New to e-Bikes - recommendations?
Bikes: 1974 Gitane TdF, 1989 Specialized Hardrock "Ice Bike", 1990 Gary Fisher Tassajara, 2012 Trek 1.5 Alpha, 2010 Surley LHT, 2011 Surley Pugsley "Fat Tire", 1988 Gary Fisher Gemini Tandem MTB
Quoted: 7 Post(s)
Liked 14 Times
Been riding for years, now only on rail trails, and I've been thinking about getting an electric bike. I turn 76 soon and can't peddle like I could 10 years ago. I tried an e-bike a friend has and really liked it - still get the exercise but not to the point where I'm wiped out. I'm looking for a fat-tire e-bike, that will handle the soft trails we have & have a range of 30+ miles or so. I want a peddle-assist so I still have to work, but not as hard. One that caught my eye was the Himiway Cruiser. Recommendations?
Quoted: 883 Post(s)
Liked 824 Times
IMO, if you like to pedal, stay off the behemoths like the Himiway, and look at what the "bigs" (Specialized, Trek, Giant etc) have to offer unless you don't want to spend $3000+. If that cost is too dear. look into DIY.
Quoted: 7 Post(s)
Liked 14 Times
Yeah - $3000 + is not going to happen. Trails I'll be on are re-done RR trails, so pretty easy terrain. I just need some assist to do the longer miles, thus the look into E-bikes.
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
Do you ride to trail head or need to transport the ebike to the trail head?
Hub motor fat tire ebikes can be found under $1200, but it will weigh 60-70 lb.
In my experience, fat tires can benefit when you're riding in beach sand, mud or snow.
If most of your riding in on hardpack, rail trails, fat tire may be overkill, narrower tires can also save a few pound of rotating weight.
Something like a Qualisports Dolphin works quite nice for rail road trails on the cheap, I bought mine at below $900
30 mile range maybe pushing it with the seatpost battery, but with PAS it should be no problem:
The $999 Lectric XP2 is serving well for me, but a bit on the heavy side, more difficult to transport with a car that the Dolphin, 30 mile range is also pushing the limit with throttle operation
Nowadays, it is all up to the supply chain availability.
Whatever retailer have in stock is likely what you can get without 6-12 wk wait. .
Old enough, hmmm?
After getting a taste while setting up and testing my equal half's e-bike I started looking and decided for the RBSM "Mud Adder" (https://www.rbsmsports.com/product/r...-adder-e-bike/). Perfect for my purposes i.e. riding anything from mild single track to pavement in varying terrain. First ride mid September,, present Odometer reading just over 1000 km.
Added the mirrors, the computer, the head and tail lights etc.
In my opinion big bang for the bucks.
Quoted: 7 Post(s)
Liked 14 Times
I haul my bike to the trail head - though it's a short distance, only a mile or so, but I just don't feel comfortable riding with traffic, after a friend was killed and another injured. Lighter weight would help with getting the bike int my small SUV - something the size of a MTB would be ideal. Something like the RBSM Mud Adder looks pretty good - if it's available. But with a weight/height limit of 220 lbs/6;1" ! I'm a big guy, 6'2 and haven't seen 220 in decades. Ah well....
Quoted: 883 Post(s)
Liked 824 Times
Agree about riding on the road, although I need to go a short distance to a few areas. That 52 pound "Mud" will be fun to get in the back of your SUV.
Quoted: 7 Post(s)
Liked 14 Times
Hmmmm..... yes, that's certainly something to consider. What's the lightest e-bike with a MTB configuration?
Quoted: 883 Post(s)
Liked 824 Times
AFAIK, anything lighter than 50 or so pounds is expensive $4K+, I'd guess (but maybe someone here knows of some). I built a < 35 pound for < $1000 with a BBS02, 52V 6 ah battery (range of 15 or so miles) and rigid MTB donor. If Chas 58 answers, he built an even lighter one with a small hub motor, but he's much younger and stronger than I am.
