on its own.
According to this site: Motor Simulator - Tools, it should go about 22 miles, so I'm not too far off. 10km doesn't sound right at all. I would expect at least 20km minimum, but more likely 30km on that motor/battery for ya.
Bowlofsalad
Great reading & thks for the detailed information , I hadn't thought about direct drive ,,, I gather they would wind out a lot more than a geared motor . I can see your point regarding the geared motor getting damaged easier as when I first started using it I would let it pull me from a stop position ,,,,, . It didn't take me long to figure out it doesn't like that ! so now I kick off ,,, pedal a bit ,,,then gently apply throttle .
Many different approaches like you say ,, ill file this for future ref ,,,!
rick
rick
If you're going to do a lot of pedaling without motor assist, I would go with a geared motor as it has less resistance over the direct drive. The last time I rode a direct drive using pedal only, it felt hard on my legs and fatigue kicked in pretty quickly. This was on low gears.
Vince , ive heard this before about DD . Yet to ride one ,,, not too good if your miles from home and a problem with power to the motor . A bit like an exercise bike maybe ,,,?
Rick - my thoughts exactly, if you run out of battery and about 5 miles from home, you're going to struggle. To me, an exercise bike should be very light on your legs when you're pedaling on a low gear. The direct drive in my opinion puts too much strain when pedaling alone and that's not a good way to exercise. Check out this video of the izip Dash with a direct drive motor with a 48v battery. Court explains how a direct drive has resistant compare to a geared motor and he demonstrates how it free wheels.
IZIP E3 Dash Review - ElectricBikeReview.com
Yep , that's an informative video . Actually i thought that the wheel when he spun it would spin less than it did so I was surprised it spun as much as it did . I can see how it would be hard work if one had to be peddaling it a few miles . Those magnets would make it tough on the legs . The geared 200w I have , has served me well for 3 years now and like you say , I can replace the gears should they wear out .
rick
rick
That depends on the design and implementation of the motor... When I ride my bike without using assist it feels just like a regular bike, just the other day I rode my BionX 350 DD hub motor set up without using the assist at all for 49Km through what were some fairly big hills, to me anyways... 433M assent total, 1781 calories used and I felt like I was just riding a normal bike, there was no noticeable resistance at all from the motor...
thanks rick
I certainly can't feel much difference as far as drag is concerned either pedaling or coasting going down hills... Now I am sure there IS "some drag" that could be "measured"... JMO and I asked the wife her opinion and she agreed ... She can't feel any difference either on her bike, pedals like a normal bike she said. Now if you start out riding with assist and turn it off after awhile, WTF is your first thought why is it dragging sooo much, what is holding me back?
Here there are many Mid drive conversions, for Hunters, of Mountain bikes.
Hub Motors don't have much climbing torqu, but will be fine for commuting in towns & cities
that are not built over steep hills..
