Tern Link D8 Claris vs Neos derailleur
Old 07-03-21, 05:01 AM
Rome1901
Hi all, would like have some opinions regarding the 2 bikes.
www*thorusa*com/tern/linkd8claris*htm
www*thorusa*com/tern/linkd8new*htm
Please change * to . when using above links, unable to post links as I am yet to hit the 10 posts requirement.
In Australia, we only have the D8 with Neos derailleur and Sram MRX shifter instead of the the Shimano Claris with trigger shifter.
My understanding is Neos derailleurs are harder to source especially in Australia and if wanting to change to different brands, an adapter of some sort is required?
Would this be a deal breaker and I should just get the D7i for approx US$120 more?
Just after a bike that I can fit easily into the trunk of a Mazda 3 sedan to take to the bike paths on weekends where I ride around 30~40km, currently using a full size bike that I have to take apart to fit inside the car and it is getting a bit tedious.
TIA!
Rome1901 is offline
Old 07-04-21, 02:19 AM
Reddleman
iti biking
Reddleman's Avatar
Bikes: Tern Link D8, much upgraded
Quoted: 104 Post(s)
Liked 101 Times in 58 Posts
You do need an adaptor to use a standard derailleur in place of the Neos one. Next door in NZ I ended up ordering one from Tern’s webstore, but I found out later that the importer here can also supply them to order too.
The original Neos derailleur on our Tern Link D8 was okay, it’s just that we needed some more range on account of living in a city built on a volcanic field!
Reddleman is offline
Old 07-26-21, 05:41 PM
The Chemist
The Chemist's Avatar
Bikes: Waltly Custom Ti // Seaboard CX01 // Dahon Boardwalk
Quoted: 123 Post(s)
Liked 528 Times in 246 Posts
TIA!
You can actually replace the shifter without replacing the derailleur. I'm running a Neos derailleur on my Boardwalk but I hated the grip shifter so I replaced it with a Shimano Rapidfire shifter (same amount of cable pull). Only thing to watch out for is that the Neos derailleur goes to the largest cog when no cable tension is applied, which is the opposite of other kinds of derailleurs. The derailleur itself is fine, and has lasted me for many years.
The Chemist is offline
Old 07-26-21, 07:31 PM
Schwinnsta
Schwinnasaur
Schwinnsta's Avatar
Quoted: 459 Post(s)
Liked 184 Times in 122 Posts
Very cool and Google to know.
Schwinnsta is offline