Quoted: 7 Post(s)
Liked 14 Times
Looking up E-bike conversion kits I came across Hilltopper E-bikes. Their Discover LE Electric Gravel bike looked good - weight listed at 44lbs, front hub, 36 V 350 W motor, 1 x 7 Shimano Nexus internally geared hub with a Gates Belt Drive, twist throttle and Pedal Assist System with 4 levels of assist. 650 wheels with gravel tires & range of 30-50+ miles of battery range. Price: $1899 including shipping in US. Sounds pretty good, and even looks like a regular bike. Any opinions on the Hilltopper?
Quoted: 883 Post(s)
Liked 824 Times
Their kits received good reviews from a couple of members several years ago, but no information on complete bikes. You might check electricbikereport for some general information, but beware that AFAIK, they charge for reviews, so to me they're more like infomercials.
Looks nice, I picked up a RAD Mission, fits in my Minivan around 47lbs, has good range (about 35 miles) and I think it will hold up to 275 lbs? I think they have them for $999 or so. I put a lot of miles on it this summer without any issues. I liked the idea of using the throttle anytime with or without assist on. Only mod I did to it was add a little better saddle.
Quoted: 236 Post(s)
Liked 196 Times
Now you're still lifting a 50lb rack into your hitch receiver, but that's more of a straight lift with your legs - and you might just leave it in place if you're using it frequently enough.
Quoted: 2496 Post(s)
Liked 739 Times
I agree that FAT bikes are overkill for the o.p. purposes. I also think that folding, unless necessary, adds cost/complexity like laptops do vs desktops. All e-bikes worth the name spec bigger rubber, better brakes and sturdier construction than the same bike model without assist. Even a commuter oriented bike could handle rail trails and, IMO, the styling and overall presentation would slot in nicer for an over 70 customer. Juiced Bikes, Aventon and Batch also have interesting value oriented bikes. Mid-drives are probably out if the budget doesn't go over $2K+. Tires around 1.9" to 2.4" is plenty, and the bike won't weigh 70lbs.
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
I have limited storage space and lots of bicycles & motorcycles.
I prefer the smaller wheels on ebike because they take up less storage space when they are not ridden.
Smaller diameter wheels are also stronger and allow more torque to be generated from the hub motor.
Smaller size ebikes in general are just easier to transport on cars... likely less weight to pick up:
https://electrek.co/2021/11/09/prope...s-on-a-budget/
Likes For cat0020:
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
If you insist on a full sized ebike, this looks like a good deal:
https://electrek.co/2021/11/15/ride1...urban-e-bikes/
Likes For cat0020:
Quoted: 7 Post(s)
Liked 14 Times
Decided on the Ariel Rideal - fairly light wt - @ 50lbs, 750 motor, gravel tires, and good range. Order placed, hope to have it by the end of the week
Likes For Saluki1968:
Quoted: 7 Post(s)
Liked 14 Times
I will - snowed a bit last few days :-)
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Looks nice. One of my favorite things about e-bikes is that I can put studded tires on it with no problem. On an analogue bike, they really slow me down - but the e-bike just doesn't care.
Likes For chas58:
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
Probably extend battery life if you take it off the bike and store indoors when bike is not in use.
Storing battery in the shed with the bike over winter months would likely shorten its lifespan.
Quoted: 7 Post(s)
Liked 14 Times
Yes. I winter, the battery will be stored indoors.
Quoted: 7 Post(s)
Liked 14 Times
Looks like I may have one of the last Ariel Rideal bikes left. Just checked there web page today and the Redeal model is listed as "SOLD OUT". I have a tracking number for mine and and is now on it's way from the west coast. Expected delivery date is Monday, nov 22 :-)
Quoted: 590 Post(s)
Liked 445 Times
I have the Hilltopper 36v 350watt e-bike front hub wheel conversion kit on my commuter, so I can't comment on the whole bike, but I have about 1,500 miles on their e-hub so far with zero issues, and I really appreciate having the throttle only option for crossing crosswalks quickly. Heck, for that price and the fact it's on sale right now for the next 2 days, while writing this I actually went and bought the whole bike for my wife.
