Anyone rebuild a cartridge bottom bracket?
Quoted: 112 Post(s)
Liked 213 Times
I haven't tried this before: looking at rebuilding a Shimano BB-CS10 sealed cartridge bottom bracket.
This one installs from the non-drive side and the adustable cup is on the drive side.
It appears to have a lock nut on the left side, similar to the one RJ rebuilds in his YT video.
Bianchi Goddess
Quoted: 2935 Post(s)
Liked 2,931 Times
I don’t think most were intended to be rebuilt. I’m unfamiliar with shipmano model numbers is this an entry level BB or a Deore / 600 level thing?
One obstacle might be getting correct size replacement cartridge bearings.
It’s a page or two back now but someone posted in the “What are Wrenching On” thread about doing one.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
I've used a pick or small screwdriver to pry seals away, inject grease and replace the seal.
On Shimano units like the 6500, UN55 etc. I've drilled a hole in the side with a carbide centerdrill. Use a vacuum and suck up the chips as you go, you don't want them in the bottom bracket. Inject grease with a needle on a grease gun. I've brought some back to life and ridden thousands of miles on them.
Likes For bluehills3149:
That said, I've thought about it. And if you're trying to keep a bike completely original, you may have no other choice but to give it a try - either via cleaning and re-greasing the bearings as BradH suggests or removing/replacing them if they're totally kaput.
Hope it turns out well if you choose to go that route. If you do, I'd be interested in hearing about your experience in doing it.
Likes For Hondo6:
Quoted: 112 Post(s)
Liked 213 Times
I'll post some photos of it later.
I had watched the RJ vid, which led me to think it's doable.
He says the locknut is left-threaded.
All the other cartridge bb that I have used install from the drive side.
Thank you.
Thank you.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
I've knocked a cheap one apart, mostly as an exercise in "forensic machanics"
Likes For dedhed:
Likes For leftthread:
Quoted: 3464 Post(s)
Liked 2,831 Times
So much for cartridge bearings on that one.
Likes For repechage:
Quoted: 566 Post(s)
Liked 1,053 Times
My ignorance - does a cartridge bottom bracket imply it has cartridge bearings or is it the fact that the “cartridge” is basically a singular unit irrespective of bearing type within?
From the above, it appears that the OP's BB-CS10 is indeed user-serviceable (whether that was Shimano's intent or not). Shimano's EV doesn't indicate that it was so designed, but the fact that it can be non-destructively disassembled with common tools implies that it can indeed be serviced and/or overhauled - provided the bearing races aren't toast.
Likes For Hondo6:
Likes For Hondo6:
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
I wonder if 5500 level, 105 bottom brackets are serviceable? I have a few old ones of those stashed back somewhere.
Quoted: 1401 Post(s)
Liked 1,886 Times
it might be due to the way the software interprets how the picture was taken and / or stored on (whatever) device (for lack of a better technical explanation)
try this to correct -
edit the photo: rotate / save - then edit again: rotate to original orientation / save
then upload and picture should be oriented correctly
