Garmin Tempe
Quoted: 18883 Post(s)
Liked 10,646 Times
Garmin Tempe
I'm looking for suggestions as to the best place to mount a Tempe unit on a drop bar road bike. Ideally out of the sunlight, far enough from the rider not to be influenced by body temp, not obstructed from broadcasting to a wrist watch, and secure enough not to tap tap tap the frame. I don't ride with a saddle bag.
Tempe is just bigger than a quarter, has a clip, and weighs about a gram so there's no worry about it throwing anything off balance.
Currently it's attached to the Di2 junction box under the stem, but that's kind of tacky.
Quoted: 3238 Post(s)
Liked 2,086 Times
Zip tie it on top of the seat post ?
Likes For Steve B.:
Liked 10,646 Times
I found a spot on the bottom of the rear derailleur. Sun doesn't reach, and it's far enough away from me.
Is there any carbon in an Ultegra Di2 RD? I think it's all metal and plastic, which would mean the sensor won't crack the casing.
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Placing it that low to the ground, wouldn't riding on hot asphalt in the summer really throw the readings off with the radiant heat from the asphalt? I've never seen one of these units or even knew they existed so it's just a guess on my part.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For John_V:
Likes For Alphamoose:
Liked 10,646 Times
Edge units have a thermometer in them. Anything with a barometer does, you need to know the temperature of the air you're measuring to determine altitude from pressure. But the Edge ones tend to go out in front of the bars and measure from the bottom, so they give you a pretty good reading and there's no reason to use a Tempe with them. I don't think Strava keeps the data but you'll see it in Connect.
Liked 10,646 Times
In other activities like skiing and backpacking, it's useful for how to dress because that seems to change, cold bothers me more as I get older.
Quoted: 4257 Post(s)
Liked 1,357 Times
The barometric altimeter is not temperature compensated. Temperature changes in the measuring device will affect the barometric pressure sensor and altimeter readings.
Likes For njkayaker:
